Date/Time: Wed, 08 May 2024 13:19:58 +0000
CTS Data not updating
View Count: 887
[2019-01-30 17:15:07] |
hnariman - Posts: 4 |
Dear Sir/Madam, I have CTS configured as been explained on TopStepTrader website, however for CL.20190200 contract last candlestick on my chart is dated Tue 2019-01-22. I guess I'm missing some configuration or activation, however I couldn't manage it through Sierra Chart or TST website manuals and so. Herein, I'm looking for your kind support and assistance in order to make things working. Please see screenshot attached. Thank You in advance, My Best, https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=25602 |
[2019-01-30 17:15:16] |
Sierra Chart - Max - Posts: 5608 |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support |
[2019-01-30 17:38:17] |
Reading Internal Order ID file. | 2019-01-28 10:16:16 Reading Trade Orders file. | 2019-01-28 10:16:16 Reading Trade Positions file. | 2019-01-28 10:16:16 Account Balance file. | 2019-01-28 10:16:16 Listening on UDP port 22904. | 2019-01-28 10:16:16 Software version: 1865 64-bit | 2019-01-28 10:16:16 Usage end date: 2019-02-28 | 2019-01-28 10:16:16 Enabled for: Advanced Features. | 2019-01-28 10:16:16 Enabled for: Advanced Features 2. | 2019-01-28 10:16:16 Enabled for: Sierra Chart Historical Data Service. | 2019-01-28 10:16:16 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-01-28 10:16:16 Current selected Data/Trading service: CTS T4 FIX | 2019-01-28 10:16:16 Chart Update Interval: 500 | 2019-01-28 10:16:16 Intraday Data Storage Time Unit: 1 | 2019-01-28 10:16:16 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-01-28 10:16:16 2019-01-28 20:16:16 Local computer time | 2019-01-28 10:16:16 2019-01-28 16:16:16 Local computer time in UTC | 2019-01-28 10:16:16 2019-01-28 10:16:16 Local computer time in SC Time Zone | 2019-01-28 10:16:16 2019-01-28 16:16:17 Server time in UTC | 2019-01-28 10:16:16 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-01-28 10:16:16 Program path: C:\SierraChart\ | 2019-01-28 10:16:16 Data Files path: C:\SierraChart\Data\ | 2019-01-28 10:16:16 OS Version Number: 10.0 | 2019-01-28 10:16:16 Locale Setting: C | 2019-01-28 10:16:16 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-01-28 10:16:16 Checking for new symbol settings. Requested symbol settings MD5 for service code cts. Request ID: 1. | 2019-01-28 10:16:16 HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2019-01-28 10:16:16 HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 46.4.97.203. | 2019-01-28 10:16:16 HTTPS login.sierrachart.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-28 10:16:17 HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:17 HTTPS login.sierrachart.com:443 (1) | Closed. | 2019-01-28 10:16:17 Received 5 login tokens. | 2019-01-28 10:16:17 Symbol settings MD5 received. Request ID: 1. | 2019-01-28 10:16:17 Symbol settings are up-to-date for cts. | 2019-01-28 10:16:17 HTTPS www.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-28 10:16:17 HTTPS www.sierrachart.com:443 (4) | Shutdown started. Waiting for graceful close. | 2019-01-28 10:16:17 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-28 10:16:17 HTTPS www.sierrachart.com:443 (2) | Closed. | 2019-01-28 10:16:17 HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2019-01-28 10:16:17 HTTPS www.sierrachart.com:443 (4) | Closed. | 2019-01-28 10:16:17 HTTPS www.sierrachart.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-28 10:16:18 HTTPS www.sierrachart.com:443 (1) | Connecting to IP: 46.4.97.203. | 2019-01-28 10:16:18 HTTPS www.sierrachart.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-28 10:16:19 HTTPS www.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:19 HTTPS www.sierrachart.com:443 (1) | Closed. | 2019-01-28 10:16:19 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:16:22 CTS T4 FIX | Firm: PTP | 2019-01-28 10:16:22 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:16:23 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:16:23 CTS FIX: Sending the Logon message. | 2019-01-28 10:16:23 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:24 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:16:24 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:16:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:16:24 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:16:24 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:24 CTS T4 FIX | Disconnected. | 2019-01-28 10:16:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:24 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:16:24 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:16:24 CTS FIX socket (1) | Closed. | 2019-01-28 10:16:24 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:16:27 CTS T4 FIX | Firm: PTP | 2019-01-28 10:16:27 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:16:27 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:16:27 CTS FIX: Sending the Logon message. | 2019-01-28 10:16:27 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:28 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:16:28 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:16:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:16:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:28 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:16:28 CTS T4 FIX | Disconnected. | 2019-01-28 10:16:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:28 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:16:28 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:16:28 CTS FIX socket (1) | Closed. | 2019-01-28 10:16:28 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:16:31 CTS T4 FIX | Firm: PTP | 2019-01-28 10:16:31 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:16:31 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:16:31 CTS FIX: Sending the Logon message. | 2019-01-28 10:16:31 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:32 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:16:32 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:16:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:16:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:32 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:16:32 CTS T4 FIX | Disconnected. | 2019-01-28 10:16:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:32 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:16:32 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:16:32 CTS FIX socket (1) | Closed. | 2019-01-28 10:16:32 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:16:35 CTS T4 FIX | Firm: PTP | 2019-01-28 10:16:35 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:16:35 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:16:35 CTS FIX: Sending the Logon message. | 2019-01-28 10:16:36 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:36 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:16:36 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:16:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:16:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:36 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:16:36 CTS T4 FIX | Disconnected. | 2019-01-28 10:16:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:36 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:16:36 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:16:36 CTS FIX socket (1) | Closed. | 2019-01-28 10:16:36 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:16:39 CTS T4 FIX | Firm: PTP | 2019-01-28 10:16:39 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:16:39 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:16:39 CTS FIX: Sending the Logon message. | 2019-01-28 10:16:40 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:40 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:16:40 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:16:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:16:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:40 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:16:40 CTS T4 FIX | Disconnected. | 2019-01-28 10:16:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:40 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:16:40 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:16:40 CTS FIX socket (1) | Closed. | 2019-01-28 10:16:40 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:16:43 CTS T4 FIX | Firm: PTP | 2019-01-28 10:16:43 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:16:43 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:16:43 CTS FIX: Sending the Logon message. | 2019-01-28 10:16:43 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:44 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:16:44 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:16:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:16:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:44 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:16:44 CTS T4 FIX | Disconnected. | 2019-01-28 10:16:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:44 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:16:44 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:16:44 CTS FIX socket (1) | Closed. | 2019-01-28 10:16:44 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:16:47 CTS T4 FIX | Firm: PTP | 2019-01-28 10:16:47 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:16:49 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:16:49 CTS FIX: Sending the Logon message. | 2019-01-28 10:16:49 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:50 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:16:50 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:16:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:16:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:50 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:16:50 CTS T4 FIX | Disconnected. | 2019-01-28 10:16:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:50 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:16:50 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:16:50 CTS FIX socket (1) | Closed. | 2019-01-28 10:16:50 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:16:53 CTS T4 FIX | Firm: PTP | 2019-01-28 10:16:53 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:16:53 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:16:53 CTS FIX: Sending the Logon message. | 2019-01-28 10:16:53 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:16:54 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:16:54 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:16:54 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:16:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:54 CTS T4 FIX | Disconnected. | 2019-01-28 10:16:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:54 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:16:54 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:16:54 CTS FIX socket (1) | Closed. | 2019-01-28 10:16:54 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:16:57 CTS T4 FIX | Firm: PTP | 2019-01-28 10:16:57 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:16:57 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:16:57 CTS FIX: Sending the Logon message. | 2019-01-28 10:16:57 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:16:58 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:16:58 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:16:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:16:58 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:16:58 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:58 CTS T4 FIX | Disconnected. | 2019-01-28 10:16:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:16:58 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:16:58 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:16:58 CTS FIX socket (1) | Closed. | 2019-01-28 10:16:58 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:01 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:01 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:01 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:01 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:02 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:02 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:02 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:02 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:02 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:02 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:02 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:02 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:02 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:05 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:05 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:05 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:05 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:05 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:06 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:06 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:06 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:06 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:06 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:06 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:06 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:06 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:09 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:09 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:09 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:09 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:09 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:10 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:10 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:10 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:10 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:10 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:10 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:10 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:10 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:13 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:13 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:13 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:13 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:14 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:14 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:14 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:14 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:14 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:14 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:14 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:14 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:14 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:17 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:17 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:17 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:17 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:18 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:18 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:18 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:18 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:18 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:18 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:18 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:18 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:18 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:21 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:21 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:21 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:21 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:22 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:22 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:22 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:22 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:22 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:22 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:22 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:22 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:22 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:25 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:25 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:25 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:25 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:26 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:26 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:26 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:26 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:26 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:26 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:26 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:26 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:26 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:29 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:29 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:29 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:29 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:30 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:30 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:30 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:30 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:30 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:30 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:30 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:30 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:30 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:33 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:33 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:33 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:33 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:34 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:34 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:34 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:34 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:34 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:34 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:34 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:34 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:34 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:37 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:37 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:37 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:37 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:38 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:38 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:38 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:38 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:38 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:38 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:39 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:39 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:39 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:41 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:41 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:41 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:41 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:42 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:42 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:42 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:42 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:42 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:42 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:42 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:42 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:42 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:45 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:45 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:45 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:45 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:46 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:46 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:46 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:46 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:46 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:46 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:46 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:46 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:46 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:49 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:49 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:49 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:49 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:50 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:50 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:50 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:50 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:50 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:50 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:50 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:50 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:50 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:53 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:53 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:53 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:53 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:54 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:54 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:54 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:54 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:54 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:54 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:55 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:55 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:55 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:17:57 CTS T4 FIX | Firm: PTP | 2019-01-28 10:17:57 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:17:57 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:17:57 CTS FIX: Sending the Logon message. | 2019-01-28 10:17:58 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:17:58 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:17:58 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:17:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:17:58 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:58 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:17:58 CTS T4 FIX | Disconnected. | 2019-01-28 10:17:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:17:58 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:17:58 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:17:58 CTS FIX socket (1) | Closed. | 2019-01-28 10:17:58 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:01 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:01 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:01 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:01 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:02 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:02 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:02 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:02 