Date/Time: Mon, 29 Apr 2024 05:01:20 +0000
Profile outline missing
View Count: 901
[2019-02-10 16:59:13] |
User97684 - Posts: 136 |
Hi , Pls help - volume profile outline not displayed on the 'bottom' side of the profile. This is when ' Display profile outline only' is selected. Many thanks |
where_is_the_profile_outline__.png / V - Attached On 2019-02-10 16:58:26 UTC - Size: 241.94 KB - 223 views |
[2019-02-12 00:46:12] |
We are not understanding this. And that image does not follow the requirements specified here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image It is just too complicated. You may not fully see the outline and you can adjust the scale to bring it into view by using Interactive Scale Move: Chart Scale and Scale Adjusting: Interactive Scale Move - Move Scale Up and Down Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
