Date/Time: Sat, 18 May 2024 18:47:03 +0000
Custom bar period value from spreadsheet?
View Count: 554
[2019-02-06 08:14:41] |
User467728 - Posts: 1 |
Hi, is it possible to have "Volume Per Bar" chart where its period value is automatically updated from spreadsheet, whenever it's changed? Cheers, Adam |
[2019-02-06 08:44:27] |
There is no direct built-in way to do this but something like this could always be developed using the Advanced Custom Study Interface and Language which does support interaction with spreadsheets.