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:02 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:02 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:03 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:03 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:03 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:05 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:05 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:05 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:05 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:06 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:07 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:07 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:07 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:07 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:07 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:07 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:07 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:07 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:10 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:10 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:10 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:10 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:10 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:11 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:11 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:11 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:11 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:11 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:11 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:11 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:11 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:11 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:11 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:14 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:14 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:14 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:14 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:14 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:15 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:15 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:15 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:15 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:15 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:15 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:15 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:15 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:18 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:18 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:18 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:18 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:18 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:19 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:19 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:19 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:19 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:19 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:19 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:19 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:19 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:22 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:22 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:22 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:22 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:22 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:23 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:23 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:23 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:23 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:23 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:23 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:23 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:23 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:23 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:26 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:26 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:26 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:26 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:26 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:27 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:27 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:27 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:27 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:27 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:27 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:27 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:27 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:30 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:30 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:30 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:30 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:30 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:31 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:31 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:31 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:31 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:31 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:31 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:31 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:31 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:34 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:34 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:34 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:34 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:34 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:35 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:35 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:35 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:35 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:35 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:35 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:35 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:35 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:38 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:38 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:38 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:38 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:38 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:39 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:39 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:39 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:39 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:39 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:39 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:39 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:39 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:42 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:42 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:42 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:42 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:42 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:43 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:43 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:43 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:43 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:43 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:43 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:43 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:43 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:46 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:46 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:46 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:46 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:46 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:47 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:47 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:47 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:47 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:47 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:47 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:47 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:47 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:47 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:50 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:50 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:51 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:51 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:52 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:52 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:52 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:52 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:52 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:52 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:52 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:52 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:52 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:55 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:55 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:55 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:55 CTS FIX: Sending the Logon message. | 2019-01-28 10:18:56 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:18:56 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:18:56 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:18:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:18:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:56 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:18:56 CTS T4 FIX | Disconnected. | 2019-01-28 10:18:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:18:56 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:18:56 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:18:56 CTS FIX socket (1) | Closed. | 2019-01-28 10:18:56 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:18:59 CTS T4 FIX | Firm: PTP | 2019-01-28 10:18:59 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:18:59 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:18:59 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:00 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:00 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:00 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:00 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:00 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:00 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:00 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:00 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:00 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:03 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:03 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:03 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:03 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:04 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:04 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:04 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:04 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:04 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:04 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:04 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:04 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:04 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:07 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:07 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:07 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:07 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:08 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:08 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:09 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:09 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:08 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:09 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:09 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:09 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:09 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:09 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:12 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:12 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:12 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:12 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:12 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:12 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:12 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:12 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:12 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:13 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:13 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:13 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:13 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:13 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:16 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:16 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:17 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:17 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:18 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:18 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:18 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:18 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:18 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:18 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:18 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:18 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:18 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:21 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:21 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:21 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:21 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:22 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:22 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:22 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:22 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:22 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:22 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:23 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:23 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:23 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:25 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:25 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:25 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:25 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:26 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:26 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:26 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:26 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:26 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:26 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:27 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:27 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:27 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:29 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:29 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:30 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:30 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:31 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:31 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:31 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:31 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:31 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:31 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:32 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:32 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:32 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:34 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:34 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:34 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:34 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:35 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:36 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:36 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:36 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:36 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:36 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:36 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:36 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:36 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:39 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:39 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:39 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:39 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:39 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:40 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:40 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:40 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:40 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:40 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:40 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:40 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:40 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:43 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:43 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:43 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:43 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:43 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:44 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:44 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:44 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:44 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:44 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:44 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:44 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:44 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:19:47 CTS T4 FIX | Firm: PTP | 2019-01-28 10:19:47 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:19:47 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:19:47 CTS FIX: Sending the Logon message. | 2019-01-28 10:19:47 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:19:48 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:19:48 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:19:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:19:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:48 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:19:48 CTS T4 FIX | Disconnected. | 2019-01-28 10:19:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:19:48 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:19:48 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:19:48 CTS FIX socket (1) | Closed. | 2019-01-28 10:19:48 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:21:48 CTS T4 FIX | Firm: PTP | 2019-01-28 10:21:48 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:21:48 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:21:48 CTS FIX: Sending the Logon message. | 2019-01-28 10:21:48 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:21:49 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:21:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:21:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:21:49 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:21:49 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:21:49 CTS T4 FIX | Disconnected. | 2019-01-28 10:21:49 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:21:49 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:21:49 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:21:49 CTS FIX socket (1) | Closed. | 2019-01-28 10:21:49 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:23:49 CTS T4 FIX | Firm: PTP | 2019-01-28 10:23:49 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:23:49 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:23:49 CTS FIX: Sending the Logon message. | 2019-01-28 10:23:50 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:23:50 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:23:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:23:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:23:50 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:23:50 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:23:50 CTS T4 FIX | Disconnected. | 2019-01-28 10:23:50 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:23:50 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:23:50 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:23:50 CTS FIX socket (1) | Closed. | 2019-01-28 10:23:50 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:25:50 CTS T4 FIX | Firm: PTP | 2019-01-28 10:25:50 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:25:50 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:25:50 CTS FIX: Sending the Logon message. | 2019-01-28 10:25:51 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:25:51 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:25:51 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:25:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:25:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:25:51 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:25:51 CTS T4 FIX | Disconnected. | 2019-01-28 10:25:51 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:25:51 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:25:51 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:25:51 CTS FIX socket (1) | Closed. | 2019-01-28 10:25:51 CLZ18 Daily #1 | Reloading chart. | 2019-01-28 10:27:51 CLZ18 Daily #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLZ18.dly | 2019-01-28 10:27:51 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:27:51 CTS T4 FIX | Firm: PTP | 2019-01-28 10:27:51 HD Request # 2 | Downloading Historical Daily chart data for CLZ18. Starting date: 1969-01-28. Service: cts | 2019-01-28 10:27:51 HD Request # 2 | Requesting historical Daily data for CLZ18 starting at 1969-01-27 | 2019-01-28 10:27:51 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:27:51 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:27:51 HTTPS historicaldata.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-28 10:27:51 HTTPS historicaldata.sierrachart.com:443 (2) | Connecting to IP: 88.99.0.216. | 2019-01-28 10:27:51 CTS FIX: Sending the Logon message. | 2019-01-28 10:27:52 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:27:52 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:27:52 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:27:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:27:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:27:52 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:27:52 CTS T4 FIX | Disconnected. | 2019-01-28 10:27:53 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:27:53 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:27:53 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:27:53 CTS FIX socket (1) | Closed. | 2019-01-28 10:27:53 HD Request # 2 | Receiving historical Daily data for CLZ18 starting at 2009-11-23 | 2019-01-28 10:27:53 HD Request # 2 | Writing historical Daily data to the file CLZ18.dly | 2019-01-28 10:27:53 HD Request # 2 | Received 2266 records from 2009-11-23 00:00:00 to 2018-11-19 00:00:00 (9.0years) and wrote 2266 records for CLZ18 | 2019-01-28 10:27:53 HD Request # 2 | Completion time: 1s | 2019-01-28 10:27:53 HD Request # 2 | Daily data download complete for CLZ18. Unique request ID: 1 | 2019-01-28 10:27:53 Removed historical data download ID 1 | 2019-01-28 10:27:53 HTTPS historicaldata.