Date/Time: Sun, 28 Apr 2024 13:16:17 +0000
Replay issue - Paused/Repaly at same time
View Count: 1353
[2013-11-12 15:53:33] |
RafiH - Posts: 28 |
In replay I checked "For all charts in Chartbook", but I have some paused and others playing at same time. When I click play, they switch and the ones paused start playing, while the ones playing go to paused?
Private File |
[2013-11-13 21:05:11] |
This would make sense. All the charts should be in the same state. What you would have to do is completely stop the replay to stop all the charts and start it again.
