Date/Time: Sat, 04 May 2024 09:29:37 +0000
[Programming Help] - Delta for Current Traded Bid Ask Volume
View Count: 2203
[2019-02-12 08:10:00] |
User120942 - Posts: 71 |
I would like to request that an option be added to display the difference (Delta) of the Current Traded Bid and Ask Volume on the Chart Dom and Regular Trading DOM. Jigsaw has a similar feature with a floating count of the difference between the total number of market orders that occur between the bid and ask that is refreshed when the two columns are cleared. Thank You |
[2019-05-26 15:25:02] |
User525733 - Posts: 126 |
+1 you guys have received many similar requests ( all to make your dom remotely more useful as jigsaw's) yet you keep ignoring them!
[2019-05-26 20:16:08] |
I worked with Frederik from Simple System Trading to develop a work around study that let's you display the delta of the current bid ask columns. The values are displayed in the Label Column with a study called the Display Current Traded Volume. The Display study also allows you to add any SG study to DOM Label Column. The studies can be found here on the Simple System Trading Gumroad: https://gumroad.com/sstfrederik#LRfhaQ See the image attached as an example of what it looks like. In the image I have the High Delta, Current Delta, Low Delta, Total at Ask, Total at Bid, Total Volume, Duration since last Column Refresh, and Total Price Levels. P.S. The boxes highlighting the current traded volume imbalances is a separate study from another source. |
DOM Delta Volume.png / V - Attached On 2019-05-26 20:09:58 UTC - Size: 13.37 KB - 702 views |
[2022-04-25 14:12:14] |
pvt2020 - Posts: 5 |
Hi support team, i got the same request from User120942, would like to have an unique (resetable) number that display that on the dom directly (example on top of ask depht for example). Areciate the answer of User120942 but it does not seem to be exactly that. See picture please, jigsaw made this option available, this simple add on would be a game changer. PS jigsasw made it up to the recent traded volume. Thanks in advance |
SIERRAFORUM1.png / V - Attached On 2022-04-25 14:11:38 UTC - Size: 59.05 KB - 287 views Attachment Deleted. |