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-28 10:27:53 HTTPS historicaldata.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-28 10:27:53 HTTPS historicaldata.sierrachart.com:443 (2) | Closed. | 2019-01-28 10:27:53 CLZ18 Daily #1 | Reloading chart. | 2019-01-28 10:27:53 CL.20190100.CME_NY #2 | Reloading chart. | 2019-01-28 10:29:27 Intraday data recording state for symbol CL.20190100.CME_NY is set to download 'Pending'. | 2019-01-28 10:29:27 HD Request # 3 | Downloading Intraday chart data for CL.20190100.CME_NY to the file CL.20190100.CME_NY.scid. Service: nymex | 2019-01-28 10:29:27 Compressing file: C:\SierraChart\Data\CL.20190100.CME_NY.scid. This may take a while. | 2019-01-28 10:29:27 HD Request # 3 | Download start date-time: 2018-07-26 11:29:27.000 | 2019-01-28 10:29:27 HD Request # 3 | Using server: ds7.sierracharts.com port 10149 | 2019-01-28 10:29:27 Socket (1) | Creating socket. | 2019-01-28 10:29:27 Socket (1) | Connecting to IP: 8.18.161.133. | 2019-01-28 10:29:27 HD Request # 3 | Setting DTC encoding to Binary VLS | 2019-01-28 10:29:28 HD Request # 3 | Sending historical data logon request message. | 2019-01-28 10:29:28 HD Request # 3 | Requesting Intraday data. Start date-time: 2018-07-26 11:29:27. Record interval: 1. Symbol: CLF19 | 2019-01-28 10:29:28 HD Request # 3 | Decompressing data. | 2019-01-28 10:29:28 HD Request # 3 | Receiving Intraday data for CL.20190100.CME_NY starting at 2018-07-26 11:35:53 | 2019-01-28 10:29:29 HD Request # 3 | Timestamp of first Intraday data file record written: 2018-07-26 11:35:53 | 2019-01-28 10:29:29 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:29:53 CTS T4 FIX | Firm: PTP | 2019-01-28 10:29:53 CTS FIX socket (2) | Creating socket. Using TLS 1.0. | 2019-01-28 10:29:53 CTS FIX socket (2) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:29:53 CTS FIX: Sending the Logon message. | 2019-01-28 10:29:53 CTS FIX socket (2) | Socket gracefully closed by remote side. | 2019-01-28 10:29:54 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:29:54 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:29:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:29:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:29:54 CTS FIX socket (2) | Write in progress. Shutdown being delayed. | 2019-01-28 10:29:54 CTS T4 FIX | Disconnected. | 2019-01-28 10:29:54 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:29:54 CTS FIX socket (2) | Write has completed. Shutdown being performed. | 2019-01-28 10:29:54 CTS FIX socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:29:54 CTS FIX socket (2) | Closed. | 2019-01-28 10:29:54 HD Request # 3 | Historical data for CL.20190100.CME_NY is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2019-01-28 10:29:58 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-01-28 10:29:58 Historical data download thread signaled to stop. | 2019-01-28 10:29:58 HD Request # 3 | Received 1375162 records from 2018-07-26 11:35:53 to 2018-12-19 13:29:41 (146.1 days) and wrote 1375162 records for CL.20190100.CME_NY | 2019-01-28 10:29:58 HD Request # 3 | Completion time: 30s | 2019-01-28 10:29:58 HD Request # 3 | Intraday data download complete for CL.20190100.CME_NY. Unique request ID: 2 | 2019-01-28 10:29:58 Removed historical data download ID 2 | 2019-01-28 10:29:58 Socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:29:58 Socket (1) | Closed. | 2019-01-28 10:29:58 CLZ18 Daily #1 | Reloading chart. | 2019-01-28 10:30:34 CLZ18 Weekly #1 | Reloading chart. | 2019-01-28 10:30:36 CLZ18 Daily #1 | Reloading chart. | 2019-01-28 10:31:05 CLZ18 Daily #1 | Reloading chart. | 2019-01-28 10:31:10 CLZ18 Weekly #1 | Reloading chart. | 2019-01-28 10:31:11 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:31:54 CTS T4 FIX | Firm: PTP | 2019-01-28 10:31:54 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:31:54 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:31:54 CTS FIX: Sending the Logon message. | 2019-01-28 10:31:54 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:31:55 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:31:55 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:31:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:31:55 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:31:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:31:55 CTS T4 FIX | Disconnected. | 2019-01-28 10:31:55 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:31:55 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:31:55 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:31:55 CTS FIX socket (1) | Closed. | 2019-01-28 10:31:55 CLZ18 Weekly #1 | Reloading chart. | 2019-01-28 10:33:31 CLZ18 Daily #1 | Reloading chart. | 2019-01-28 10:33:36 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:33:55 CTS T4 FIX | Firm: PTP | 2019-01-28 10:33:55 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:33:55 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:33:55 CTS FIX: Sending the Logon message. | 2019-01-28 10:33:56 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:33:56 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:33:56 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:33:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:33:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:33:56 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:33:56 CTS T4 FIX | Disconnected. | 2019-01-28 10:33:56 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:33:56 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:33:56 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:33:56 CTS FIX socket (1) | Closed. | 2019-01-28 10:33:56 CLZ18 Weekly #1 | Reloading chart. | 2019-01-28 10:34:51 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:35:56 CTS T4 FIX | Firm: PTP | 2019-01-28 10:35:56 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:35:56 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:35:56 CTS FIX: Sending the Logon message. | 2019-01-28 10:35:57 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:35:57 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:35:57 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:35:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:35:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:35:57 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:35:57 CTS T4 FIX | Disconnected. | 2019-01-28 10:35:57 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:35:57 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:35:57 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:35:57 CTS FIX socket (1) | Closed. | 2019-01-28 10:35:57 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:37:57 CTS T4 FIX | Firm: PTP | 2019-01-28 10:37:57 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:37:58 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:37:58 CTS FIX: Sending the Logon message. | 2019-01-28 10:37:58 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:37:59 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:37:59 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:37:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:37:59 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:37:59 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:37:59 CTS T4 FIX | Disconnected. | 2019-01-28 10:37:59 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:37:59 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:37:59 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:37:59 CTS FIX socket (1) | Closed. | 2019-01-28 10:37:59 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:39:59 CTS T4 FIX | Firm: PTP | 2019-01-28 10:39:59 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:39:59 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:39:59 CTS FIX: Sending the Logon message. | 2019-01-28 10:39:59 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:40:00 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:40:00 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:40:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:40:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:40:00 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:40:00 CTS T4 FIX | Disconnected. | 2019-01-28 10:40:00 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:40:00 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:40:00 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:40:00 CTS FIX socket (1) | Closed. | 2019-01-28 10:40:00 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:42:00 CTS T4 FIX | Firm: PTP | 2019-01-28 10:42:00 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:42:00 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:42:00 CTS FIX: Sending the Logon message. | 2019-01-28 10:42:01 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:42:01 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:42:01 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:42:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:42:01 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:42:01 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:42:01 CTS T4 FIX | Disconnected. | 2019-01-28 10:42:01 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:42:01 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:42:01 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:42:01 CTS FIX socket (1) | Closed. | 2019-01-28 10:42:01 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:44:01 CTS T4 FIX | Firm: PTP | 2019-01-28 10:44:01 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:44:01 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:44:01 CTS FIX: Sending the Logon message. | 2019-01-28 10:44:02 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:44:02 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:44:02 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:44:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:44:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:44:02 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:44:02 CTS T4 FIX | Disconnected. | 2019-01-28 10:44:02 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:44:02 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:44:03 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:44:03 CTS FIX socket (1) | Closed. | 2019-01-28 10:44:03 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:46:02 CTS T4 FIX | Firm: PTP | 2019-01-28 10:46:02 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:46:03 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:46:03 CTS FIX: Sending the Logon message. | 2019-01-28 10:46:03 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:46:04 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:46:04 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:46:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:46:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:46:04 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:46:04 CTS T4 FIX | Disconnected. | 2019-01-28 10:46:04 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:46:04 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:46:04 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:46:04 CTS FIX socket (1) | Closed. | 2019-01-28 10:46:04 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:48:04 CTS T4 FIX | Firm: PTP | 2019-01-28 10:48:04 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:48:04 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:48:04 CTS FIX: Sending the Logon message. | 2019-01-28 10:48:04 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:48:05 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:48:05 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:48:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:48:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:48:05 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:48:05 CTS T4 FIX | Disconnected. | 2019-01-28 10:48:05 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:48:05 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:48:05 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:48:05 CTS FIX socket (1) | Closed. | 2019-01-28 10:48:05 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:50:05 CTS T4 FIX | Firm: PTP | 2019-01-28 10:50:05 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:50:06 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:50:06 CTS FIX: Sending the Logon message. | 2019-01-28 10:50:06 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:50:07 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:50:07 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:50:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:50:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:50:07 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:50:07 CTS T4 FIX | Disconnected. | 2019-01-28 10:50:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:50:07 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:50:07 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:50:07 CTS FIX socket (1) | Closed. | 2019-01-28 10:50:07 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:52:07 CTS T4 FIX | Firm: PTP | 2019-01-28 10:52:07 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:52:09 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:52:09 CTS FIX: Sending the Logon message. | 2019-01-28 10:52:09 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:52:10 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:52:10 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:52:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:52:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:52:10 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:52:10 CTS T4 FIX | Disconnected. | 2019-01-28 10:52:10 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:52:10 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:52:10 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:52:10 CTS FIX socket (1) | Closed. | 2019-01-28 10:52:10 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:54:10 CTS T4 FIX | Firm: PTP | 2019-01-28 10:54:10 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:54:10 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:54:10 CTS FIX: Sending the Logon message. | 2019-01-28 10:54:10 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:54:11 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:54:11 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:54:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:54:11 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:54:11 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:54:11 CTS T4 FIX | Disconnected. | 2019-01-28 10:54:11 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:54:11 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:54:11 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:54:11 CTS FIX socket (1) | Closed. | 2019-01-28 10:54:11 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:56:11 CTS T4 FIX | Firm: PTP | 2019-01-28 10:56:11 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:56:11 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:56:11 CTS FIX: Sending the Logon message. | 2019-01-28 10:56:11 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:56:12 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:56:12 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:56:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:56:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:56:12 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:56:12 CTS T4 FIX | Disconnected. | 2019-01-28 10:56:12 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:56:12 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:56:12 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:56:12 CTS FIX socket (1) | Closed. | 2019-01-28 10:56:12 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 10:58:12 CTS T4 FIX | Firm: PTP | 2019-01-28 10:58:12 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 10:58:12 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 10:58:12 CTS FIX: Sending the Logon message. | 2019-01-28 10:58:13 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 10:58:13 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 10:58:13 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 10:58:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 10:58:13 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:58:13 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 10:58:13 CTS T4 FIX | Disconnected. | 2019-01-28 10:58:13 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 10:58:13 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 10:58:13 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 10:58:13 CTS FIX socket (1) | Closed. | 2019-01-28 10:58:13 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:00:13 CTS T4 FIX | Firm: PTP | 2019-01-28 11:00:13 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:00:13 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:00:13 CTS FIX: Sending the Logon message. | 2019-01-28 11:00:14 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:00:14 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:00:14 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:00:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:00:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:00:14 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:00:14 CTS T4 FIX | Disconnected. | 2019-01-28 11:00:14 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:00:14 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:00:15 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:00:15 CTS FIX socket (1) | Closed. | 2019-01-28 11:00:15 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:02:14 CTS T4 FIX | Firm: PTP | 2019-01-28 11:02:14 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:02:15 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:02:15 CTS FIX: Sending the Logon message. | 2019-01-28 11:02:15 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:02:16 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:02:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:02:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:02:16 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:02:16 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:02:16 CTS T4 FIX | Disconnected. | 2019-01-28 11:02:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:02:16 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:02:16 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:02:16 CTS FIX socket (1) | Closed. | 2019-01-28 11:02:16 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:04:16 CTS T4 FIX | Firm: PTP | 2019-01-28 11:04:16 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:04:16 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:04:16 CTS FIX: Sending the Logon message. | 2019-01-28 11:04:16 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:04:17 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:04:17 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:04:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:04:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:04:17 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:04:17 CTS T4 FIX | Disconnected. | 2019-01-28 11:04:17 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:04:17 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:04:17 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:04:17 CTS FIX socket (1) | Closed. | 2019-01-28 11:04:17 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:06:17 CTS T4 FIX | Firm: PTP | 2019-01-28 11:06:17 CTS FIX socket (2) | Creating socket. Using TLS 1.0. | 2019-01-28 11:06:17 CTS FIX socket (2) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:06:17 CTS FIX: Sending the Logon message. | 2019-01-28 11:06:17 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:06:18 CTS FIX socket (2) | Socket gracefully closed by remote side. | 2019-01-28 11:06:18 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:06:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:06:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:06:18 CTS FIX socket (2) | Write in progress. Shutdown being delayed. | 2019-01-28 11:06:18 CTS T4 FIX | Disconnected. | 2019-01-28 11:06:18 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:06:18 CTS FIX socket (2) | Write has completed. Shutdown being performed. | 2019-01-28 11:06:18 CTS FIX socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:06:18 CTS FIX socket (2) | Closed. | 2019-01-28 11:06:18 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:08:18 CTS T4 FIX | Firm: PTP | 2019-01-28 11:08:18 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:08:18 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:08:18 CTS FIX: Sending the Logon message. | 2019-01-28 11:08:19 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:08:19 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:08:19 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:08:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:08:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:08:19 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:08:19 CTS T4 FIX | Disconnected. | 2019-01-28 11:08:19 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:08:19 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:08:19 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:08:19 CTS FIX socket (1) | Closed. | 2019-01-28 11:08:19 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:10:19 CTS T4 FIX | Firm: PTP | 2019-01-28 11:10:19 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:10:19 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:10:19 CTS FIX: Sending the Logon message. | 2019-01-28 11:10:20 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:10:20 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:10:20 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:10:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:10:20 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:10:20 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:10:20 CTS T4 FIX | Disconnected. | 2019-01-28 11:10:20 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:10:20 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:10:21 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:10:21 CTS FIX socket (1) | Closed. | 2019-01-28 11:10:21 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:12:20 CTS T4 FIX | Firm: PTP | 2019-01-28 11:12:20 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:12:24 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:12:24 CTS FIX: Sending the Logon message. | 2019-01-28 11:12:24 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:12:25 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:12:25 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:12:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:12:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:12:25 