Date/Time: Tue, 07 May 2024 23:25:09 +0000
Some kind of marking between session times?
View Count: 672
[2019-02-03 14:30:41] |
User284663 - Posts: 44 |
Hello SC support, I am trying to find some kind of marker or gap on my line chart to show when the symbol was closed, I recall that I may have seen a gap or a flat line displaying this (the time when the symbol wasn't open for trading) Is there anything like this I could make use of? THANKS |
[2019-02-04 19:13:06] |
It sounds like what you are looking for is the following option: Chart Settings: Include Columns With No Data (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-05 07:21:05] |
Hmm, I'm using a line chart and that setting doesn't appear to be doing anything.. perhaps just a simple straight horizontal line would suffice my query but here is the catch.. During weekend hours the line has moved up and down, this I do not understand as the exchange is closed during those hours, am I missing something? In summary, I'm just looking for a simple visual aid to acknowledge the exchange is closed during this period on the chart, but it seems there may possibly be a few variables in play. Date Time Of Last Edit: 2019-02-05 07:25:47
[2019-02-05 12:58:37] |
Edit: Chart>Chart settings>Main settings tab - Gap fill, fill all bar gaps SOLVED |
