Date/Time: Tue, 07 May 2024 08:58:47 +0000
Move Drawings to a new symbol
View Count: 1160
[2019-02-05 15:05:53] |
tdug - Posts: 124 |
Hi, I have done a lot of analysis on a broker handle for oil GCL not CL. I now wish to use the CL symbol on my charts as I have a new broker feed. I am aware of the copy drawings to x chart function, however this is a parent/child relationship. Is it possible to move all analysis on one symbol to another? ie. if I update the symbol on the chart to CL, I want to have all the analysis ie. drawings form the GCL symbol chart. Many thanks |
[2019-02-05 17:37:52] |
The only way to do this is to enable this option: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-05 17:38:13
[2019-02-05 17:43:53] |
tdug - Posts: 124 |
ok, many thanks