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:12:25 CTS T4 FIX | Disconnected. | 2019-01-28 11:12:25 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:12:25 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:12:25 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:12:25 CTS FIX socket (1) | Closed. | 2019-01-28 11:12:25 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:14:25 CTS T4 FIX | Firm: PTP | 2019-01-28 11:14:25 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:14:25 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:14:25 CTS FIX: Sending the Logon message. | 2019-01-28 11:14:25 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:14:26 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:14:26 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:14:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:14:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:14:26 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:14:26 CTS T4 FIX | Disconnected. | 2019-01-28 11:14:26 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:14:26 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:14:26 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:14:26 CTS FIX socket (1) | Closed. | 2019-01-28 11:14:26 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:16:26 CTS T4 FIX | Firm: PTP | 2019-01-28 11:16:26 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:16:26 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:16:26 CTS FIX: Sending the Logon message. | 2019-01-28 11:16:27 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:16:27 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:16:27 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:16:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:16:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:16:27 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:16:27 CTS T4 FIX | Disconnected. | 2019-01-28 11:16:27 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:16:27 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:16:27 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:16:27 CTS FIX socket (1) | Closed. | 2019-01-28 11:16:27 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:18:27 CTS T4 FIX | Firm: PTP | 2019-01-28 11:18:27 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:18:30 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:18:30 CTS FIX: Sending the Logon message. | 2019-01-28 11:18:30 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:18:31 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:18:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:18:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:18:31 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:18:31 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:18:31 CTS T4 FIX | Disconnected. | 2019-01-28 11:18:31 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:18:31 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:18:31 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:18:31 CTS FIX socket (1) | Closed. | 2019-01-28 11:18:31 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:20:31 CTS T4 FIX | Firm: PTP | 2019-01-28 11:20:31 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:20:31 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:20:31 CTS FIX: Sending the Logon message. | 2019-01-28 11:20:31 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:20:32 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:20:32 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:20:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:20:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:20:32 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:20:32 CTS T4 FIX | Disconnected. | 2019-01-28 11:20:32 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:20:32 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:20:32 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:20:32 CTS FIX socket (1) | Closed. | 2019-01-28 11:20:32 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:22:32 CTS T4 FIX | Firm: PTP | 2019-01-28 11:22:32 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:22:32 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:22:32 CTS FIX: Sending the Logon message. | 2019-01-28 11:22:33 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:22:33 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:22:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:22:33 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:22:33 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:22:33 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:22:33 CTS T4 FIX | Disconnected. | 2019-01-28 11:22:33 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:22:33 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:22:33 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:22:33 CTS FIX socket (1) | Closed. | 2019-01-28 11:22:33 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-28 11:24:33 CTS T4 FIX | Firm: PTP | 2019-01-28 11:24:33 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-28 11:24:33 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-28 11:24:33 CTS FIX: Sending the Logon message. | 2019-01-28 11:24:34 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-28 11:24:34 CTS FIX: Received a Logout message. Text = Too many failed login attempts: Your username has been locked out. Please contact your firm administrator to reset the user | 2019-01-28 11:24:34 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-01-28 11:24:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-28 11:24:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:24:34 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-28 11:24:34 CTS T4 FIX | Disconnected. | 2019-01-28 11:24:34 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-28 11:24:34 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-28 11:24:35 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-28 11:24:35 CTS FIX socket (1) | Closed. | 2019-01-28 11:24:35 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-29 00:28:47 CTS T4 FIX | Firm: PTP | 2019-01-29 00:28:47 Notice: Detected that the system has resumed from a low-power state. | 2019-01-29 00:28:47 Re-connecting to the Data/Trading service. | 2019-01-29 00:28:47 CTS FIX: DisconnectFIX called. | 2019-01-29 00:28:47 CTS T4 FIX | Disconnected. | 2019-01-29 00:28:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-29 00:28:47 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-29 00:28:50 CTS T4 FIX | Firm: PTP | 2019-01-29 00:28:50 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-29 00:28:52 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-29 00:28:52 CTS FIX: Sending the Logon message. | 2019-01-29 00:28:53 CTS T4 FIX | FIX version: 4.7.23.0 | 2019-01-29 00:28:53 CTS T4 FIX | Connected to data and trading server. | 2019-01-29 00:28:53 CTS T4 FIX | Starting real-time market data updates for: CLZ18. ID: 1 | 2019-01-29 00:28:53 Symbol Error - CLZ18 is unknown, unavailable, or improperly formatted. CTS T4 FIX | Invalid symbol format. Needs to be [contract].[market].[exchange] or [contract].[market].[C or P].OPT.[exchange] . Symbol: CLZ18 | 2019-01-29 00:28:53 CTS T4 FIX | Invalid symbol format. Needs to be [contract].[market].[exchange] or [contract].[market].[C or P].OPT.[exchange] . Symbol: CLZ18 | 2019-01-29 00:28:53 * CTS T4 FIX | Requesting security definition data for: CLZ18. ID: 1 | 2019-01-29 00:28:53 CTS T4 FIX | Received Account List collateral report. | 2019-01-29 00:28:53 CTS T4 FIX | Subscribing to account: S1J* | 2019-01-29 00:28:53 Supported exchange: CME_NGOp (SIM:NYMEX NatGas Options) | 2019-01-29 00:28:53 Supported exchange: CME_CO (SIM:COMEX Futures) | 2019-01-29 00:28:53 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2019-01-29 00:28:53 Supported exchange: CME_CL (SIM:NYMEX CrudeOil Futures) | 2019-01-29 00:28:53 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2019-01-29 00:28:53 Supported exchange: CME_FRE (SIM:NYMEX Freight Futures) | 2019-01-29 00:28:53 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2019-01-29 00:28:53 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2019-01-29 00:28:53 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2019-01-29 00:28:53 Supported exchange: CME_NG (SIM:NYMEX NatGas Futures) | 2019-01-29 00:28:53 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2019-01-29 00:28:53 Supported exchange: CME_KOp (SIM:KCBT Options) | 2019-01-29 00:28:53 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2019-01-29 00:28:53 Supported exchange: CME_CLOp (SIM:NYMEX CrudeOil Options) | 2019-01-29 00:28:53 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2019-01-29 00:28:53 Supported exchange: CME_COAL (SIM:NYMEX Coal Futures) | 2019-01-29 00:28:53 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2019-01-29 00:28:53 Supported exchange: CME_K (SIM:KCBT Futures) | 2019-01-29 00:28:53 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2019-01-29 00:28:53 Supported exchange: CME_COALOp (SIM:NYMEX Coal Options) | 2019-01-29 00:28:53 Supported exchange: CME_ELEOp (SIM:NYMEX Power Options) | 2019-01-29 00:28:53 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2019-01-29 00:28:53 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2019-01-29 00:28:53 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2019-01-29 00:28:53 CTS T4 FIX | Starting real-time market data updates for: CL.20190100.CME_NY. ID: 2 | 2019-01-29 00:28:53 CTS T4 FIX | Requesting security definition data for: CL.20190100.CME_NY. ID: 2 | 2019-01-29 00:28:53 Intraday data recording state for symbol CL.20190100.CME_NY is set to download 'Pending'. | 2019-01-29 00:28:53 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2019-01-29 00:28:53 Supported exchange: CME_ELE (SIM:NYMEX Power Futures) | 2019-01-29 00:28:53 Supported exchange: CME_REF (SIM:NYMEX Refined Products Futures) | 2019-01-29 00:28:53 Supported exchange: CME_FREOp (SIM:NYMEX Freight Options) | 2019-01-29 00:28:53 Supported exchange: CME_PETOp (SIM:NYMEX NGL/Petrochemicals Options) | 2019-01-29 00:28:53 Supported exchange: CME_REFOp (SIM:NYMEX Refined Products Options) | 2019-01-29 00:28:53 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2019-01-29 00:28:53 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2019-01-29 00:28:53 Supported exchange: CME_COOp (SIM:COMEX Options) | 2019-01-29 00:28:53 Delaying start of download for CL.20190100.CME_NY | 2019-01-29 00:28:53 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2019-01-29 00:28:54 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190100.CME_NY | 2019-01-29 00:28:55 Symbol Error - CL.20190100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-29 00:28:55 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-29 00:28:55 HD Request # 4 | Downloading Intraday chart data for CL.20190100.CME_NY to the file CL.20190100.CME_NY.scid. Service: nymex | 2019-01-29 00:28:56 HD Request # 4 | Download start date-time: 2018-12-19 13:29:41.000 | 2019-01-29 00:28:56 HD Request # 4 | Using server: ds1.sierracharts.com port 10150 | 2019-01-29 00:28:56 Socket (2) | Creating socket. | 2019-01-29 00:28:56 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-01-29 00:28:56 HD Request # 4 | Setting DTC encoding to Binary VLS | 2019-01-29 00:28:56 HD Request # 4 | Sending historical data logon request message. | 2019-01-29 00:28:56 HD Request # 4 | Requesting Intraday data. Start date-time: 2018-12-19 13:29:41. Record interval: 1. Symbol: CLF19 | 2019-01-29 00:28:56 HD Request # 4 | Decompressing data. | 2019-01-29 00:28:57 HD Request # 4 | Receiving Intraday data for CL.20190100.CME_NY starting at 2018-12-19 13:29:41 | 2019-01-29 00:28:57 HD Request # 4 | Timestamp of first Intraday data file record written: 2018-12-19 13:29:41 | 2019-01-29 00:28:57 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 00:28:57 Historical data download thread signaled to stop. | 2019-01-29 00:28:57 HD Request # 4 | Received 1 record from 2018-12-19 13:29:41 to 2018-12-19 13:29:41 (0.0 seconds) and wrote 1 record for CL.20190100.CME_NY | 2019-01-29 00:28:57 HD Request # 4 | Completion time: 0s | 2019-01-29 00:28:57 HD Request # 4 | Intraday data download complete for CL.20190100.CME_NY. Unique request ID: 3 | 2019-01-29 00:28:57 Removed historical data download ID 3 | 2019-01-29 00:28:57 Real-time Intraday chart data file updates started for CL.20190100.CME_NY | 2019-01-29 00:28:57 Opened cached Intraday file: C:\SierraChart\Data\CL.20190100.CME_NY.scid | 2019-01-29 00:28:57 Intraday chart data file opened for CL.20190100.CME_NY | 2019-01-29 00:28:57 Socket (2) | Socket gracefully closed by remote side. | 2019-01-29 00:28:57 Socket (2) | Closed. | 2019-01-29 00:28:57 CTS T4 FIX | Requesting Open Orders for account: S1J*. Request ID: 2292951 | 2019-01-29 00:28:58 Requesting market depth updates for: CL.20190100.CME_NY if supported. | 2019-01-29 00:28:58 CTS T4 FIX | No open orders for account S1Jan29157920 | 2019-01-29 00:28:58 CTS T4 FIX | Requesting historical Fills for account: S1J*. Request ID: 2292952 | 2019-01-29 00:29:08 CTS T4 FIX | Received Account List collateral report. | 2019-01-29 00:29:08 CTS T4 FIX | Server provided no historical order fills for account EBEC0534-D38A-4FDD-8BD4-C9FD3581A6C1 | 2019-01-29 00:29:08 CLZ18 5 Min #1 | Reloading chart. | 2019-01-29 00:49:04 CLZ18 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLZ18.scid | 2019-01-29 00:49:04 CTS T4 FIX | Using primary service for historical data for CLZ18 | 2019-01-29 00:49:05 Intraday data recording state for symbol CLZ18 is set to download 'Pending'. | 2019-01-29 00:49:05 HD Request # 5 | Downloading Intraday chart data for CLZ18 to the file CLZ18.scid. Service: cts | 2019-01-29 00:49:05 Compressing file: C:\SierraChart\Data\CLZ18.scid. This may take a while. | 2019-01-29 00:49:05 HD Request # 5 | Download start date-time: 2018-07-27 01:49:04.000 | 2019-01-29 00:49:05 CTS T4 FIX | Invalid symbol format. Needs to be [contract].[market].[exchange] or [contract].[market].[C or P].OPT.[exchange] . Symbol: CLZ18 | 2019-01-29 00:49:05 * HD Request # 5 | Error downloading historical Intraday data for CLZ18. CTS T4 FIX | Invalid symbol format. Needs to be [contract].[market].[exchange] or [contract].[market].[C or P].OPT.[exchange] . Symbol: CLZ18 | 2019-01-29 00:49:05 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLZ18 | 2019-01-29 00:49:05 HD Request # 5 | Completion time: 0s | 2019-01-29 00:49:05 HD Request # 5 | Intraday data download complete for CLZ18. Unique request ID: 4 | 2019-01-29 00:49:05 Removed historical data download ID 4 | 2019-01-29 00:49:05 Real-time Intraday chart data file updates started for CLZ18 | 2019-01-29 00:49:05 Opened cached Intraday file: C:\SierraChart\Data\CLZ18.scid | 2019-01-29 00:49:05 Intraday chart data file opened for CLZ18 | 2019-01-29 00:49:05 Unsubscribed from market depth data for CL.20190100.CME_NY | 2019-01-29 00:53:58 CLZ18 Daily #1 | Reloading chart. | 2019-01-29 00:54:13 CLZ18 Daily #1 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data | 2019-01-29 00:54:13 HD Request # 6 | Downloading Historical Daily chart data for CLZ18. Starting date: 2018-11-16. Service: cts | 2019-01-29 00:54:13 Historical data download counter reset. | 2019-01-29 00:54:13 HD Request # 6 | Requesting historical Daily data for CLZ18 starting at 2018-11-15 | 2019-01-29 00:54:13 HTTPS historicaldata.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-29 00:54:13 HTTPS historicaldata.sierrachart.com:443 (2) | Connecting to IP: 88.99.0.216. | 2019-01-29 00:54:13 HD Request # 6 | Receiving historical Daily data for CLZ18 starting at 2018-11-16 | 2019-01-29 00:54:14 HD Request # 6 | Writing historical Daily data to the file CLZ18.dly | 2019-01-29 00:54:14 HD Request # 6 | Received 3 records from 2018-11-16 00:00:00 to 2018-11-19 00:00:00 (4.0 days) and wrote 2 records for CLZ18 | 2019-01-29 00:54:14 HD Request # 6 | Completion time: 0s | 2019-01-29 00:54:14 HD Request # 6 | Daily data download complete for CLZ18. Unique request ID: 5 | 2019-01-29 00:54:14 Removed historical data download ID 5 | 2019-01-29 00:54:14 HTTPS historicaldata.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 00:54:14 CLZ18 Daily #1 | Reloading chart. | 2019-01-29 00:54:14 HTTPS historicaldata.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-29 00:54:14 HTTPS historicaldata.sierrachart.com:443 (2) | Closed. | 2019-01-29 00:54:14 CLZ18 Weekly #1 | Reloading chart. | 2019-01-29 00:54:15 CLZ18 1 Min #1 | Reloading chart. | 2019-01-29 00:54:15 CLZ18 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLZ18.scid | 2019-01-29 00:54:15 CLZ18 5 Min #1 | Reloading chart. | 2019-01-29 00:54:20 CLZ18 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLZ18.scid | 2019-01-29 00:54:20 CLZ18 10 Min #1 | Reloading chart. | 2019-01-29 00:54:20 CLZ18 10 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLZ18.scid | 2019-01-29 00:54:20 CLZ18 30 Min #1 | Reloading chart. | 2019-01-29 00:54:21 CLZ18 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLZ18.scid | 2019-01-29 00:54:21 CLZ18 60 Min #1 | Reloading chart. | 2019-01-29 00:54:21 CLZ18 60 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLZ18.scid | 2019-01-29 00:54:21 CLZ18 Daily #1 | Reloading chart. | 2019-01-29 00:54:23 File >> Disconnect selected. | 2019-01-29 00:57:35 CTS FIX: DisconnectFIX called. | 2019-01-29 00:57:35 CTS FIX: Sending a Logout message. | 2019-01-29 00:57:35 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-29 00:57:35 CTS T4 FIX | Disconnected. | 2019-01-29 00:57:35 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-29 00:57:35 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-29 00:57:35 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-29 00:57:35 CTS FIX socket (1) | Closed. | 2019-01-29 00:57:35 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-29 00:57:37 CTS T4 FIX | Firm: PTP | 2019-01-29 00:57:37 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-29 00:57:38 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-29 00:57:38 CTS FIX: Sending the Logon message. | 2019-01-29 00:57:38 CTS T4 FIX | FIX version: 4.7.23.0 | 2019-01-29 00:57:39 CTS T4 FIX | Connected to data and trading server. | 2019-01-29 00:57:39 CTS T4 FIX | Starting real-time market data updates for: CLZ18. ID: 1 | 2019-01-29 00:57:39 Symbol Error - CLZ18 is unknown, unavailable, or improperly formatted. CTS T4 FIX | Invalid symbol format. Needs to be [contract].[market].[exchange] or [contract].[market].[C or P].OPT.[exchange] . Symbol: CLZ18 | 2019-01-29 00:57:39 CTS T4 FIX | Invalid symbol format. Needs to be [contract].[market].[exchange] or [contract].[market].[C or P].OPT.[exchange] . Symbol: CLZ18 | 2019-01-29 00:57:39 * CTS T4 FIX | Requesting security definition data for: CLZ18. ID: 1 | 2019-01-29 00:57:39 CTS T4 FIX | Received Account List collateral report. | 2019-01-29 00:57:39 CTS T4 FIX | Subscribing to account: S1J* | 2019-01-29 00:57:39 Supported exchange: CME_NGOp (SIM:NYMEX NatGas Options) | 2019-01-29 00:57:39 Supported exchange: CME_CO (SIM:COMEX Futures) | 2019-01-29 00:57:39 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2019-01-29 00:57:39 Supported exchange: CME_CL (SIM:NYMEX CrudeOil Futures) | 2019-01-29 00:57:39 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2019-01-29 00:57:39 Supported exchange: CME_FRE (SIM:NYMEX Freight Futures) | 2019-01-29 00:57:39 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2019-01-29 00:57:39 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2019-01-29 00:57:39 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2019-01-29 00:57:39 Supported exchange: CME_NG (SIM:NYMEX NatGas Futures) | 2019-01-29 00:57:39 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2019-01-29 00:57:39 Supported exchange: CME_KOp (SIM:KCBT Options) | 2019-01-29 00:57:39 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2019-01-29 00:57:39 Supported exchange: CME_CLOp (SIM:NYMEX CrudeOil Options) | 2019-01-29 00:57:39 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2019-01-29 00:57:39 Supported exchange: CME_COAL (SIM:NYMEX Coal Futures) | 2019-01-29 00:57:39 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2019-01-29 00:57:39 Supported exchange: CME_K (SIM:KCBT Futures) | 2019-01-29 00:57:39 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2019-01-29 00:57:39 Supported exchange: CME_COALOp (SIM:NYMEX Coal Options) | 2019-01-29 00:57:39 Supported exchange: CME_ELEOp (SIM:NYMEX Power Options) | 2019-01-29 00:57:39 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2019-01-29 00:57:39 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2019-01-29 00:57:39 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2019-01-29 00:57:39 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2019-01-29 00:57:39 Supported exchange: CME_ELE (SIM:NYMEX Power Futures) | 2019-01-29 00:57:39 Supported exchange: CME_REF (SIM:NYMEX Refined Products Futures) | 2019-01-29 00:57:39 Supported exchange: CME_FREOp (SIM:NYMEX Freight Options) | 2019-01-29 00:57:39 Supported exchange: CME_PETOp (SIM:NYMEX NGL/Petrochemicals Options) | 2019-01-29 00:57:39 Supported exchange: CME_REFOp (SIM:NYMEX Refined Products Options) | 2019-01-29 00:57:39 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2019-01-29 00:57:39 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2019-01-29 00:57:39 Supported exchange: CME_COOp (SIM:COMEX Options) | 2019-01-29 00:57:39 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2019-01-29 00:57:42 CTS T4 FIX | Requesting Open Orders for account: S1J*. Request ID: 2292956 | 2019-01-29 00:57:44 CTS T4 FIX | No open orders for account S1Jan29157920 | 2019-01-29 00:57:44 HTTPS www.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-29 00:57:54 HTTPS www.sierrachart.com:443 (2) | Connecting to IP: 46.4.97.203. | 2019-01-29 00:57:54 CTS T4 FIX | Requesting historical Fills for account: S1J*. Request ID: 2292957 | 2019-01-29 00:57:54 HTTPS www.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 00:57:54 CTS T4 FIX | Received Account List collateral report. | 2019-01-29 00:57:54 CTS T4 FIX | Server provided no historical order fills for account EBEC0534-D38A-4FDD-8BD4-C9FD3581A6C1 | 2019-01-29 00:57:54 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-29 00:57:54 HTTPS www.sierrachart.com:443 (2) | Closed. | 2019-01-29 00:57:54 CL.20190200.CME_NY Daily #2 | Reloading chart. | 2019-01-29 00:58:14 CL.20190200.CME_NY Daily #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CL.20190200.CME_NY.dly | 2019-01-29 00:58:14 CTS T4 FIX | Starting real-time market data updates for: CL.20190200.CME_NY. ID: 2 | 2019-01-29 00:58:15 CTS T4 FIX | Requesting security definition data for: CL.20190200.CME_NY. ID: 2 | 2019-01-29 00:58:15 HD Request # 7 | Downloading Historical Daily chart data for CL.20190200.CME_NY. Starting date: 1969-01-28. Service: cts | 2019-01-29 00:58:15 HD Request # 7 | Requesting historical Daily data for CLG19 starting at 1969-01-27 | 2019-01-29 00:58:15 HTTPS historicaldata.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-29 00:58:15 HTTPS historicaldata.sierrachart.com:443 (2) | Connecting to IP: 88.99.0.216. | 2019-01-29 00:58:15 HD Request # 7 | Receiving historical Daily data for CL.20190200.CME_NY starting at 2013-11-20 | 2019-01-29 00:58:16 HD Request # 7 | Writing historical Daily data to the file CL.20190200.CME_NY.dly | 2019-01-29 00:58:16 HD Request # 7 | Received 1301 records from 2013-11-20 00:00:00 to 2019-01-22 00:00:00 (5.2years) and wrote 1301 records for CL.20190200.CME_NY | 2019-01-29 00:58:16 HD Request # 7 | Completion time: 1s | 2019-01-29 00:58:16 HD Request # 7 | Daily data download complete for CL.20190200.CME_NY. Unique request ID: 6 | 2019-01-29 00:58:16 Removed historical data download ID 6 | 2019-01-29 00:58:16 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190200.CME_NY | 2019-01-29 00:58:16 HTTPS historicaldata.