Date/Time: Fri, 03 May 2024 02:31:50 +0000
[Programming Help] - Schedule Menu Click
View Count: 576
[2019-02-11 09:58:11] |
User942837 - Posts: 108 |
Is there a way (or workaround) in ASCIL to schedule a menu click? Example, Edit >> Export Bar and Study data to text file. Reason is, if I use this manually, it does include the data in last bar close even before the new one is opened (which is what I am after). Is this internally calling sc.WriteBarAndStudyDataToFile? Is there a way to make the same call? Please this is really stopping me from going forward. Thank you Date Time Of Last Edit: 2019-02-12 08:17:47
[2019-02-12 15:56:37] |
User291310 - Posts: 10 |
I am also trying to find a way to have the latest bar data after a session is closed, rather than waiting for the next bar open. I've looked at studies6.cpp (scsf_WriteBarAndStudyDataToFile) and I didn't find a way to change code in order to write on bar close. Presumably Sierrachart can use use the function they are calling when clicking Edit >> Export Bar and Study data to text file like you have just mentione
