Date/Time: Mon, 06 May 2024 17:23:08 +0000
1 No data. Can't access Topstep Account on Sierra. 3. Can't find e min indexes on Sierra s
View Count: 813
[2019-02-01 18:29:32] |
Russell C - Posts: 3 |
1. When I login to my Sierra Account I am not getting any data. No price movement on charts or Dom. Please advise remedy. 2 . I have entered a trading Combine with Topstep trader and opted for Sierra Charts. I received login credentials from Topstep but I CANNOT access Sierra charts with these credentials...invalid username/password. PLEASE TELL ME HOW TO LOGIN TO MY TOPSTEP TRADER ACCOUNT. Thanks. 3. I CANNOT find the same indexes on Sierra as I trade on my Infinity AT dom. Please advise if Sierra have the same e-mini futures contracts for the Nasdaq ((NQ9H), The Russell (RTYH9), the Dow (YMH9), and the S & P (ESH9) I look forward to hearing from you. With thanks and kind regards, Date Time Of Last Edit: 2019-02-01 18:53:25
[2019-02-01 20:57:25] |
1. We need to know if Top Step Trader set you up on the Rithmic or CTS system? We need to know which one. 2. We do see that you have successfully logged into Sierra Chart. 3. Yes all of these futures contracts will be listed in File >> Find Symbol but the symbols can be slightly different. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-04 11:28:52] |
Thank you for your response. 1. I confirm that top-step is CTS system. CAN YOU PLEASE CONFIRM THAT SIERRA WILL NOW BE ABLE TO ALLOW ME TO LOG INTO MY TOPSTEP ACCOUNT? THANK YOU. 2. Yes I can login to Sierra chart BUT NO LIVE DATA!!!! Can you please RECTIFY this. 3. Please advise me of Sierra Charts symbols for E-mini Nasdaq, S&P, Russell 2000, and Dow. I CANNOT FIND THEM. Thanks. Your definitive response to my issues would be most welcome as I am currently unable to trade until these are resolved. |
[2019-02-04 16:14:03] |
Sierra Chart - Max - Posts: 5605 |
Refer to the CTS setup instructions here: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions Sierra Chart Support |
[2019-02-04 18:09:00] |
2. We do not have control over this data. 3. The symbols are listed in File >> Find Symbol. And be sure to refer to our prior post as well for the setup instructions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-04 18:09:12
[2019-02-04 19:07:14] |
Thank you. Can you please reply to point number 1. Thank you |
[2019-02-04 19:22:11] |
Yes you just need to follow the set up instructions here: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
