Date/Time: Sun, 19 May 2024 06:11:58 +0000
Price goes past top of chart
View Count: 670
[2019-02-05 17:48:29] |
User283207 - Posts: 5 |
Sometimes the price bars go past the top of the screen. I can't pull them down. the only way I can get them down is to compress the prices on the right hand side of the chart. But then things get so small that studies can be hard to see. And the prices and studies are stuck near the top.how can I pull the prices and studies down when they go over the top or bottom. Sometimes it happen on the bottom of the screen
[2019-02-05 21:26:27] |
Refer to: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
