Date/Time: Sun, 19 May 2024 02:33:46 +0000
docs on sc.GetPersistent and sc.SetPersistent
View Count: 1255
[2019-02-05 17:30:09] |
User153286 - Posts: 44 |
Are there any online docs for these? for example: sc.GetPersistentPointer(1) sc.SetPersistentPointer(1, myvariable); sc.GetPersistentFloat(1) sc.GetPersistentInt(1) what is the 1? how are these to be used? |
[2019-02-06 04:17:41] |
I found it... no idea why I did not see it before they are on the ACSIL Interface Members - Functions page https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html and the 1 is the Id of the persistent variable, meaning if I use two of them in my study the value should change perhaps 1 and 2 |
[2019-02-06 05:14:06] |
The following section covers the Get and Set Persistent for all the variable types: sc.GetPersistentInt() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