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 00:58:16 HTTPS historicaldata.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-29 00:58:16 HTTPS historicaldata.sierrachart.com:443 (2) | Closed. | 2019-01-29 00:58:16 CL.20190200.CME_NY Daily #2 | Reloading chart. | 2019-01-29 00:58:16 Symbol Error - CL.20190200.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-29 00:58:16 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-29 00:58:16 CL.20190200.CME_NY 1 Min #1 | Reloading chart. | 2019-01-29 00:58:27 CL.20190200.CME_NY 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CL.20190200.CME_NY.scid | 2019-01-29 00:58:27 Intraday data recording state for symbol CL.20190200.CME_NY is set to download 'Pending'. | 2019-01-29 00:58:28 HD Request # 8 | Downloading Intraday chart data for CL.20190200.CME_NY to the file CL.20190200.CME_NY.scid. Service: nymex | 2019-01-29 00:58:28 Compressing file: C:\SierraChart\Data\CL.20190200.CME_NY.scid. This may take a while. | 2019-01-29 00:58:28 HD Request # 8 | Download start date-time: 2018-07-27 01:58:27.000 | 2019-01-29 00:58:28 HD Request # 8 | Using server: ds7.sierracharts.com port 10149 | 2019-01-29 00:58:28 Socket (2) | Creating socket. | 2019-01-29 00:58:28 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-01-29 00:58:28 HD Request # 8 | Setting DTC encoding to Binary VLS | 2019-01-29 00:58:28 HD Request # 8 | Sending historical data logon request message. | 2019-01-29 00:58:28 HD Request # 8 | Requesting Intraday data. Start date-time: 2018-07-27 01:58:27. Record interval: 1. Symbol: CLG19 | 2019-01-29 00:58:28 HD Request # 8 | Decompressing data. | 2019-01-29 00:58:29 CL.20190200.CME_NY #3 | Reloading chart. | 2019-01-29 00:58:29 Requesting market depth updates for: CL.20190200.CME_NY if supported. | 2019-01-29 00:58:29 HD Request # 8 | Receiving Intraday data for CL.20190200.CME_NY starting at 2018-07-27 02:52:36 | 2019-01-29 00:58:29 HD Request # 8 | Timestamp of first Intraday data file record written: 2018-07-27 02:52:36 | 2019-01-29 00:58:29 HTTPS www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2019-01-29 00:58:45 HTTPS www.sierrachart.com:443 (3) | Connecting to IP: 46.4.97.203. | 2019-01-29 00:58:45 HTTPS www.sierrachart.com:443 (3) | Shutdown started. Waiting for graceful close. | 2019-01-29 00:58:46 HTTPS www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2019-01-29 00:58:46 HTTPS www.sierrachart.com:443 (3) | Closed. | 2019-01-29 00:58:46 Historical data download thread signaled to stop. | 2019-01-29 00:58:50 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 00:58:50 HD Request # 8 | Received 1360031 records from 2018-07-27 02:52:36 to 2019-01-22 13:29:59 (179.5 days) and wrote 1360031 records for CL.20190200.CME_NY | 2019-01-29 00:58:50 HD Request # 8 | Completion time: 23s | 2019-01-29 00:58:50 HD Request # 8 | Intraday data download complete for CL.20190200.CME_NY. Unique request ID: 7 | 2019-01-29 00:58:50 Removed historical data download ID 7 | 2019-01-29 00:58:50 Real-time Intraday chart data file updates started for CL.20190200.CME_NY | 2019-01-29 00:58:50 Opened cached Intraday file: C:\SierraChart\Data\CL.20190200.CME_NY.scid | 2019-01-29 00:58:50 Intraday chart data file opened for CL.20190200.CME_NY | 2019-01-29 00:58:50 Socket (2) | Socket gracefully closed by remote side. | 2019-01-29 00:58:51 Socket (2) | Closed. | 2019-01-29 00:58:51 CTS T4 FIX | Querying for spread/strategy symbols for CL.######00.CME_NY. | 2019-01-29 00:59:02 CTS T4 FIX | Received 1528 security definitions for symbols request. | 2019-01-29 00:59:08 CTS FIX socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-01-29 15:29:03 * CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-29 15:29:03 Notice: Detected that the system has resumed from a low-power state. | 2019-01-29 15:29:03 Re-connecting to the Data/Trading service. | 2019-01-29 15:29:03 CTS FIX: DisconnectFIX called. | 2019-01-29 15:29:03 CTS FIX: Sending a Logout message. | 2019-01-29 15:29:03 CTS T4 FIX | Disconnected. | 2019-01-29 15:29:03 CTS FIX socket (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2019-01-29 15:29:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-29 15:29:03 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-29 15:29:03 CTS FIX socket (1) | Closed. | 2019-01-29 15:29:03 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-29 15:29:06 CTS T4 FIX | Firm: PTP | 2019-01-29 15:29:06 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-29 15:29:07 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-29 15:29:07 CTS FIX: Sending the Logon message. | 2019-01-29 15:29:07 CTS T4 FIX | FIX version: 4.7.23.0 | 2019-01-29 15:29:08 CTS T4 FIX | Connected to data and trading server. | 2019-01-29 15:29:08 CTS T4 FIX | Starting real-time market data updates for: CL.20190200.CME_NY. ID: 1 | 2019-01-29 15:29:08 CTS T4 FIX | Requesting security definition data for: CL.20190200.CME_NY. ID: 1 | 2019-01-29 15:29:08 Intraday data recording state for symbol CL.20190200.CME_NY is set to download 'Pending'. | 2019-01-29 15:29:08 Delaying start of download for CL.20190200.CME_NY | 2019-01-29 15:29:08 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190200.CME_NY | 2019-01-29 15:29:08 CTS T4 FIX | Received Account List collateral report. | 2019-01-29 15:29:08 CTS T4 FIX | Subscribing to account: S1J* | 2019-01-29 15:29:08 Supported exchange: CME_NGOp (SIM:NYMEX NatGas Options) | 2019-01-29 15:29:08 Supported exchange: CME_CO (SIM:COMEX Futures) | 2019-01-29 15:29:08 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2019-01-29 15:29:08 Supported exchange: CME_CL (SIM:NYMEX CrudeOil Futures) | 2019-01-29 15:29:08 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2019-01-29 15:29:08 Supported exchange: CME_FRE (SIM:NYMEX Freight Futures) | 2019-01-29 15:29:08 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2019-01-29 15:29:08 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2019-01-29 15:29:08 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2019-01-29 15:29:08 Supported exchange: CME_NG (SIM:NYMEX NatGas Futures) | 2019-01-29 15:29:08 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2019-01-29 15:29:08 Supported exchange: CME_KOp (SIM:KCBT Options) | 2019-01-29 15:29:08 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2019-01-29 15:29:08 Supported exchange: CME_CLOp (SIM:NYMEX CrudeOil Options) | 2019-01-29 15:29:08 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2019-01-29 15:29:08 Supported exchange: CME_COAL (SIM:NYMEX Coal Futures) | 2019-01-29 15:29:08 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2019-01-29 15:29:08 Supported exchange: CME_K (SIM:KCBT Futures) | 2019-01-29 15:29:08 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2019-01-29 15:29:08 Supported exchange: CME_COALOp (SIM:NYMEX Coal Options) | 2019-01-29 15:29:08 Supported exchange: CME_ELEOp (SIM:NYMEX Power Options) | 2019-01-29 15:29:08 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2019-01-29 15:29:08 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2019-01-29 15:29:08 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2019-01-29 15:29:08 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2019-01-29 15:29:08 Supported exchange: CME_ELE (SIM:NYMEX Power Futures) | 2019-01-29 15:29:08 Supported exchange: CME_REF (SIM:NYMEX Refined Products Futures) | 2019-01-29 15:29:08 Supported exchange: CME_FREOp (SIM:NYMEX Freight Options) | 2019-01-29 15:29:08 Supported exchange: CME_PETOp (SIM:NYMEX NGL/Petrochemicals Options) | 2019-01-29 15:29:08 Supported exchange: CME_REFOp (SIM:NYMEX Refined Products Options) | 2019-01-29 15:29:08 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2019-01-29 15:29:08 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2019-01-29 15:29:08 Supported exchange: CME_COOp (SIM:COMEX Options) | 2019-01-29 15:29:08 Symbol Error - CL.20190200.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-29 15:29:08 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-29 15:29:08 HD Request # 9 | Downloading Intraday chart data for CL.20190200.CME_NY to the file CL.20190200.CME_NY.scid. Service: nymex | 2019-01-29 15:29:09 HD Request # 9 | Download start date-time: 2019-01-22 13:29:59.000 | 2019-01-29 15:29:09 HD Request # 9 | Using server: ds1.sierracharts.com port 10150 | 2019-01-29 15:29:09 Socket (2) | Creating socket. | 2019-01-29 15:29:09 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-01-29 15:29:09 HD Request # 9 | Setting DTC encoding to Binary VLS | 2019-01-29 15:29:09 HD Request # 9 | Sending historical data logon request message. | 2019-01-29 15:29:09 HD Request # 9 | Requesting Intraday data. Start date-time: 2019-01-22 13:29:59. Record interval: 1. Symbol: CLG19 | 2019-01-29 15:29:09 HD Request # 9 | Decompressing data. | 2019-01-29 15:29:10 HD Request # 9 | Receiving Intraday data for CL.20190200.CME_NY starting at 2019-01-22 13:29:59 | 2019-01-29 15:29:10 HD Request # 9 | Timestamp of first Intraday data file record written: 2019-01-22 13:29:59 | 2019-01-29 15:29:10 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 15:29:10 Historical data download thread signaled to stop. | 2019-01-29 15:29:10 HD Request # 9 | Received 1 record from 2019-01-22 13:29:59 to 2019-01-22 13:29:59 (0.0 seconds) and wrote 1 record for CL.20190200.CME_NY | 2019-01-29 15:29:10 HD Request # 9 | Completion time: 0s | 2019-01-29 15:29:10 HD Request # 9 | Intraday data download complete for CL.20190200.CME_NY. Unique request ID: 8 | 2019-01-29 15:29:10 Removed historical data download ID 8 | 2019-01-29 15:29:10 Real-time Intraday chart data file updates started for CL.20190200.CME_NY | 2019-01-29 15:29:10 Opened cached Intraday file: C:\SierraChart\Data\CL.20190200.CME_NY.scid | 2019-01-29 15:29:10 Intraday chart data file opened for CL.20190200.CME_NY | 2019-01-29 15:29:10 Socket (2) | Socket gracefully closed by remote side. | 2019-01-29 15:29:10 Socket (2) | Closed. | 2019-01-29 15:29:10 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2019-01-29 15:29:11 CTS T4 FIX | Requesting Open Orders for account: S1J*. Request ID: 2292964 | 2019-01-29 15:29:13 Requesting market depth updates for: CL.20190200.CME_NY if supported. | 2019-01-29 15:29:13 CTS T4 FIX | No open orders for account S1Jan29157920 | 2019-01-29 15:29:13 CTS T4 FIX | Requesting historical Fills for account: S1J*. Request ID: 2292965 | 2019-01-29 15:29:23 CTS T4 FIX | Received Account List collateral report. | 2019-01-29 15:29:23 CTS T4 FIX | Server provided no historical order fills for account EBEC0534-D38A-4FDD-8BD4-C9FD3581A6C1 | 2019-01-29 15:29:23 CL.20190100.CME_NY 1 Min #4 | Reloading chart. | 2019-01-29 15:30:32 CTS T4 FIX | Starting real-time market data updates for: CL.20190100.CME_NY. ID: 2 | 2019-01-29 15:30:32 CTS T4 FIX | Requesting security definition data for: CL.20190100.CME_NY. ID: 2 | 2019-01-29 15:30:32 Intraday data recording state for symbol CL.20190100.CME_NY is set to download 'Pending'. | 2019-01-29 15:30:32 Delaying start of download for CL.20190100.CME_NY | 2019-01-29 15:30:32 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190100.CME_NY | 2019-01-29 15:30:33 Symbol Error - CL.20190100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-29 15:30:34 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-29 15:30:34 HD Request # 10 | Downloading Intraday chart data for CL.20190100.CME_NY to the file CL.20190100.CME_NY.scid. Service: nymex | 2019-01-29 15:30:35 HD Request # 10 | Download start date-time: 2018-12-19 13:29:41.000 | 2019-01-29 15:30:35 HD Request # 10 | Using server: ds7.sierracharts.com port 10149 | 2019-01-29 15:30:35 Socket (2) | Creating socket. | 2019-01-29 15:30:35 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-01-29 15:30:35 HD Request # 10 | Setting DTC encoding to Binary VLS | 2019-01-29 15:30:35 HD Request # 10 | Sending historical data logon request message. | 2019-01-29 15:30:35 HD Request # 10 | Requesting Intraday data. Start date-time: 2018-12-19 13:29:41. Record interval: 1. Symbol: CLF19 | 2019-01-29 15:30:35 HD Request # 10 | Decompressing data. | 2019-01-29 15:30:35 HD Request # 10 | Receiving Intraday data for CL.20190100.CME_NY starting at 2018-12-19 13:29:41 | 2019-01-29 15:30:35 HD Request # 10 | Timestamp of first Intraday data file record written: 2018-12-19 13:29:41 | 2019-01-29 15:30:35 Historical data download thread signaled to stop. | 2019-01-29 15:30:35 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 15:30:35 HD Request # 10 | Received 1 record from 2018-12-19 13:29:41 to 2018-12-19 13:29:41 (0.0 seconds) and wrote 1 record for CL.20190100.CME_NY | 2019-01-29 15:30:35 HD Request # 10 | Completion time: 0s | 2019-01-29 15:30:35 HD Request # 10 | Intraday data download complete for CL.20190100.CME_NY. Unique request ID: 9 | 2019-01-29 15:30:35 Removed historical data download ID 9 | 2019-01-29 15:30:35 Real-time Intraday chart data file updates started for CL.20190100.CME_NY | 2019-01-29 15:30:35 Opened cached Intraday file: C:\SierraChart\Data\CL.20190100.CME_NY.scid | 2019-01-29 15:30:35 Intraday chart data file opened for CL.20190100.CME_NY | 2019-01-29 15:30:35 Socket (2) | Socket gracefully closed by remote side. | 2019-01-29 15:30:36 Socket (2) | Closed. | 2019-01-29 15:30:36 CL.20190200.CME_NY 1 Min #4 | Reloading chart. | 2019-01-29 15:31:10 CL.20190200.CME_NY 5 Min #2 | Reloading chart. | 2019-01-29 15:31:42 CL.20190200.CME_NY 1 Min #2 | Reloading chart. | 2019-01-29 15:31:44 CL.20190200.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:31:45 CL.20190200.CME_NY Daily #2 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data | 2019-01-29 15:31:45 HD Request # 11 | Downloading Historical Daily chart data for CL.20190200.CME_NY. Starting date: 2019-01-18. Service: cts | 2019-01-29 15:31:46 HD Request # 11 | Requesting historical Daily data for CLG19 starting at 2019-01-17 | 2019-01-29 15:31:46 HTTPS historicaldata.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-29 15:31:46 HTTPS historicaldata.sierrachart.com:443 (2) | Connecting to IP: 88.99.0.216. | 2019-01-29 15:31:46 HD Request # 11 | Receiving historical Daily data for CL.20190200.CME_NY starting at 2019-01-18 | 2019-01-29 15:31:47 HD Request # 11 | Writing historical Daily data to the file CL.20190200.CME_NY.dly | 2019-01-29 15:31:47 HD Request # 11 | Received 3 records from 2019-01-18 00:00:00 to 2019-01-22 00:00:00 (5.0 days) and wrote 2 records for CL.20190200.CME_NY | 2019-01-29 15:31:47 HD Request # 11 | Completion time: 0s | 2019-01-29 15:31:47 HD Request # 11 | Daily data download complete for CL.20190200.CME_NY. Unique request ID: 10 | 2019-01-29 15:31:47 Removed historical data download ID 10 | 2019-01-29 15:31:47 CL.20190200.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:31:47 HTTPS historicaldata.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 15:31:47 HTTPS historicaldata.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-29 15:31:47 HTTPS historicaldata.sierrachart.com:443 (2) | Closed. | 2019-01-29 15:31:47 CL.20190200.CME_NY 5 Min #2 | Reloading chart. | 2019-01-29 15:31:48 CL.20190200.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:31:50 CL.20190200.CME_NY 5 Min #2 | Reloading chart. | 2019-01-29 15:45:44 CL.20190100.CME_NY 5 Min #2 | Reloading chart. | 2019-01-29 15:46:02 CL.20190100.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:46:05 CL.20190100.CME_NY Daily #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CL.20190100.CME_NY.dly | 2019-01-29 15:46:05 HD Request # 12 | Downloading Historical Daily chart data for CL.20190100.CME_NY. Starting date: 1969-01-29. Service: cts | 2019-01-29 15:46:06 HD Request # 12 | Requesting historical Daily data for CLF19 starting at 1969-01-28 | 2019-01-29 15:46:06 HTTPS historicaldata.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2019-01-29 15:46:06 HTTPS historicaldata.sierrachart.com:443 (3) | Connecting to IP: 88.99.0.216. | 2019-01-29 15:46:06 HD Request # 12 | Receiving historical Daily data for CL.20190100.CME_NY starting at 2013-11-20 | 2019-01-29 15:46:07 HD Request # 12 | Writing historical Daily data to the file CL.20190100.CME_NY.dly | 2019-01-29 15:46:07 HD Request # 12 | Received 1280 records from 2013-11-20 00:00:00 to 2018-12-19 00:00:00 (5.1years) and wrote 1280 records for CL.20190100.CME_NY | 2019-01-29 15:46:07 HD Request # 12 | Completion time: 1s | 2019-01-29 15:46:07 HD Request # 12 | Daily data download complete for CL.20190100.CME_NY. Unique request ID: 11 | 2019-01-29 15:46:07 Removed historical data download ID 11 | 2019-01-29 15:46:07 HTTPS historicaldata.sierrachart.com:443 (3) | Shutdown started. Waiting for graceful close. | 2019-01-29 15:46:07 CL.20190100.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:46:07 HTTPS historicaldata.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2019-01-29 15:46:07 HTTPS historicaldata.sierrachart.com:443 (3) | Closed. | 2019-01-29 15:46:07 CL.20190200.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:48:44 CL.20190300.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:49:25 CL.20190300.CME_NY Daily #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CL.20190300.CME_NY.dly | 2019-01-29 15:49:25 CTS T4 FIX | Starting real-time market data updates for: CL.20190300.CME_NY. ID: 3 | 2019-01-29 15:49:26 CTS T4 FIX | Requesting security definition data for: CL.20190300.CME_NY. ID: 3 | 2019-01-29 15:49:26 HD Request # 13 | Downloading Historical Daily chart data for CL.20190300.CME_NY. Starting date: 1969-01-29. Service: cts | 2019-01-29 15:49:26 HD Request # 13 | Requesting historical Daily data for CLH19 starting at 1969-01-28 | 2019-01-29 15:49:26 HTTPS historicaldata.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-29 15:49:26 HTTPS historicaldata.sierrachart.com:443 (2) | Connecting to IP: 88.99.0.216. | 2019-01-29 15:49:26 HD Request # 13 | Receiving historical Daily data for CL.20190300.CME_NY starting at 2013-11-20 | 2019-01-29 15:49:27 HD Request # 13 | Writing historical Daily data to the file CL.20190300.CME_NY.dly | 2019-01-29 15:49:27 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190300.CME_NY | 2019-01-29 15:49:27 HD Request # 13 | Received 1306 records from 2013-11-20 00:00:00 to 2019-01-29 00:00:00 (5.2years) and wrote 1306 records for CL.20190300.CME_NY | 2019-01-29 15:49:27 HD Request # 13 | Completion time: 2s | 2019-01-29 15:49:27 HD Request # 13 | Daily data download complete for CL.20190300.CME_NY. Unique request ID: 12 | 2019-01-29 15:49:27 Removed historical data download ID 12 | 2019-01-29 15:49:27 CTS T4 FIX | Received matching security definition for symbol CL.20190300.CME_NY. Subscribing to data. | 2019-01-29 15:49:27 CTS T4 FIX | Subscribing to symbol CL.20190300.CME_NY. Market: XCME_NY CL (H19) | 2019-01-29 15:49:27 Contract-Exchange: CL-CME_NY. Description: SIM:Crude Oil Mar19. Tick Size: 1.000000. Value Format: 0. Price Multiplier: 1.000000. Currency Value Per Tick: 10.000000 | 2019-01-29 15:49:27 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2019-01-29 15:49:27 HTTPS historicaldata.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 15:49:27 CL.20190300.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:49:27 HTTPS historicaldata.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-29 15:49:27 HTTPS historicaldata.sierrachart.com:443 (2) | Closed. | 2019-01-29 15:49:27 Contract specifications for CL.20190300.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2019-01-29 15:49:27 CL.20190400.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:50:09 CL.20190400.CME_NY Daily #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CL.20190400.CME_NY.dly | 2019-01-29 15:50:09 CTS T4 FIX | Starting real-time market data updates for: CL.20190400.CME_NY. ID: 4 | 2019-01-29 15:50:10 CTS T4 FIX | Requesting security definition data for: CL.20190400.CME_NY. ID: 4 | 2019-01-29 15:50:10 HD Request # 14 | Downloading Historical Daily chart data for CL.20190400.CME_NY. Starting date: 1969-01-29. Service: cts | 2019-01-29 15:50:10 HD Request # 14 | Requesting historical Daily data for CLJ19 starting at 1969-01-28 | 2019-01-29 15:50:10 HTTPS historicaldata.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-29 15:50:10 HTTPS historicaldata.sierrachart.com:443 (2) | Connecting to IP: 88.99.0.216. | 2019-01-29 15:50:10 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190400.CME_NY | 2019-01-29 15:50:11 HD Request # 14 | Receiving historical Daily data for CL.20190400.CME_NY starting at 2013-11-20 | 2019-01-29 15:50:11 HD Request # 14 | Writing historical Daily data to the file CL.20190400.CME_NY.dly | 2019-01-29 15:50:11 HD Request # 14 | Received 1306 records from 2013-11-20 00:00:00 to 2019-01-29 00:00:00 (5.2years) and wrote 1306 records for CL.20190400.CME_NY | 2019-01-29 15:50:11 HD Request # 14 | Completion time: 1s | 2019-01-29 15:50:11 HD Request # 14 | Daily data download complete for CL.20190400.CME_NY. Unique request ID: 13 | 2019-01-29 15:50:11 Removed historical data download ID 13 | 2019-01-29 15:50:11 CTS T4 FIX | Received matching security definition for symbol CL.20190400.CME_NY. Subscribing to data. | 2019-01-29 15:50:11 CTS T4 FIX | Subscribing to symbol CL.20190400.CME_NY. Market: XCME_NY CL (J19) | 2019-01-29 15:50:11 Contract-Exchange: CL-CME_NY. Description: SIM:Crude Oil Apr19. Tick Size: 1.000000. Value Format: 0. Price Multiplier: 1.000000. Currency Value Per Tick: 10.000000 | 2019-01-29 15:50:11 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2019-01-29 15:50:11 HTTPS historicaldata.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 15:50:11 Contract specifications for CL.20190400.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2019-01-29 15:50:11 HTTPS historicaldata.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-29 15:50:11 HTTPS historicaldata.sierrachart.com:443 (2) | Closed. | 2019-01-29 15:50:11 CL.20190400.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:50:11 CL.20190300.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:50:35 CL.20190100.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:53:11 CL.20190200.CME_NY Daily #2 | Reloading chart. | 2019-01-29 15:53:37 This feature requires subscribing to the Sierra Chart Exchange Data Feed. | 2019-01-29 15:59:22 * Requesting symbols for NYSE | 2019-01-29 15:59:22 CTS T4 FIX | Querying for spread/strategy symbols for CL.