Date/Time: Sat, 04 May 2024 21:16:22 +0000
Server side OCO orders & Trailing Stops
View Count: 1394
[2019-02-09 07:52:07] |
HAB-User115006 - Posts: 38 |
I want to Execute a OCO Buy order with 1 Target and 1 Trailing Stop, I will be using Rithmic that supports Server side OCO orders. So after the Primary OCO Buy order executes, do you send BOTH the Target and the Trailing orders to the exchange OR do you send the Target order only and manage the Trailing locally on Sierra? |
[2019-02-10 17:07:04] |
They will both be sent to Rithmic which will send them to the exchange but the trailing stop price is managed on your system as documented here: Order Types: Sierra Chart Management of Trailing Stop and Chase Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
