Date/Time: Mon, 13 May 2024 20:36:36 +0000
1-minute bar chart doesn't display a new bar every minute
View Count: 630
[2019-02-07 12:04:08] |
User726297 - Posts: 13 |
Hello, I am actually watching the EPM19 contract (S&P e-mini differed month future), using a standard 1-minute chart, but it often happens that a new bar is created only every 5 or even 10 minutes. Why is this happening, and most important, is the price I see on the chart the real current price or a delayed price? Sorry if the question had already been asked but I found nothing about it. Regards |
[2019-02-07 15:51:42] |
This question is only appropriate for the exchange. You need to contact the exchange. This is not within the scope of our support.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-07 15:51:53
[2019-02-07 19:35:54] |
Sawtooth - Posts: 3995 |
The June 2019 ES futures contract is currently sparsely traded so you won't get a bar every minute unless there was trading in than minute. These may shed some light on this topic: Chart Settings: Include Columns With No Data (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu) Chart Settings: Do Not Draw Columns With No Data (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu) |