######00.CME_NY. | 2019-01-29 16:00:00 CTS T4 FIX | Received 1528 security definitions for symbols request. | 2019-01-29 16:00:02 CTS T4 FIX | Querying for option symbols for CL.20190100.CME_NY. | 2019-01-29 16:00:57 CTS T4 FIX | Received 0 security definitions for symbols request. | 2019-01-29 16:00:57 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CL.20190300.CME_NY | 2019-01-29 16:01:44 Intraday data recording state for symbol CL.20190300.CME_NY is set to download 'Pending'. | 2019-01-29 16:01:44 HD Request # 15 | Downloading Intraday chart data for CL.20190300.CME_NY to the file CL.20190300.CME_NY.scid. Service: nymex | 2019-01-29 16:01:44 Compressing file: C:\SierraChart\Data\CL.20190300.CME_NY.scid. This may take a while. | 2019-01-29 16:01:44 HD Request # 15 | Download start date-time: 2018-07-27 17:01:44.000 | 2019-01-29 16:01:44 HD Request # 15 | Using server: ds1.sierracharts.com port 10150 | 2019-01-29 16:01:44 Socket (2) | Creating socket. | 2019-01-29 16:01:44 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-01-29 16:01:44 HD Request # 15 | Setting DTC encoding to Binary VLS | 2019-01-29 16:01:44 HD Request # 15 | Sending historical data logon request message. | 2019-01-29 16:01:44 HD Request # 15 | Requesting Intraday data. Start date-time: 2018-07-27 17:01:44. Record interval: 1. Symbol: CLH19 | 2019-01-29 16:01:45 HD Request # 15 | Decompressing data. | 2019-01-29 16:01:45 HD Request # 15 | Receiving Intraday data for CL.20190300.CME_NY starting at 2018-07-30 03:44:13 | 2019-01-29 16:01:46 HD Request # 15 | Timestamp of first Intraday data file record written: 2018-07-30 03:44:13 | 2019-01-29 16:01:46 Historical data download thread signaled to stop. | 2019-01-29 16:01:57 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-29 16:01:57 HD Request # 15 | Received 742282 records from 2018-07-30 03:44:13 to 2019-01-29 15:51:44 (183.5 days) and wrote 742282 records for CL.20190300.CME_NY | 2019-01-29 16:01:57 HD Request # 15 | Completion time: 12s | 2019-01-29 16:01:57 HD Request # 15 | Intraday data download complete for CL.20190300.CME_NY. Unique request ID: 14 | 2019-01-29 16:01:57 Removed historical data download ID 14 | 2019-01-29 16:01:57 Real-time Intraday chart data file updates started for CL.20190300.CME_NY | 2019-01-29 16:01:57 Opened cached Intraday file: C:\SierraChart\Data\CL.20190300.CME_NY.scid | 2019-01-29 16:01:57 Intraday chart data file opened for CL.20190300.CME_NY | 2019-01-29 16:01:57 CTS T4 FIX | Using primary service for historical data for CL.20190300.CME_NY | 2019-01-29 16:01:57 Intraday data recording state for symbol CL.20190300.CME_NY is set to download 'Pending'. | 2019-01-29 16:01:57 HD Request # 16 | Downloading Intraday chart data for CL.20190300.CME_NY to the file CL.20190300.CME_NY.scid. Service: cts | 2019-01-29 16:01:57 HD Request # 16 | Download start date-time: 2019-01-29 15:51:44.000 | 2019-01-29 16:01:57 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2019-01-29 16:01:57 Socket (2) | Socket gracefully closed by remote side. | 2019-01-29 16:01:57 Socket (2) | Closed. | 2019-01-29 16:01:57 CTS FIX Historical Data socket (3) | Creating socket. Using TLS 1.0. | 2019-01-29 16:01:59 CTS FIX Historical Data socket (3) | Connecting to IP: 74.201.6.229. | 2019-01-29 16:01:59 CTS FIX Historical Data: Sending the Logon message. | 2019-01-29 16:01:59 CTS FIX Historical Data: Connected to Historical data server. | 2019-01-29 16:02:00 HD Request # 16 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-29 00:00:00 to 2019-01-29 00:00:00 (US Central Time). | 2019-01-29 16:02:00 HD Request # 16 | Receiving Intraday data for CL.20190300.CME_NY starting at 2019-01-28 17:00:00 | 2019-01-29 16:02:04 HD Request # 16 | Timestamp of first Intraday data file record written: 2019-01-29 15:51:44 | 2019-01-29 16:02:04 HD Request # 16 | Total records received: 41233 | 2019-01-29 16:02:04 HD Request # 16 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-30 00:00:00 to 2019-01-30 00:00:00 (US Central Time). | 2019-01-29 16:02:04 HD Request # 16 | Total records received: 41233 | 2019-01-29 16:02:05 HD Request # 16 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-31 00:00:00 to 2019-01-31 00:00:00 (US Central Time). | 2019-01-29 16:02:05 HD Request # 16 | Received 41233 records from 2019-01-28 17:00:00 to 2019-01-29 15:59:59 (23.0 hours) and wrote 141 records for CL.20190300.CME_NY | 2019-01-29 16:02:05 HD Request # 16 | Completion time: 8s | 2019-01-29 16:02:05 HD Request # 16 | Intraday data download complete for CL.20190300.CME_NY. Unique request ID: 15 | 2019-01-29 16:02:05 Removed historical data download ID 15 | 2019-01-29 16:02:05 Real-time Intraday chart data file updates started for CL.20190300.CME_NY | 2019-01-29 16:02:05 Opened cached Intraday file: C:\SierraChart\Data\CL.20190300.CME_NY.scid | 2019-01-29 16:02:05 Intraday chart data file opened for CL.20190300.CME_NY | 2019-01-29 16:02:05 CTS FIX Historical Data socket (3) | Socket gracefully closed by remote side. | 2019-01-29 16:03:05 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2019-01-29 16:03:05 CTS FIX Historical Data socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-29 16:03:05 CTS FIX Historical Data: Disconnected. | 2019-01-29 16:03:05 CTS FIX Historical Data socket (3) | Closed. | 2019-01-29 16:03:05 CL.20190100.CME_NY Daily #2 | Reloading chart. | 2019-01-29 16:20:23 CL.20190100.CME_NY 1 Min #1 | Reloading chart. | 2019-01-29 16:21:31 CL.20190100.CME_NY 5 Min #1 | Reloading chart. | 2019-01-29 16:21:48 CL.20190100.CME_NY 5 Min #1 | Reloading chart. | 2019-01-29 16:29:26 CL.20190100.CME_NY 10 Min #1 | Reloading chart. | 2019-01-29 16:29:28 CL.20190100.CME_NY 5 Min #1 | Reloading chart. | 2019-01-29 16:29:31 CL.20190100.CME_NY Daily #4 | Reloading chart. | 2019-01-29 16:47:18 CL.20190100.CME_NY Weekly #4 | Reloading chart. | 2019-01-29 16:49:36 Unsubscribed from market depth data for CL.20190200.CME_NY | 2019-01-29 16:53:55 CL.20190100.CME_NY 1 Min #3 | Reloading chart. | 2019-01-29 16:56:47 CL.20190100.CME_NY 60 Min #3 | Reloading chart. | 2019-01-29 16:56:51 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2019-01-29 16:59:01 CTS T4 FIX | Received unsolicited security definition for symbol CL.XCME_NY CL (Z21)-2(H22)(M22).CME_NY. Making full security definition request for additional details. | 2019-01-29 17:33:02 CTS T4 FIX | Received unsolicited security definition for symbol CL.XCME_NY CL (Z20)-2(H21)(M21).CME_NY. Making full security definition request for additional details. | 2019-01-29 17:33:02 Contract specifications for CL.XCME_NY CL (Z21)-2(H22)(M22).CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2019-01-29 17:33:02 Contract specifications for CL.XCME_NY CL (Z20)-2(H21)(M21).CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2019-01-29 17:33:02 CTS FIX socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-01-30 00:59:34 * CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-30 00:59:34 Notice: Detected that the system has resumed from a low-power state. | 2019-01-30 00:59:34 Re-connecting to the Data/Trading service. | 2019-01-30 00:59:34 CTS FIX: DisconnectFIX called. | 2019-01-30 00:59:35 CTS FIX: Sending a Logout message. | 2019-01-30 00:59:35 CTS FIX socket (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2019-01-30 00:59:35 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-30 00:59:35 CTS FIX socket (1) | Closed. | 2019-01-30 00:59:35 CTS T4 FIX | Disconnected. | 2019-01-30 00:59:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-30 00:59:35 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-30 00:59:38 CTS T4 FIX | Firm: PTP | 2019-01-30 00:59:38 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-30 00:59:39 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-30 00:59:39 CTS FIX: Sending the Logon message. | 2019-01-30 00:59:40 CTS T4 FIX | FIX version: 4.7.23.0 | 2019-01-30 00:59:40 CTS T4 FIX | Connected to data and trading server. | 2019-01-30 00:59:40 CTS T4 FIX | Starting real-time market data updates for: CL.20190200.CME_NY. ID: 1 | 2019-01-30 00:59:40 CTS T4 FIX | Requesting security definition data for: CL.20190200.CME_NY. ID: 1 | 2019-01-30 00:59:40 Intraday data recording state for symbol CL.20190200.CME_NY is set to download 'Pending'. | 2019-01-30 00:59:40 CTS T4 FIX | Starting real-time market data updates for: CL.20190100.CME_NY. ID: 2 | 2019-01-30 00:59:40 CTS T4 FIX | Requesting security definition data for: CL.20190100.CME_NY. ID: 2 | 2019-01-30 00:59:40 Intraday data recording state for symbol CL.20190100.CME_NY is set to download 'Pending'. | 2019-01-30 00:59:40 CTS T4 FIX | Starting real-time market data updates for: CL.20190300.CME_NY. ID: 3 | 2019-01-30 00:59:40 CTS T4 FIX | Requesting security definition data for: CL.20190300.CME_NY. ID: 3 | 2019-01-30 00:59:40 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CL.20190300.CME_NY | 2019-01-30 00:59:40 Intraday data recording state for symbol CL.20190300.CME_NY is set to download 'Pending'. | 2019-01-30 00:59:40 Delaying start of download for CL.20190200.CME_NY | 2019-01-30 00:59:40 CTS T4 FIX | Received Account List collateral report. | 2019-01-30 00:59:41 CTS T4 FIX | Subscribing to account: S1J* | 2019-01-30 00:59:41 Supported exchange: CME_NGOp (SIM:NYMEX NatGas Options) | 2019-01-30 00:59:41 Supported exchange: CME_CO (SIM:COMEX Futures) | 2019-01-30 00:59:41 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2019-01-30 00:59:41 Supported exchange: CME_CL (SIM:NYMEX CrudeOil Futures) | 2019-01-30 00:59:41 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2019-01-30 00:59:41 Supported exchange: CME_FRE (SIM:NYMEX Freight Futures) | 2019-01-30 00:59:41 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2019-01-30 00:59:41 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2019-01-30 00:59:41 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2019-01-30 00:59:41 Supported exchange: CME_NG (SIM:NYMEX NatGas Futures) | 2019-01-30 00:59:41 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2019-01-30 00:59:41 Supported exchange: CME_KOp (SIM:KCBT Options) | 2019-01-30 00:59:41 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2019-01-30 00:59:41 Supported exchange: CME_CLOp (SIM:NYMEX CrudeOil Options) | 2019-01-30 00:59:41 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2019-01-30 00:59:41 Supported exchange: CME_COAL (SIM:NYMEX Coal Futures) | 2019-01-30 00:59:41 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2019-01-30 00:59:41 Supported exchange: CME_K (SIM:KCBT Futures) | 2019-01-30 00:59:41 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2019-01-30 00:59:41 Supported exchange: CME_COALOp (SIM:NYMEX Coal Options) | 2019-01-30 00:59:41 Supported exchange: CME_ELEOp (SIM:NYMEX Power Options) | 2019-01-30 00:59:41 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2019-01-30 00:59:41 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2019-01-30 00:59:41 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2019-01-30 00:59:41 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2019-01-30 00:59:41 Supported exchange: CME_ELE (SIM:NYMEX Power Futures) | 2019-01-30 00:59:41 Supported exchange: CME_REF (SIM:NYMEX Refined Products Futures) | 2019-01-30 00:59:41 Supported exchange: CME_FREOp (SIM:NYMEX Freight Options) | 2019-01-30 00:59:41 Supported exchange: CME_PETOp (SIM:NYMEX NGL/Petrochemicals Options) | 2019-01-30 00:59:41 Supported exchange: CME_REFOp (SIM:NYMEX Refined Products Options) | 2019-01-30 00:59:41 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2019-01-30 00:59:41 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2019-01-30 00:59:41 Supported exchange: CME_COOp (SIM:COMEX Options) | 2019-01-30 00:59:41 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190100.CME_NY | 2019-01-30 00:59:41 Symbol Error - CL.20190100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-30 00:59:41 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-30 00:59:41 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190200.CME_NY | 2019-01-30 00:59:43 Symbol Error - CL.20190200.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-30 00:59:43 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-30 00:59:43 HD Request # 17 | Downloading Intraday chart data for CL.20190200.CME_NY to the file CL.20190200.CME_NY.scid. Service: nymex | 2019-01-30 00:59:44 HD Request # 17 | Download start date-time: 2019-01-22 13:29:59.000 | 2019-01-30 00:59:44 HD Request # 17 | Using server: ds7.sierracharts.com port 10149 | 2019-01-30 00:59:44 Socket (2) | Creating socket. | 2019-01-30 00:59:44 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-01-30 00:59:44 HD Request # 17 | Setting DTC encoding to Binary VLS | 2019-01-30 00:59:44 HD Request # 17 | Sending historical data logon request message. | 2019-01-30 00:59:44 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190300.CME_NY | 2019-01-30 00:59:44 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2019-01-30 00:59:44 HD Request # 17 | Requesting Intraday data. Start date-time: 2019-01-22 13:29:59. Record interval: 1. Symbol: CLG19 | 2019-01-30 00:59:44 CTS T4 FIX | Received matching security definition for symbol CL.20190300.CME_NY. Subscribing to data. | 2019-01-30 00:59:44 CTS T4 FIX | Subscribing to symbol CL.20190300.CME_NY. Market: XCME_NY CL (H19) | 2019-01-30 00:59:44 Contract-Exchange: CL-CME_NY. Description: SIM:Crude Oil Mar19. Tick Size: 1.000000. Value Format: 0. Price Multiplier: 1.000000. Currency Value Per Tick: 10.000000 | 2019-01-30 00:59:44 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2019-01-30 00:59:44 HD Request # 17 | Decompressing data. | 2019-01-30 00:59:45 HD Request # 17 | Receiving Intraday data for CL.20190200.CME_NY starting at 2019-01-22 13:29:59 | 2019-01-30 00:59:45 HD Request # 17 | Timestamp of first Intraday data file record written: 2019-01-22 13:29:59 | 2019-01-30 00:59:45 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 00:59:45 Historical data download thread signaled to stop. | 2019-01-30 00:59:45 HD Request # 17 | Received 1 record from 2019-01-22 13:29:59 to 2019-01-22 13:29:59 (0.0 seconds) and wrote 1 record for CL.20190200.CME_NY | 2019-01-30 00:59:45 HD Request # 17 | Completion time: 0s | 2019-01-30 00:59:45 HD Request # 17 | Intraday data download complete for CL.20190200.CME_NY. Unique request ID: 16 | 2019-01-30 00:59:45 Removed historical data download ID 16 | 2019-01-30 00:59:45 Real-time Intraday chart data file updates started for CL.20190200.CME_NY | 2019-01-30 00:59:45 Opened cached Intraday file: C:\SierraChart\Data\CL.20190200.CME_NY.scid | 2019-01-30 00:59:45 Intraday chart data file opened for CL.20190200.CME_NY | 2019-01-30 00:59:45 Contract specifications for CL.20190300.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2019-01-30 00:59:45 HD Request # 18 | Downloading Intraday chart data for CL.20190100.CME_NY to the file CL.20190100.CME_NY.scid. Service: nymex | 2019-01-30 00:59:45 HD Request # 18 | Download start date-time: 2018-12-19 13:29:41.000 | 2019-01-30 00:59:45 HD Request # 18 | Using server: ds1.sierracharts.com port 10150 | 2019-01-30 00:59:45 Socket (2) | Socket gracefully closed by remote side. | 2019-01-30 00:59:45 Socket (2) | Closed. | 2019-01-30 00:59:45 Socket (3) | Creating socket. | 2019-01-30 00:59:45 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-01-30 00:59:45 HD Request # 18 | Setting DTC encoding to Binary VLS | 2019-01-30 00:59:45 HD Request # 18 | Sending historical data logon request message. | 2019-01-30 00:59:45 CTS T4 FIX | Requesting Open Orders for account: S1J*. Request ID: 2292982 | 2019-01-30 00:59:45 HD Request # 18 | Requesting Intraday data. Start date-time: 2018-12-19 13:29:41. Record interval: 1. Symbol: CLF19 | 2019-01-30 00:59:45 CTS T4 FIX | No open orders for account S1Jan29157920 | 2019-01-30 00:59:46 HD Request # 18 | Decompressing data. | 2019-01-30 00:59:46 HD Request # 18 | Receiving Intraday data for CL.20190100.CME_NY starting at 2018-12-19 13:29:41 | 2019-01-30 00:59:46 HD Request # 18 | Timestamp of first Intraday data file record written: 2018-12-19 13:29:41 | 2019-01-30 00:59:46 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-01-30 00:59:46 Historical data download thread signaled to stop. | 2019-01-30 00:59:46 HD Request # 18 | Received 1 record from 2018-12-19 13:29:41 to 2018-12-19 13:29:41 (0.0 seconds) and wrote 1 record for CL.20190100.CME_NY | 2019-01-30 00:59:46 HD Request # 18 | Completion time: 0s | 2019-01-30 00:59:46 HD Request # 18 | Intraday data download complete for CL.20190100.CME_NY. Unique request ID: 17 | 2019-01-30 00:59:46 Removed historical data download ID 17 | 2019-01-30 00:59:46 Real-time Intraday chart data file updates started for CL.20190100.CME_NY | 2019-01-30 00:59:46 Opened cached Intraday file: C:\SierraChart\Data\CL.20190100.CME_NY.scid | 2019-01-30 00:59:46 Intraday chart data file opened for CL.20190100.CME_NY | 2019-01-30 00:59:46 Delaying start of download for CL.20190300.CME_NY | 2019-01-30 00:59:46 Socket (3) | Socket gracefully closed by remote side. | 2019-01-30 00:59:46 Socket (3) | Closed. | 2019-01-30 00:59:46 HD Request # 19 | Downloading Intraday chart data for CL.20190300.CME_NY to the file CL.20190300.CME_NY.scid. Service: nymex | 2019-01-30 00:59:50 HD Request # 19 | Download start date-time: 2019-01-29 20:19:31.000 | 2019-01-30 00:59:50 HD Request # 19 | Using server: ds7.sierracharts.com port 10149 | 2019-01-30 00:59:50 Socket (2) | Creating socket. | 2019-01-30 00:59:50 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-01-30 00:59:50 HD Request # 19 | Setting DTC encoding to Binary VLS | 2019-01-30 00:59:50 HD Request # 19 | Sending historical data logon request message. | 2019-01-30 00:59:50 HD Request # 19 | Requesting Intraday data. Start date-time: 2019-01-29 20:19:31. Record interval: 1. Symbol: CLH19 | 2019-01-30 00:59:50 HD Request # 19 | Decompressing data. | 2019-01-30 00:59:51 HD Request # 19 | Receiving Intraday data for CL.20190300.CME_NY starting at 2019-01-29 20:19:31 | 2019-01-30 00:59:51 HD Request # 19 | Timestamp of first Intraday data file record written: 2019-01-29 20:19:31 | 2019-01-30 00:59:51 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 00:59:51 Historical data download thread signaled to stop. | 2019-01-30 00:59:51 HD Request # 19 | Received 4923 records from 2019-01-29 20:19:31 to 2019-01-30 00:49:49 (4.5 hours) and wrote 4923 records for CL.20190300.CME_NY | 2019-01-30 00:59:51 HD Request # 19 | Completion time: 2s | 2019-01-30 00:59:51 HD Request # 19 | Intraday data download complete for CL.20190300.CME_NY. Unique request ID: 18 | 2019-01-30 00:59:51 Removed historical data download ID 18 | 2019-01-30 00:59:51 Real-time Intraday chart data file updates started for CL.20190300.CME_NY | 2019-01-30 00:59:51 Opened cached Intraday file: C:\SierraChart\Data\CL.20190300.CME_NY.scid | 2019-01-30 00:59:51 Intraday chart data file opened for CL.20190300.CME_NY | 2019-01-30 00:59:51 CTS T4 FIX | Using primary service for historical data for CL.20190300.CME_NY | 2019-01-30 00:59:51 Intraday data recording state for symbol CL.20190300.CME_NY is set to download 'Pending'. | 2019-01-30 00:59:51 HD Request # 20 | Downloading Intraday chart data for CL.20190300.CME_NY to the file CL.20190300.CME_NY.scid. Service: cts | 2019-01-30 00:59:51 HD Request # 20 | Download start date-time: 2019-01-30 00:49:49.000 | 2019-01-30 00:59:51 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2019-01-30 00:59:51 Socket (2) | Socket gracefully closed by remote side. | 2019-01-30 00:59:51 Socket (2) | Closed. | 2019-01-30 00:59:51 CTS FIX Historical Data socket (3) | Creating socket. Using TLS 1.0. | 2019-01-30 00:59:53 CTS FIX Historical Data socket (3) | Connecting to IP: 74.201.6.229. | 2019-01-30 00:59:53 CTS FIX Historical Data: Sending the Logon message. | 2019-01-30 00:59:53 CTS FIX Historical Data: Connected to Historical data server. | 2019-01-30 00:59:54 HD Request # 20 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-30 00:00:00 to 2019-01-30 00:00:00 (US Central Time). | 2019-01-30 00:59:54 HD Request # 20 | Receiving Intraday data for CL.20190300.CME_NY starting at 2019-01-29 17:00:00 | 2019-01-30 00:59:55 HD Request # 20 | Timestamp of first Intraday data file record written: 2019-01-30 00:49:49 | 2019-01-30 00:59:55 HD Request # 20 | Total records received: 8335 | 2019-01-30 00:59:55 HD Request # 20 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-31 00:00:00 to 2019-01-31 00:00:00 (US Central Time). | 2019-01-30 00:59:55 CTS T4 FIX | Requesting historical Fills for account: S1J*. Request ID: 2292983 | 2019-01-30 00:59:55 HD Request # 20 | Total records received: 8335 | 2019-01-30 00:59:56 HD Request # 20 | Requesting historical Second data for CL.20190300.CME_NY from 2019-02-01 00:00:00 to 2019-02-01 00:00:00 (US Central Time). | 2019-01-30 00:59:56 CTS T4 FIX | Received Account List collateral report. | 2019-01-30 00:59:56 CTS T4 FIX | Server provided no historical order fills for account EBEC0534-D38A-4FDD-8BD4-C9FD3581A6C1 | 2019-01-30 00:59:56 HD Request # 20 | Received 8335 records from 2019-01-29 17:00:00 to 2019-01-30 00:59:51 (8.0 hours) and wrote 359 records for CL.20190300.CME_NY | 2019-01-30 00:59:56 Added 7 Time and Sales records to Intraday data file for CL.20190300.CME_NY after download. | 2019-01-30 00:59:56 HD Request # 20 | Completion time: 4s | 2019-01-30 00:59:56 HD Request # 20 | Intraday data download complete for CL.20190300.CME_NY. Unique request ID: 19 | 2019-01-30 00:59:56 Removed historical data download ID 19 | 2019-01-30 00:59:56 Real-time Intraday chart data file updates started for CL.20190300.CME_NY | 2019-01-30 00:59:56 Opened cached Intraday file: C:\SierraChart\Data\CL.20190300.CME_NY.scid | 2019-01-30 00:59:56 Intraday chart data file opened for CL.20190300.CME_NY | 2019-01-30 00:59:56 CL.20190100.CME_NY Daily #5 | Reloading chart. | 2019-01-30 01:01:43 CL.20190100.CME_NY Daily #5 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data | 2019-01-30 01:01:43 HD Request # 21 | Downloading Historical Daily chart data for CL.20190100.CME_NY. Starting date: 2018-12-18. Service: cts | 2019-01-30 01:01:43 Historical data download counter reset. | 2019-01-30 01:01:43 HD Request # 21 | Requesting historical Daily data for CLF19 starting at 2018-12-17 | 2019-01-30 01:01:43 HTTPS historicaldata.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-30 01:01:43 HTTPS historicaldata.sierrachart.com:443 (2) | Connecting to IP: 88.99.0.216. | 2019-01-30 01:01:43 HD Request # 21 | Receiving historical Daily data for CL.20190100.CME_NY starting at 2018-12-18 | 2019-01-30 01:01:44 HD Request # 21 | Writing historical Daily data to the file CL.20190100.CME_NY.dly | 2019-01-30 01:01:44 HD Request # 21 | Received 3 records from 2018-12-18 00:00:00 to 2018-12-19 00:00:00 (2.0 days) and wrote 2 records for CL.20190100.CME_NY | 2019-01-30 01:01:44 HD Request # 21 | Completion time: 0s | 2019-01-30 01:01:44 HD Request # 21 | Daily data download complete for CL.20190100.CME_NY. Unique request ID: 20 | 2019-01-30 01:01:44 Removed historical data download ID 20 | 2019-01-30 01:01:44 CL.20190100.CME_NY Daily #5 | Reloading chart. | 2019-01-30 01:01:44 HTTPS historicaldata.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 01:01:44 CL.20190100.CME_NY Weekly #4 | Reloading chart. | 2019-01-30 01:01:44 CL.20190100.CME_NY Daily #2 | Reloading chart. | 2019-01-30 01:01:44 HTTPS historicaldata.