Date/Time: Sun, 19 May 2024 02:02:18 +0000
DOM SC DATA - All Services gata
View Count: 700
[2019-02-06 13:41:27] |
philippe herbreteau - Posts: 1 |
Hello, I currently have the Sierra Chart 15-day trial version. I use SC DATA - All Services and I want to use that. My problem is that I can not configure the DOM, I have depth that appears in the columns Buy and Sell and I do not find how to do it. I enclose a screenshot of what I would like (PHSC01.PNG) and what I get (PHSC02.PNG). If you can help me, thank you cordially ---------------------------------------------------------- Bonjour, J'ai actuellement la version d'essai de 15 jours Sierra Chart. J'utilise le service SC DATA - All services et je souhaite utiliser que cela. Mon problème est que je n'arrive pas à configurer le DOM, je n'ai de profondeur qui s'affiche dans les colonnes Buy et Sell et je ne trouve pas comment faire. Je vous joint une copie d'écran dce que je voudrais(PHSC01.PNG) et de que j'obtiens(PHSC02.PNG). Si vous pouves m'aider, merci cordialement |
PHSC01.PNG / V - Attached On 2019-02-06 13:40:55 UTC - Size: 79.15 KB - 230 views PHSC02.PNG / V - Attached On 2019-02-06 13:40:59 UTC - Size: 29.48 KB - 236 views |
[2019-02-06 19:55:02] |
For market depth for the DAX would require that you use the Sierra Chart Exchange Data Feed and activate the EUREX exchange. Complete documentation is here: Sierra Chart Exchange Data Feed This data feed is an extra cost. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
