Date/Time: Fri, 03 May 2024 18:26:49 +0000
Help with backtest
View Count: 838
[2019-02-05 05:38:48] |
User651753 - Posts: 77 |
I am trying to complete a spreadsheet backtest ., It looks like bar backtest complete the test, and show some data ( total trade, Percent Profitable, but it doesn't show the rest ( Profit and Loss, etc https://imgur.com/a/hsPJJJX I've changed the dropdown from points > tick etc but each setting didn't change anything. I am testing with Bitmex, i don't know if the value in profit are BTC, It uses to work great and show each 1 point = $1 profit but since the update look like everything has changed. Date Time Of Last Edit: 2019-02-05 05:41:27
[2019-02-05 06:10:38] |
You need to choose the particular symbol at the top. That is a must. And you will want to use the Profit/Loss format of Points. Do not use Currency Value. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