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-30 01:01:44 HTTPS historicaldata.sierrachart.com:443 (2) | Closed. | 2019-01-30 01:01:44 CTS FIX Historical Data socket (3) | Socket gracefully closed by remote side. | 2019-01-30 01:01:56 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2019-01-30 01:01:56 CTS FIX Historical Data socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-30 01:01:56 CTS FIX Historical Data: Disconnected. | 2019-01-30 01:01:56 CTS FIX Historical Data socket (3) | Closed. | 2019-01-30 01:01:56 CTS FIX: No heartbeat messages received from server. Sent Test Request message to server. | 2019-01-30 02:17:13 The data feed was lost. There was no activity for at least 60.0 seconds. | 2019-01-30 02:17:13 Connection to the external service has been lost. | 2019-01-30 02:17:13 CTS FIX: DisconnectFIX called. | 2019-01-30 02:17:13 CTS FIX: Sending a Logout message. | 2019-01-30 02:17:13 CTS T4 FIX | Disconnected. | 2019-01-30 02:17:13 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-30 02:17:13 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-30 02:17:13 Notice: Detected that the system has resumed from a low-power state. | 2019-01-30 02:17:13 Re-connecting to the Data/Trading service. | 2019-01-30 02:17:13 CTS T4 FIX | Disconnected. | 2019-01-30 02:17:13 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-30 02:17:13 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-30 02:17:16 CTS T4 FIX | Firm: PTP | 2019-01-30 02:17:16 CTS FIX socket (2) | Creating socket. Using TLS 1.0. | 2019-01-30 02:17:17 CTS FIX socket (2) | Connecting to IP: 74.201.6.199. | 2019-01-30 02:17:17 CTS FIX: Sending the Logon message. | 2019-01-30 02:17:17 CTS T4 FIX | FIX version: 4.7.23.0 | 2019-01-30 02:17:18 CTS T4 FIX | Connected to data and trading server. | 2019-01-30 02:17:18 CTS T4 FIX | Starting real-time market data updates for: CL.20190200.CME_NY. ID: 1 | 2019-01-30 02:17:18 CTS T4 FIX | Requesting security definition data for: CL.20190200.CME_NY. ID: 1 | 2019-01-30 02:17:18 Intraday data recording state for symbol CL.20190200.CME_NY is set to download 'Pending'. | 2019-01-30 02:17:18 CTS T4 FIX | Starting real-time market data updates for: CL.20190100.CME_NY. ID: 2 | 2019-01-30 02:17:18 CTS T4 FIX | Requesting security definition data for: CL.20190100.CME_NY. ID: 2 | 2019-01-30 02:17:18 Intraday data recording state for symbol CL.20190100.CME_NY is set to download 'Pending'. | 2019-01-30 02:17:18 CTS T4 FIX | Starting real-time market data updates for: CL.20190300.CME_NY. ID: 3 | 2019-01-30 02:17:18 CTS T4 FIX | Requesting security definition data for: CL.20190300.CME_NY. ID: 3 | 2019-01-30 02:17:18 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CL.20190300.CME_NY | 2019-01-30 02:17:18 Intraday data recording state for symbol CL.20190300.CME_NY is set to download 'Pending'. | 2019-01-30 02:17:18 Delaying start of download for CL.20190200.CME_NY | 2019-01-30 02:17:18 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190100.CME_NY | 2019-01-30 02:17:18 CTS T4 FIX | Received Account List collateral report. | 2019-01-30 02:17:18 CTS T4 FIX | Subscribing to account: S1J* | 2019-01-30 02:17:18 Supported exchange: CME_NGOp (SIM:NYMEX NatGas Options) | 2019-01-30 02:17:18 Supported exchange: CME_CO (SIM:COMEX Futures) | 2019-01-30 02:17:18 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2019-01-30 02:17:18 Supported exchange: CME_CL (SIM:NYMEX CrudeOil Futures) | 2019-01-30 02:17:18 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2019-01-30 02:17:18 Supported exchange: CME_FRE (SIM:NYMEX Freight Futures) | 2019-01-30 02:17:18 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2019-01-30 02:17:18 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2019-01-30 02:17:18 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2019-01-30 02:17:18 Supported exchange: CME_NG (SIM:NYMEX NatGas Futures) | 2019-01-30 02:17:18 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2019-01-30 02:17:18 Supported exchange: CME_KOp (SIM:KCBT Options) | 2019-01-30 02:17:18 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2019-01-30 02:17:18 Supported exchange: CME_CLOp (SIM:NYMEX CrudeOil Options) | 2019-01-30 02:17:18 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2019-01-30 02:17:18 Supported exchange: CME_COAL (SIM:NYMEX Coal Futures) | 2019-01-30 02:17:18 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2019-01-30 02:17:18 Supported exchange: CME_K (SIM:KCBT Futures) | 2019-01-30 02:17:18 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2019-01-30 02:17:18 Supported exchange: CME_COALOp (SIM:NYMEX Coal Options) | 2019-01-30 02:17:18 Supported exchange: CME_ELEOp (SIM:NYMEX Power Options) | 2019-01-30 02:17:18 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2019-01-30 02:17:18 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2019-01-30 02:17:18 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2019-01-30 02:17:18 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2019-01-30 02:17:18 Supported exchange: CME_ELE (SIM:NYMEX Power Futures) | 2019-01-30 02:17:18 Supported exchange: CME_REF (SIM:NYMEX Refined Products Futures) | 2019-01-30 02:17:18 Supported exchange: CME_FREOp (SIM:NYMEX Freight Options) | 2019-01-30 02:17:18 Supported exchange: CME_PETOp (SIM:NYMEX NGL/Petrochemicals Options) | 2019-01-30 02:17:18 Supported exchange: CME_REFOp (SIM:NYMEX Refined Products Options) | 2019-01-30 02:17:18 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2019-01-30 02:17:18 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2019-01-30 02:17:18 Supported exchange: CME_COOp (SIM:COMEX Options) | 2019-01-30 02:17:18 Symbol Error - CL.20190100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-30 02:17:18 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-30 02:17:18 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190200.CME_NY | 2019-01-30 02:17:19 Symbol Error - CL.20190200.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-30 02:17:20 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-30 02:17:20 HD Request # 22 | Downloading Intraday chart data for CL.20190200.CME_NY to the file CL.20190200.CME_NY.scid. Service: nymex | 2019-01-30 02:17:20 HD Request # 22 | Download start date-time: 2019-01-22 13:29:59.000 | 2019-01-30 02:17:20 HD Request # 22 | Using server: ds1.sierracharts.com port 10150 | 2019-01-30 02:17:20 Socket (3) | Creating socket. | 2019-01-30 02:17:20 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-01-30 02:17:20 HD Request # 22 | Setting DTC encoding to Binary VLS | 2019-01-30 02:17:20 HD Request # 22 | Sending historical data logon request message. | 2019-01-30 02:17:20 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2019-01-30 02:17:20 HD Request # 22 | Requesting Intraday data. Start date-time: 2019-01-22 13:29:59. Record interval: 1. Symbol: CLG19 | 2019-01-30 02:17:20 HD Request # 22 | Decompressing data. | 2019-01-30 02:17:21 HD Request # 22 | Receiving Intraday data for CL.20190200.CME_NY starting at 2019-01-22 13:29:59 | 2019-01-30 02:17:21 HD Request # 22 | Timestamp of first Intraday data file record written: 2019-01-22 13:29:59 | 2019-01-30 02:17:21 Historical data download thread signaled to stop. | 2019-01-30 02:17:21 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-01-30 02:17:21 HD Request # 22 | Received 1 record from 2019-01-22 13:29:59 to 2019-01-22 13:29:59 (0.0 seconds) and wrote 1 record for CL.20190200.CME_NY | 2019-01-30 02:17:21 HD Request # 22 | Completion time: 1s | 2019-01-30 02:17:21 HD Request # 22 | Intraday data download complete for CL.20190200.CME_NY. Unique request ID: 21 | 2019-01-30 02:17:21 Removed historical data download ID 21 | 2019-01-30 02:17:21 Real-time Intraday chart data file updates started for CL.20190200.CME_NY | 2019-01-30 02:17:21 Opened cached Intraday file: C:\SierraChart\Data\CL.20190200.CME_NY.scid | 2019-01-30 02:17:21 Intraday chart data file opened for CL.20190200.CME_NY | 2019-01-30 02:17:21 HD Request # 23 | Downloading Intraday chart data for CL.20190100.CME_NY to the file CL.20190100.CME_NY.scid. Service: nymex | 2019-01-30 02:17:21 HD Request # 23 | Download start date-time: 2018-12-19 13:29:41.000 | 2019-01-30 02:17:21 HD Request # 23 | Using server: ds7.sierracharts.com port 10149 | 2019-01-30 02:17:21 Socket (4) | Creating socket. | 2019-01-30 02:17:21 Socket (4) | Connecting to IP: 8.18.161.133. | 2019-01-30 02:17:21 Socket (3) | Socket gracefully closed by remote side. | 2019-01-30 02:17:21 Socket (3) | Closed. | 2019-01-30 02:17:21 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190300.CME_NY | 2019-01-30 02:17:21 HD Request # 23 | Setting DTC encoding to Binary VLS | 2019-01-30 02:17:21 HD Request # 23 | Sending historical data logon request message. | 2019-01-30 02:17:21 CTS T4 FIX | Received matching security definition for symbol CL.20190300.CME_NY. Subscribing to data. | 2019-01-30 02:17:21 CTS T4 FIX | Subscribing to symbol CL.20190300.CME_NY. Market: XCME_NY CL (H19) | 2019-01-30 02:17:21 Contract-Exchange: CL-CME_NY. Description: SIM:Crude Oil Mar19. Tick Size: 1.000000. Value Format: 0. Price Multiplier: 1.000000. Currency Value Per Tick: 10.000000 | 2019-01-30 02:17:21 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2019-01-30 02:17:21 HD Request # 23 | Requesting Intraday data. Start date-time: 2018-12-19 13:29:41. Record interval: 1. Symbol: CLF19 | 2019-01-30 02:17:21 Contract specifications for CL.20190300.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2019-01-30 02:17:21 HD Request # 23 | Decompressing data. | 2019-01-30 02:17:22 HD Request # 23 | Receiving Intraday data for CL.20190100.CME_NY starting at 2018-12-19 13:29:41 | 2019-01-30 02:17:22 HD Request # 23 | Timestamp of first Intraday data file record written: 2018-12-19 13:29:41 | 2019-01-30 02:17:22 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-01-30 02:17:22 Historical data download thread signaled to stop. | 2019-01-30 02:17:22 HD Request # 23 | Received 1 record from 2018-12-19 13:29:41 to 2018-12-19 13:29:41 (0.0 seconds) and wrote 1 record for CL.20190100.CME_NY | 2019-01-30 02:17:22 HD Request # 23 | Completion time: 1s | 2019-01-30 02:17:22 HD Request # 23 | Intraday data download complete for CL.20190100.CME_NY. Unique request ID: 22 | 2019-01-30 02:17:22 Removed historical data download ID 22 | 2019-01-30 02:17:22 Real-time Intraday chart data file updates started for CL.20190100.CME_NY | 2019-01-30 02:17:22 Opened cached Intraday file: C:\SierraChart\Data\CL.20190100.CME_NY.scid | 2019-01-30 02:17:22 Intraday chart data file opened for CL.20190100.CME_NY | 2019-01-30 02:17:22 Delaying start of download for CL.20190300.CME_NY | 2019-01-30 02:17:22 Socket (4) | Socket gracefully closed by remote side. | 2019-01-30 02:17:22 Socket (4) | Closed. | 2019-01-30 02:17:22 CTS T4 FIX | Requesting Open Orders for account: S1J*. Request ID: 2292991 | 2019-01-30 02:17:23 CTS T4 FIX | No open orders for account S1Jan29157920 | 2019-01-30 02:17:23 HD Request # 24 | Downloading Intraday chart data for CL.20190300.CME_NY to the file CL.20190300.CME_NY.scid. Service: nymex | 2019-01-30 02:17:27 HD Request # 24 | Download start date-time: 2019-01-30 01:52:32.000 | 2019-01-30 02:17:27 HD Request # 24 | Using server: ds1.sierracharts.com port 10150 | 2019-01-30 02:17:27 Socket (3) | Creating socket. | 2019-01-30 02:17:27 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-01-30 02:17:27 HD Request # 24 | Setting DTC encoding to Binary VLS | 2019-01-30 02:17:27 HD Request # 24 | Sending historical data logon request message. | 2019-01-30 02:17:27 HD Request # 24 | Requesting Intraday data. Start date-time: 2019-01-30 01:52:32. Record interval: 1. Symbol: CLH19 | 2019-01-30 02:17:27 HD Request # 24 | Decompressing data. | 2019-01-30 02:17:28 HD Request # 24 | Receiving Intraday data for CL.20190300.CME_NY starting at 2019-01-30 01:52:32 | 2019-01-30 02:17:28 HD Request # 24 | Timestamp of first Intraday data file record written: 2019-01-30 01:52:32 | 2019-01-30 02:17:28 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-01-30 02:17:28 Historical data download thread signaled to stop. | 2019-01-30 02:17:28 HD Request # 24 | Received 424 records from 2019-01-30 01:52:32 to 2019-01-30 02:07:27 (14.9 minutes) and wrote 424 records for CL.20190300.CME_NY | 2019-01-30 02:17:28 HD Request # 24 | Completion time: 1s | 2019-01-30 02:17:28 HD Request # 24 | Intraday data download complete for CL.20190300.CME_NY. Unique request ID: 23 | 2019-01-30 02:17:28 Removed historical data download ID 23 | 2019-01-30 02:17:28 Real-time Intraday chart data file updates started for CL.20190300.CME_NY | 2019-01-30 02:17:28 Opened cached Intraday file: C:\SierraChart\Data\CL.20190300.CME_NY.scid | 2019-01-30 02:17:28 Intraday chart data file opened for CL.20190300.CME_NY | 2019-01-30 02:17:28 CTS T4 FIX | Using primary service for historical data for CL.20190300.CME_NY | 2019-01-30 02:17:28 Intraday data recording state for symbol CL.20190300.CME_NY is set to download 'Pending'. | 2019-01-30 02:17:28 HD Request # 25 | Downloading Intraday chart data for CL.20190300.CME_NY to the file CL.20190300.CME_NY.scid. Service: cts | 2019-01-30 02:17:28 HD Request # 25 | Download start date-time: 2019-01-30 02:07:27.000 | 2019-01-30 02:17:28 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2019-01-30 02:17:28 Socket (3) | Socket gracefully closed by remote side. | 2019-01-30 02:17:28 Socket (3) | Closed. | 2019-01-30 02:17:28 CTS FIX Historical Data socket (4) | Creating socket. Using TLS 1.0. | 2019-01-30 02:17:30 CTS FIX Historical Data socket (4) | Connecting to IP: 74.201.6.229. | 2019-01-30 02:17:30 CTS FIX Historical Data: Sending the Logon message. | 2019-01-30 02:17:30 CTS FIX Historical Data: Connected to Historical data server. | 2019-01-30 02:17:31 HD Request # 25 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-30 00:00:00 to 2019-01-30 00:00:00 (US Central Time). | 2019-01-30 02:17:31 HD Request # 25 | Receiving Intraday data for CL.20190300.CME_NY starting at 2019-01-29 17:00:00 | 2019-01-30 02:17:32 HD Request # 25 | Timestamp of first Intraday data file record written: 2019-01-30 02:07:27 | 2019-01-30 02:17:32 HD Request # 25 | Total records received: 10456 | 2019-01-30 02:17:32 HD Request # 25 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-31 00:00:00 to 2019-01-31 00:00:00 (US Central Time). | 2019-01-30 02:17:32 HD Request # 25 | Total records received: 10456 | 2019-01-30 02:17:32 HD Request # 25 | Requesting historical Second data for CL.20190300.CME_NY from 2019-02-01 00:00:00 to 2019-02-01 00:00:00 (US Central Time). | 2019-01-30 02:17:32 HD Request # 25 | Received 10456 records from 2019-01-29 17:00:00 to 2019-01-30 02:17:27 (9.3 hours) and wrote 386 records for CL.20190300.CME_NY | 2019-01-30 02:17:33 Added 5 Time and Sales records to Intraday data file for CL.20190300.CME_NY after download. | 2019-01-30 02:17:33 HD Request # 25 | Completion time: 5s | 2019-01-30 02:17:33 HD Request # 25 | Intraday data download complete for CL.20190300.CME_NY. Unique request ID: 24 | 2019-01-30 02:17:33 Removed historical data download ID 24 | 2019-01-30 02:17:33 Real-time Intraday chart data file updates started for CL.20190300.CME_NY | 2019-01-30 02:17:33 Opened cached Intraday file: C:\SierraChart\Data\CL.20190300.CME_NY.scid | 2019-01-30 02:17:33 Intraday chart data file opened for CL.20190300.CME_NY | 2019-01-30 02:17:33 CTS T4 FIX | Requesting historical Fills for account: S1J*. Request ID: 2292992 | 2019-01-30 02:17:33 CTS T4 FIX | Received Account List collateral report. | 2019-01-30 02:17:33 CTS T4 FIX | Server provided no historical order fills for account EBEC0534-D38A-4FDD-8BD4-C9FD3581A6C1 | 2019-01-30 02:17:33 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-30 02:17:37 CTS FIX socket (1) | Shutdown started. Waiting for graceful close. | 2019-01-30 02:17:37 CTS FIX socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-01-30 02:17:37 * CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-30 02:17:37 CTS FIX socket (1) | Closed. | 2019-01-30 02:17:37 CTS FIX Historical Data socket (4) | Socket gracefully closed by remote side. | 2019-01-30 02:19:33 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2019-01-30 02:19:33 CTS FIX Historical Data socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-30 02:19:33 CTS FIX Historical Data: Disconnected. | 2019-01-30 02:19:33 CTS FIX Historical Data socket (4) | Closed. | 2019-01-30 02:19:33 CL.20190100.CME_NY 1 Min #5 | Reloading chart. | 2019-01-30 02:24:17 CL.20190100.CME_NY 1 Min #5 | Reloading chart. | 2019-01-30 02:24:21 CL.20190100.CME_NY 100 Trades #3 | Reloading chart. | 2019-01-30 02:27:09 CL.20190100.CME_NY 500 Trades #3 | Reloading chart. | 2019-01-30 02:28:06 CL.20190100.CME_NY 60 Min #3 | Reloading chart. | 2019-01-30 02:28:16 CL.20190100.CME_NY 500 Min #3 | Reloading chart. | 2019-01-30 02:28:19 CL.20190100.CME_NY 500 Trades #3 | Reloading chart. | 2019-01-30 02:28:24 CL.20190100.CME_NY 100 Trades #3 | Reloading chart. | 2019-01-30 02:33:09 CL.20190100.CME_NY 500 Trades #3 | Reloading chart. | 2019-01-30 02:33:12 CL.20190100.CME_NY 1 Min #5 | Reloading chart. | 2019-01-30 02:34:23 CL.20190100.CME_NY 100 Trades #5 | Reloading chart. | 2019-01-30 02:34:37 CTS FIX socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-01-30 10:40:50 * CTS FIX socket (2) | Socket gracefully closed by remote side. | 2019-01-30 10:40:50 Notice: Detected that the system has resumed from a low-power state. | 2019-01-30 10:40:51 Re-connecting to the Data/Trading service. | 2019-01-30 10:40:51 CTS FIX: DisconnectFIX called. | 2019-01-30 10:40:51 CTS FIX: Sending a Logout message. | 2019-01-30 10:40:51 CTS FIX socket (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2019-01-30 10:40:51 CTS FIX socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-30 10:40:51 CTS FIX socket (2) | Closed. | 2019-01-30 10:40:51 CTS T4 FIX | Disconnected. | 2019-01-30 10:40:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-30 10:40:51 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-30 10:40:54 CTS T4 FIX | Firm: PTP | 2019-01-30 10:40:54 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-30 10:40:55 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-30 10:40:55 CTS FIX: Sending the Logon message. | 2019-01-30 10:40:56 CTS T4 FIX | FIX version: 4.7.23.0 | 2019-01-30 10:40:56 CTS T4 FIX | Connected to data and trading server. | 2019-01-30 10:40:56 CTS T4 FIX | Starting real-time market data updates for: CL.20190200.CME_NY. ID: 1 | 2019-01-30 10:40:56 CTS T4 FIX | Requesting security definition data for: CL.20190200.CME_NY. ID: 1 | 2019-01-30 10:40:56 Intraday data recording state for symbol CL.20190200.CME_NY is set to download 'Pending'. | 2019-01-30 10:40:56 CTS T4 FIX | Starting real-time market data updates for: CL.20190100.CME_NY. ID: 2 | 2019-01-30 10:40:56 CTS T4 FIX | Requesting security definition data for: CL.20190100.CME_NY. ID: 2 | 2019-01-30 10:40:56 Intraday data recording state for symbol CL.20190100.CME_NY is set to download 'Pending'. | 2019-01-30 10:40:56 CTS T4 FIX | Starting real-time market data updates for: CL.20190300.CME_NY. ID: 3 | 2019-01-30 10:40:56 CTS T4 FIX | Requesting security definition data for: CL.20190300.CME_NY. ID: 3 | 2019-01-30 10:40:56 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CL.20190300.CME_NY | 2019-01-30 10:40:56 Intraday data recording state for symbol CL.20190300.CME_NY is set to download 'Pending'. | 2019-01-30 10:40:56 Delaying start of download for CL.20190200.CME_NY | 2019-01-30 10:40:56 CTS T4 FIX | Received Account List collateral report. | 2019-01-30 10:40:57 CTS T4 FIX | Subscribing to account: S1J* | 2019-01-30 10:40:57 Supported exchange: CME_NGOp (SIM:NYMEX NatGas Options) | 2019-01-30 10:40:57 Supported exchange: CME_CO (SIM:COMEX Futures) | 2019-01-30 10:40:57 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2019-01-30 10:40:57 Supported exchange: CME_CL (SIM:NYMEX CrudeOil Futures) | 2019-01-30 10:40:57 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2019-01-30 10:40:57 Supported exchange: CME_FRE (SIM:NYMEX Freight Futures) | 2019-01-30 10:40:57 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2019-01-30 10:40:57 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2019-01-30 10:40:57 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2019-01-30 10:40:57 Supported exchange: CME_NG (SIM:NYMEX NatGas Futures) | 2019-01-30 10:40:57 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2019-01-30 10:40:57 Supported exchange: CME_KOp (SIM:KCBT Options) | 2019-01-30 10:40:57 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2019-01-30 10:40:57 Supported exchange: CME_CLOp (SIM:NYMEX CrudeOil Options) | 2019-01-30 10:40:57 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2019-01-30 10:40:57 Supported exchange: CME_COAL (SIM:NYMEX Coal Futures) | 2019-01-30 10:40:57 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2019-01-30 10:40:57 Supported exchange: CME_K (SIM:KCBT Futures) | 2019-01-30 10:40:57 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2019-01-30 10:40:57 Supported exchange: CME_COALOp (SIM:NYMEX Coal Options) | 2019-01-30 10:40:57 Supported exchange: CME_ELEOp (SIM:NYMEX Power Options) | 2019-01-30 10:40:57 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2019-01-30 10:40:57 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2019-01-30 10:40:57 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2019-01-30 10:40:57 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2019-01-30 10:40:57 Supported exchange: CME_ELE (SIM:NYMEX Power Futures) | 2019-01-30 10:40:57 Supported exchange: CME_REF (SIM:NYMEX Refined Products Futures) | 2019-01-30 10:40:57 Supported exchange: CME_FREOp (SIM:NYMEX Freight Options) | 2019-01-30 10:40:57 Supported exchange: CME_PETOp (SIM:NYMEX NGL/Petrochemicals Options) | 2019-01-30 10:40:57 Supported exchange: CME_REFOp (SIM:NYMEX Refined Products Options) | 2019-01-30 10:40:57 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2019-01-30 10:40:57 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2019-01-30 10:40:57 Supported exchange: CME_COOp (SIM:COMEX Options) | 2019-01-30 10:40:57 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190100.CME_NY | 2019-01-30 10:40:57 Symbol Error - CL.20190100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-30 10:40:57 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-30 10:40:57 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190200.CME_NY | 2019-01-30 10:40:59 Symbol Error - CL.20190200.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-30 10:40:59 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-30 10:40:59 HD Request # 26 | Downloading Intraday chart data for CL.20190200.CME_NY to the file CL.20190200.CME_NY.scid. Service: nymex | 2019-01-30 10:40:59 HD Request # 26 | Download start date-time: 2019-01-22 13:29:59.000 | 2019-01-30 10:40:59 HD Request # 26 | Using server: ds7.sierracharts.com port 10149 | 2019-01-30 10:40:59 Socket (2) | Creating socket. | 2019-01-30 10:40:59 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-01-30 10:40:59 HD Request # 26 | Setting DTC encoding to Binary VLS | 2019-01-30 10:40:59 HD Request # 26 | Sending historical data logon request message. | 2019-01-30 10:40:59 HD Request # 26 | Requesting Intraday data. Start date-time: 2019-01-22 13:29:59. Record interval: 1. Symbol: CLG19 | 2019-01-30 10:41:00 HD Request # 26 | Decompressing data. | 2019-01-30 10:41:00 HD Request # 26 | Receiving Intraday data for CL.20190200.CME_NY starting at 2019-01-22 13:29:59 | 2019-01-30 10:41:00 HD Request # 26 | Timestamp of first Intraday data file record written: 2019-01-22 13:29:59 | 2019-01-30 10:41:00 Historical data download thread signaled to stop. | 2019-01-30 10:41:00 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 10:41:00 HD Request # 26 | Received 1 record from 2019-01-22 13:29:59 to 2019-01-22 13:29:59 (0.0 seconds) and wrote 1 record for CL.20190200.CME_NY | 2019-01-30 10:41:00 HD Request # 26 | Completion time: 0s | 2019-01-30 10:41:00 HD Request # 26 | Intraday data download complete for CL.20190200.CME_NY. Unique request ID: 25 | 2019-01-30 10:41:00 Removed historical data download ID 25 | 2019-01-30 10:41:00 Real-time Intraday chart data file updates started for CL.20190200.CME_NY | 2019-01-30 10:41:00 Opened cached Intraday file: C:\SierraChart\Data\CL.20190200.CME_NY.scid | 2019-01-30 10:41:00 Intraday chart data file opened for CL.20190200.CME_NY | 2019-01-30 10:41:00 HD Request # 27 | Downloading Intraday chart data for CL.20190100.CME_NY to the file CL.20190100.CME_NY.scid. Service: nymex | 2019-01-30 10:41:00 HD Request # 27 | Download start date-time: 2018-12-19 13:29:41.000 | 2019-01-30 10:41:00 HD Request # 27 | Using server: ds1.sierracharts.com port 10150 | 2019-01-30 10:41:00 Socket (3) | Creating socket. | 2019-01-30 10:41:00 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-01-30 10:41:00 Socket (2) | Socket gracefully closed by remote side. | 2019-01-30 10:41:00 Socket (2) | Closed. | 2019-01-30 10:41:00 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190300.CME_NY | 2019-01-30 10:41:00 HD Request # 27 | Setting DTC encoding to Binary VLS | 2019-01-30 10:41:00 HD Request # 27 | Sending historical data logon request message. | 2019-01-30 10:41:00 CTS T4 FIX | Received matching security definition for symbol CL.20190300.CME_NY. Subscribing to data. | 2019-01-30 10:41:00 CTS T4 FIX | Subscribing to symbol CL.20190300.CME_NY. Market: XCME_NY CL (H19) | 2019-01-30 10:41:00 Contract-Exchange: CL-CME_NY. Description: SIM:Crude Oil Mar19. Tick Size: 1.000000. Value Format: 0. Price Multiplier: 1.000000. Currency Value Per Tick: 10.000000 | 2019-01-30 10:41:00 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2019-01-30 10:41:00 HD Request # 27 | Requesting Intraday data. Start date-time: 2018-12-19 13:29:41. Record interval: 1. Symbol: CLF19 | 2019-01-30 10:41:00 Contract specifications for CL.20190300.