Date/Time: Wed, 15 May 2024 16:03:25 +0000
Numbers Bars study uses incorrect color to mark Up/Down bars
View Count: 619
[2019-02-08 00:10:51] |
User972768 - Posts: 166 |
Hello, I came across some irregularity in a way Number Bars study marks Up and Down bars in Point & Figure chart. Please take a look at attached screenshots. The only difference between them is that when I use numbers from 2nd column (while columns #1 & #3 are set to "No Text") coloring of Up/Down bars is correct. If I use Column #1 to show numbers and set Col #2 & 3 to "No text", the coloring is off. You can see groups of green and red columns instead of green-red-green-red-... pattern. Thanks and Best regards |
NumberBars_Column1.png / V - Attached On 2019-02-08 00:09:04 UTC - Size: 602.46 KB - 227 views NumberBars_Column2.png / V - Attached On 2019-02-08 00:09:13 UTC - Size: 64.51 KB - 238 views |
[2019-02-08 03:26:09] |
Please disregard this ticket. The issue was incorrect setting of "Graph Draw Type" in Chart >> Chart Settings >> Main Settings". Instead of "Point and Figure XO" it was "Candlestick Bar". Sorry for inconvenience. |
