Date/Time: Mon, 29 Apr 2024 18:39:19 +0000
Volume At Price Threshold Alert V2 - Ratios
View Count: 1283
[2019-02-11 09:50:12] |
sync - Posts: 9 |
I am using the Volume At Price Threshold Alert V2 with Comparison Method 'Ask Volume Bid Volume Ratio' and this is working fine when I set a % threshold and choose a marker. However, there doesn't seem to be a method for the opposite ratio, 'Bid Volume Ask Volume Ratio' with the ability to set a separate % threshold and separate marker. Can this be implemented? Currently, we can only have markers for ratios going in one direction and it would be very useful to have both sides presented. |
[2019-02-11 10:51:05] |
User907968 - Posts: 802 |
Hi, Did you try adding a second copy of the study and setting the % threshold to negative (see Percent Threshold section of linked document below) Volume at Price Threshold Alert V2 |
[2019-02-11 11:00:33] |
sync - Posts: 9 |
Hi, Thanks for that, I didn't spot the negative threshold text. That works now - sorry for the post! |
