Date/Time: Thu, 09 May 2024 04:17:08 +0000
I want to look at H4 chart, but
View Count: 538
[2019-01-30 23:14:13] |
CC WOLF - Posts: 1 |
I can't find the H4 or up resolution. Is there a way to add the H4, D1, and higher resolution options?
[2019-01-31 08:22:20] |
Refer to: Changing Chart Bars Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
