Date/Time: Mon, 29 Apr 2024 20:29:42 +0000
Some Chartbooks not getting Data through
View Count: 571
[2019-02-05 11:11:21] |
User513662 - Posts: 90 |
Hi, I run 16 chartbooks with around 5 charts in each. For some reason some of them just stop printing live data. When I switch to other chartbooks they are working ok. Restarting SC fixes the issue but this is not the solution. Is there anything I can provide you to investigate this? Thanks. |
[2019-02-05 17:44:49] |
Refer to this help topic: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