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2019-01-30 10:41:01 HD Request # 27 | Decompressing data. | 2019-01-30 10:41:01 HD Request # 27 | Receiving Intraday data for CL.20190100.CME_NY starting at 2018-12-19 13:29:41 | 2019-01-30 10:41:01 HD Request # 27 | Timestamp of first Intraday data file record written: 2018-12-19 13:29:41 | 2019-01-30 10:41:01 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-01-30 10:41:01 Historical data download thread signaled to stop. | 2019-01-30 10:41:01 HD Request # 27 | Received 1 record from 2018-12-19 13:29:41 to 2018-12-19 13:29:41 (0.0 seconds) and wrote 1 record for CL.20190100.CME_NY | 2019-01-30 10:41:01 HD Request # 27 | Completion time: 0s | 2019-01-30 10:41:01 HD Request # 27 | Intraday data download complete for CL.20190100.CME_NY. Unique request ID: 26 | 2019-01-30 10:41:01 Removed historical data download ID 26 | 2019-01-30 10:41:01 Real-time Intraday chart data file updates started for CL.20190100.CME_NY | 2019-01-30 10:41:01 Opened cached Intraday file: C:\SierraChart\Data\CL.20190100.CME_NY.scid | 2019-01-30 10:41:01 Intraday chart data file opened for CL.20190100.CME_NY | 2019-01-30 10:41:01 Delaying start of download for CL.20190300.CME_NY | 2019-01-30 10:41:01 Socket (3) | Socket gracefully closed by remote side. | 2019-01-30 10:41:01 Socket (3) | Closed. | 2019-01-30 10:41:01 CTS T4 FIX | Requesting Open Orders for account: S1J*. Request ID: 2293000 | 2019-01-30 10:41:01 CTS T4 FIX | No open orders for account S1Jan29157920 | 2019-01-30 10:41:02 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2019-01-30 10:41:02 HTTPS www.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-30 10:41:04 HTTPS www.sierrachart.com:443 (2) | Connecting to IP: 46.4.97.203. | 2019-01-30 10:41:04 HTTPS www.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 10:41:04 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-30 10:41:04 HTTPS www.sierrachart.com:443 (2) | Closed. | 2019-01-30 10:41:04 HD Request # 28 | Downloading Intraday chart data for CL.20190300.CME_NY to the file CL.20190300.CME_NY.scid. Service: nymex | 2019-01-30 10:41:05 HD Request # 28 | Download start date-time: 2019-01-30 03:26:40.000 | 2019-01-30 10:41:05 HD Request # 28 | Using server: ds7.sierracharts.com port 10149 | 2019-01-30 10:41:05 Socket (2) | Creating socket. | 2019-01-30 10:41:05 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-01-30 10:41:05 HD Request # 28 | Setting DTC encoding to Binary VLS | 2019-01-30 10:41:05 HD Request # 28 | Sending historical data logon request message. | 2019-01-30 10:41:05 HD Request # 28 | Requesting Intraday data. Start date-time: 2019-01-30 03:26:40. Record interval: 1. Symbol: CLH19 | 2019-01-30 10:41:06 HD Request # 28 | Decompressing data. | 2019-01-30 10:41:06 HD Request # 28 | Receiving Intraday data for CL.20190300.CME_NY starting at 2019-01-30 03:26:40 | 2019-01-30 10:41:06 HD Request # 28 | Timestamp of first Intraday data file record written: 2019-01-30 03:26:40 | 2019-01-30 10:41:06 Historical data download thread signaled to stop. | 2019-01-30 10:41:07 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 10:41:07 HD Request # 28 | Received 17546 records from 2019-01-30 03:26:40 to 2019-01-30 10:31:06 (7.1 hours) and wrote 17546 records for CL.20190300.CME_NY | 2019-01-30 10:41:07 HD Request # 28 | Completion time: 0s | 2019-01-30 10:41:07 HD Request # 28 | Intraday data download complete for CL.20190300.CME_NY. Unique request ID: 27 | 2019-01-30 10:41:07 Removed historical data download ID 27 | 2019-01-30 10:41:07 Real-time Intraday chart data file updates started for CL.20190300.CME_NY | 2019-01-30 10:41:07 Opened cached Intraday file: C:\SierraChart\Data\CL.20190300.CME_NY.scid | 2019-01-30 10:41:07 Intraday chart data file opened for CL.20190300.CME_NY | 2019-01-30 10:41:07 CTS T4 FIX | Using primary service for historical data for CL.20190300.CME_NY | 2019-01-30 10:41:07 Intraday data recording state for symbol CL.20190300.CME_NY is set to download 'Pending'. | 2019-01-30 10:41:07 HD Request # 29 | Downloading Intraday chart data for CL.20190300.CME_NY to the file CL.20190300.CME_NY.scid. Service: cts | 2019-01-30 10:41:07 HD Request # 29 | Download start date-time: 2019-01-30 10:31:06.000 | 2019-01-30 10:41:07 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2019-01-30 10:41:07 Socket (2) | Socket gracefully closed by remote side. | 2019-01-30 10:41:07 Socket (2) | Closed. | 2019-01-30 10:41:07 CTS FIX Historical Data socket (3) | Creating socket. Using TLS 1.0. | 2019-01-30 10:41:09 CTS FIX Historical Data socket (3) | Connecting to IP: 74.201.6.229. | 2019-01-30 10:41:09 CTS FIX Historical Data: Sending the Logon message. | 2019-01-30 10:41:10 CTS FIX Historical Data: Connected to Historical data server. | 2019-01-30 10:41:10 HD Request # 29 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-30 00:00:00 to 2019-01-30 00:00:00 (US Central Time). | 2019-01-30 10:41:10 CTS T4 FIX | Requesting historical Fills for account: S1J*. Request ID: 2293001 | 2019-01-30 10:41:11 CTS T4 FIX | Received Account List collateral report. | 2019-01-30 10:41:12 CTS T4 FIX | Server provided no historical order fills for account EBEC0534-D38A-4FDD-8BD4-C9FD3581A6C1 | 2019-01-30 10:41:12 HD Request # 29 | Receiving Intraday data for CL.20190300.CME_NY starting at 2019-01-29 17:00:00 | 2019-01-30 10:41:17 HD Request # 29 | Timestamp of first Intraday data file record written: 2019-01-30 10:31:06 | 2019-01-30 10:41:17 HD Request # 29 | Total records received: 30962 | 2019-01-30 10:41:17 HD Request # 29 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-31 00:00:00 to 2019-01-31 00:00:00 (US Central Time). | 2019-01-30 10:41:17 HD Request # 29 | Total records received: 30962 | 2019-01-30 10:41:17 HD Request # 29 | Requesting historical Second data for CL.20190300.CME_NY from 2019-02-01 00:00:00 to 2019-02-01 00:00:00 (US Central Time). | 2019-01-30 10:41:17 HD Request # 29 | Received 30962 records from 2019-01-29 17:00:00 to 2019-01-30 10:41:10 (17.7 hours) and wrote 541 records for CL.20190300.CME_NY | 2019-01-30 10:41:17 Added 168 Time and Sales records to Intraday data file for CL.20190300.CME_NY after download. | 2019-01-30 10:41:17 HD Request # 29 | Completion time: 11s | 2019-01-30 10:41:17 HD Request # 29 | Intraday data download complete for CL.20190300.CME_NY. Unique request ID: 28 | 2019-01-30 10:41:17 Removed historical data download ID 28 | 2019-01-30 10:41:17 Real-time Intraday chart data file updates started for CL.20190300.CME_NY | 2019-01-30 10:41:17 Opened cached Intraday file: C:\SierraChart\Data\CL.20190300.CME_NY.scid | 2019-01-30 10:41:17 Intraday chart data file opened for CL.20190300.CME_NY | 2019-01-30 10:41:17 CTS FIX Historical Data socket (3) | Socket gracefully closed by remote side. | 2019-01-30 10:43:17 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2019-01-30 10:43:17 CTS FIX Historical Data socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-30 10:43:17 CTS FIX Historical Data: Disconnected. | 2019-01-30 10:43:17 CTS FIX Historical Data socket (3) | Closed. | 2019-01-30 10:43:17 File >> Disconnect selected. | 2019-01-30 10:45:51 CTS FIX: DisconnectFIX called. | 2019-01-30 10:45:51 CTS FIX: Sending a Logout message. | 2019-01-30 10:45:51 CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-01-30 10:45:51 CTS T4 FIX | Disconnected. | 2019-01-30 10:45:51 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-30 10:45:51 CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-01-30 10:45:51 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-30 10:45:51 CTS FIX socket (1) | Closed. | 2019-01-30 10:45:51 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-30 10:45:53 CTS T4 FIX | Firm: PTP | 2019-01-30 10:45:53 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-30 10:45:53 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-30 10:45:53 CTS FIX: Sending the Logon message. | 2019-01-30 10:45:53 CTS T4 FIX | FIX version: 4.7.23.0 | 2019-01-30 10:45:54 CTS T4 FIX | Connected to data and trading server. | 2019-01-30 10:45:54 CTS T4 FIX | Starting real-time market data updates for: CL.20190200.CME_NY. ID: 1 | 2019-01-30 10:45:54 CTS T4 FIX | Requesting security definition data for: CL.20190200.CME_NY. ID: 1 | 2019-01-30 10:45:54 Intraday data recording state for symbol CL.20190200.CME_NY is set to download 'Pending'. | 2019-01-30 10:45:54 CTS T4 FIX | Starting real-time market data updates for: CL.20190100.CME_NY. ID: 2 | 2019-01-30 10:45:54 CTS T4 FIX | Requesting security definition data for: CL.20190100.CME_NY. ID: 2 | 2019-01-30 10:45:54 Intraday data recording state for symbol CL.20190100.CME_NY is set to download 'Pending'. | 2019-01-30 10:45:54 CTS T4 FIX | Starting real-time market data updates for: CL.20190300.CME_NY. ID: 3 | 2019-01-30 10:45:54 CTS T4 FIX | Requesting security definition data for: CL.20190300.CME_NY. ID: 3 | 2019-01-30 10:45:54 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CL.20190300.CME_NY | 2019-01-30 10:45:54 Intraday data recording state for symbol CL.20190300.CME_NY is set to download 'Pending'. | 2019-01-30 10:45:54 Delaying start of download for CL.20190200.CME_NY | 2019-01-30 10:45:54 CTS T4 FIX | Received Account List collateral report. | 2019-01-30 10:45:54 CTS T4 FIX | Subscribing to account: S1J* | 2019-01-30 10:45:54 Supported exchange: CME_NGOp (SIM:NYMEX NatGas Options) | 2019-01-30 10:45:54 Supported exchange: CME_CO (SIM:COMEX Futures) | 2019-01-30 10:45:54 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2019-01-30 10:45:54 Supported exchange: CME_CL (SIM:NYMEX CrudeOil Futures) | 2019-01-30 10:45:54 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2019-01-30 10:45:54 Supported exchange: CME_FRE (SIM:NYMEX Freight Futures) | 2019-01-30 10:45:54 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2019-01-30 10:45:54 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2019-01-30 10:45:54 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2019-01-30 10:45:54 Supported exchange: CME_NG (SIM:NYMEX NatGas Futures) | 2019-01-30 10:45:54 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2019-01-30 10:45:54 Supported exchange: CME_KOp (SIM:KCBT Options) | 2019-01-30 10:45:54 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2019-01-30 10:45:54 Supported exchange: CME_CLOp (SIM:NYMEX CrudeOil Options) | 2019-01-30 10:45:54 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2019-01-30 10:45:54 Supported exchange: CME_COAL (SIM:NYMEX Coal Futures) | 2019-01-30 10:45:54 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2019-01-30 10:45:54 Supported exchange: CME_K (SIM:KCBT Futures) | 2019-01-30 10:45:54 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2019-01-30 10:45:54 Supported exchange: CME_COALOp (SIM:NYMEX Coal Options) | 2019-01-30 10:45:54 Supported exchange: CME_ELEOp (SIM:NYMEX Power Options) | 2019-01-30 10:45:54 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2019-01-30 10:45:54 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2019-01-30 10:45:54 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2019-01-30 10:45:54 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2019-01-30 10:45:54 Supported exchange: CME_ELE (SIM:NYMEX Power Futures) | 2019-01-30 10:45:54 Supported exchange: CME_REF (SIM:NYMEX Refined Products Futures) | 2019-01-30 10:45:54 Supported exchange: CME_FREOp (SIM:NYMEX Freight Options) | 2019-01-30 10:45:54 Supported exchange: CME_PETOp (SIM:NYMEX NGL/Petrochemicals Options) | 2019-01-30 10:45:54 Supported exchange: CME_REFOp (SIM:NYMEX Refined Products Options) | 2019-01-30 10:45:54 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2019-01-30 10:45:54 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2019-01-30 10:45:54 Supported exchange: CME_COOp (SIM:COMEX Options) | 2019-01-30 10:45:54 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190100.CME_NY | 2019-01-30 10:45:54 Symbol Error - CL.20190100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-30 10:45:54 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-30 10:45:54 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190200.CME_NY | 2019-01-30 10:45:56 Symbol Error - CL.20190200.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2019-01-30 10:45:56 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2019-01-30 10:45:56 HD Request # 30 | Downloading Intraday chart data for CL.20190200.CME_NY to the file CL.20190200.CME_NY.scid. Service: nymex | 2019-01-30 10:45:56 HD Request # 30 | Download start date-time: 2019-01-22 13:29:59.000 | 2019-01-30 10:45:56 HD Request # 30 | Using server: ds1.sierracharts.com port 10150 | 2019-01-30 10:45:56 Socket (2) | Creating socket. | 2019-01-30 10:45:56 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-01-30 10:45:56 HD Request # 30 | Setting DTC encoding to Binary VLS | 2019-01-30 10:45:57 HD Request # 30 | Sending historical data logon request message. | 2019-01-30 10:45:57 HD Request # 30 | Requesting Intraday data. Start date-time: 2019-01-22 13:29:59. Record interval: 1. Symbol: CLG19 | 2019-01-30 10:45:57 CTS T4 FIX | Sending security definition request to obtain SecurityID for symbol CL.20190300.CME_NY | 2019-01-30 10:45:57 HD Request # 30 | Decompressing data. | 2019-01-30 10:45:57 HD Request # 30 | Receiving Intraday data for CL.20190200.CME_NY starting at 2019-01-22 13:29:59 | 2019-01-30 10:45:57 HD Request # 30 | Timestamp of first Intraday data file record written: 2019-01-22 13:29:59 | 2019-01-30 10:45:57 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 10:45:57 Historical data download thread signaled to stop. | 2019-01-30 10:45:57 HD Request # 30 | Received 1 record from 2019-01-22 13:29:59 to 2019-01-22 13:29:59 (0.0 seconds) and wrote 1 record for CL.20190200.CME_NY | 2019-01-30 10:45:57 HD Request # 30 | Completion time: 0s | 2019-01-30 10:45:57 HD Request # 30 | Intraday data download complete for CL.20190200.CME_NY. Unique request ID: 29 | 2019-01-30 10:45:57 Removed historical data download ID 29 | 2019-01-30 10:45:57 Real-time Intraday chart data file updates started for CL.20190200.CME_NY | 2019-01-30 10:45:57 Opened cached Intraday file: C:\SierraChart\Data\CL.20190200.CME_NY.scid | 2019-01-30 10:45:57 Intraday chart data file opened for CL.20190200.CME_NY | 2019-01-30 10:45:57 HD Request # 31 | Downloading Intraday chart data for CL.20190100.CME_NY to the file CL.20190100.CME_NY.scid. Service: nymex | 2019-01-30 10:45:57 HD Request # 31 | Download start date-time: 2018-12-19 13:29:41.000 | 2019-01-30 10:45:57 HD Request # 31 | Using server: ds7.sierracharts.com port 10149 | 2019-01-30 10:45:57 Socket (3) | Creating socket. | 2019-01-30 10:45:57 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-01-30 10:45:57 CTS T4 FIX | Received matching security definition for symbol CL.20190300.CME_NY. Subscribing to data. | 2019-01-30 10:45:57 CTS T4 FIX | Subscribing to symbol CL.20190300.CME_NY. Market: XCME_NY CL (H19) | 2019-01-30 10:45:57 Contract-Exchange: CL-CME_NY. Description: SIM:Crude Oil Mar19. Tick Size: 1.000000. Value Format: 0. Price Multiplier: 1.000000. Currency Value Per Tick: 10.000000 | 2019-01-30 10:45:57 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2019-01-30 10:45:57 Socket (2) | Socket gracefully closed by remote side. | 2019-01-30 10:45:57 Socket (2) | Closed. | 2019-01-30 10:45:57 Contract specifications for CL.20190300.CME_NY. Multiplier: 1. Tick Size: 1. Value Format: 0. Currency Value per Tick: 10 | 2019-01-30 10:45:58 HD Request # 31 | Setting DTC encoding to Binary VLS | 2019-01-30 10:45:58 HD Request # 31 | Sending historical data logon request message. | 2019-01-30 10:45:58 CTS T4 FIX | Received 'Account Update/Balance Data' collateral report. | 2019-01-30 10:45:58 HD Request # 31 | Requesting Intraday data. Start date-time: 2018-12-19 13:29:41. Record interval: 1. Symbol: CLF19 | 2019-01-30 10:45:58 HD Request # 31 | Decompressing data. | 2019-01-30 10:45:58 HD Request # 31 | Receiving Intraday data for CL.20190100.CME_NY starting at 2018-12-19 13:29:41 | 2019-01-30 10:45:58 HD Request # 31 | Timestamp of first Intraday data file record written: 2018-12-19 13:29:41 | 2019-01-30 10:45:58 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-01-30 10:45:58 Historical data download thread signaled to stop. | 2019-01-30 10:45:58 HD Request # 31 | Received 1 record from 2018-12-19 13:29:41 to 2018-12-19 13:29:41 (0.0 seconds) and wrote 1 record for CL.20190100.CME_NY | 2019-01-30 10:45:58 HD Request # 31 | Completion time: 1s | 2019-01-30 10:45:58 HD Request # 31 | Intraday data download complete for CL.20190100.CME_NY. Unique request ID: 30 | 2019-01-30 10:45:58 Removed historical data download ID 30 | 2019-01-30 10:45:58 Real-time Intraday chart data file updates started for CL.20190100.CME_NY | 2019-01-30 10:45:58 Opened cached Intraday file: C:\SierraChart\Data\CL.20190100.CME_NY.scid | 2019-01-30 10:45:58 Intraday chart data file opened for CL.20190100.CME_NY | 2019-01-30 10:45:58 Delaying start of download for CL.20190300.CME_NY | 2019-01-30 10:45:58 Socket (3) | Socket gracefully closed by remote side. | 2019-01-30 10:45:59 Socket (3) | Closed. | 2019-01-30 10:45:59 CTS T4 FIX | Requesting Open Orders for account: S1J*. Request ID: 2293009 | 2019-01-30 10:45:59 CTS T4 FIX | No open orders for account S1Jan29157920 | 2019-01-30 10:45:59 HD Request # 32 | Downloading Intraday chart data for CL.20190300.CME_NY to the file CL.20190300.CME_NY.scid. Service: nymex | 2019-01-30 10:46:02 HD Request # 32 | Download start date-time: 2019-01-30 10:45:51.000 | 2019-01-30 10:46:02 HD Request # 32 | Using server: ds1.sierracharts.com port 10150 | 2019-01-30 10:46:02 Socket (2) | Creating socket. | 2019-01-30 10:46:02 Socket (2) | Connecting to IP: 8.18.161.135. | 2019-01-30 10:46:02 HD Request # 32 | Setting DTC encoding to Binary VLS | 2019-01-30 10:46:03 HD Request # 32 | Sending historical data logon request message. | 2019-01-30 10:46:03 HD Request # 32 | Requesting Intraday data. Start date-time: 2019-01-30 10:45:51. Record interval: 1. Symbol: CLH19 | 2019-01-30 10:46:03 HD Request # 32 | Decompressing data. | 2019-01-30 10:46:03 Historical data download thread signaled to stop. | 2019-01-30 10:46:03 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 10:46:03 HD Request # 32 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CL.20190300.CME_NY | 2019-01-30 10:46:03 HD Request # 32 | Completion time: 1s | 2019-01-30 10:46:03 HD Request # 32 | Intraday data download complete for CL.20190300.CME_NY. Unique request ID: 31 | 2019-01-30 10:46:03 Removed historical data download ID 31 | 2019-01-30 10:46:03 Real-time Intraday chart data file updates started for CL.20190300.CME_NY | 2019-01-30 10:46:03 Opened cached Intraday file: C:\SierraChart\Data\CL.20190300.CME_NY.scid | 2019-01-30 10:46:03 Intraday chart data file opened for CL.20190300.CME_NY | 2019-01-30 10:46:03 CTS T4 FIX | Using primary service for historical data for CL.20190300.CME_NY | 2019-01-30 10:46:03 Intraday data recording state for symbol CL.20190300.CME_NY is set to download 'Pending'. | 2019-01-30 10:46:03 HD Request # 33 | Downloading Intraday chart data for CL.20190300.CME_NY to the file CL.20190300.CME_NY.scid. Service: cts | 2019-01-30 10:46:03 HD Request # 33 | Download start date-time: 2019-01-30 10:45:51.000 | 2019-01-30 10:46:03 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2019-01-30 10:46:03 CTS FIX Historical Data socket (3) | Creating socket. Using TLS 1.0. | 2019-01-30 10:46:03 CTS FIX Historical Data socket (3) | Connecting to IP: 74.201.6.229. | 2019-01-30 10:46:03 Socket (2) | Socket gracefully closed by remote side. | 2019-01-30 10:46:03 Socket (2) | Closed. | 2019-01-30 10:46:03 CTS FIX Historical Data: Sending the Logon message. | 2019-01-30 10:46:04 CTS FIX Historical Data: Connected to Historical data server. | 2019-01-30 10:46:04 HD Request # 33 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-30 00:00:00 to 2019-01-30 00:00:00 (US Central Time). | 2019-01-30 10:46:04 CL.20190200.CME_NY 5 Min #1 | Reloading chart. | 2019-01-30 10:46:08 CL.20190200.CME_NY 500 Trades #3 | Reloading chart. | 2019-01-30 10:46:08 CL.20190200.CME_NY 100 Trades #5 | Reloading chart. | 2019-01-30 10:46:08 CTS T4 FIX | Requesting historical Fills for account: S1J*. Request ID: 2293010 | 2019-01-30 10:46:09 CTS T4 FIX | Received Account List collateral report. | 2019-01-30 10:46:09 CTS T4 FIX | Server provided no historical order fills for account EBEC0534-D38A-4FDD-8BD4-C9FD3581A6C1 | 2019-01-30 10:46:09 HD Request # 33 | Receiving Intraday data for CL.20190300.CME_NY starting at 2019-01-29 17:00:00 | 2019-01-30 10:46:09 HD Request # 33 | Timestamp of first Intraday data file record written: 2019-01-30 10:45:51 | 2019-01-30 10:46:10 HD Request # 33 | Total records received: 31247 | 2019-01-30 10:46:10 HD Request # 33 | Requesting historical Second data for CL.20190300.CME_NY from 2019-01-31 00:00:00 to 2019-01-31 00:00:00 (US Central Time). | 2019-01-30 10:46:10 HD Request # 33 | Total records received: 31247 | 2019-01-30 10:46:10 HD Request # 33 | Requesting historical Second data for CL.20190300.CME_NY from 2019-02-01 00:00:00 to 2019-02-01 00:00:00 (US Central Time). | 2019-01-30 10:46:10 HD Request # 33 | Received 31247 records from 2019-01-29 17:00:00 to 2019-01-30 10:46:05 (17.8 hours) and wrote 15 records for CL.20190300.CME_NY | 2019-01-30 10:46:10 Added 82 Time and Sales records to Intraday data file for CL.20190300.CME_NY after download. | 2019-01-30 10:46:10 HD Request # 33 | Completion time: 7s | 2019-01-30 10:46:10 HD Request # 33 | Intraday data download complete for CL.20190300.CME_NY. Unique request ID: 32 | 2019-01-30 10:46:10 Removed historical data download ID 32 | 2019-01-30 10:46:10 Real-time Intraday chart data file updates started for CL.20190300.CME_NY | 2019-01-30 10:46:10 Opened cached Intraday file: C:\SierraChart\Data\CL.20190300.CME_NY.scid | 2019-01-30 10:46:10 Intraday chart data file opened for CL.20190300.CME_NY | 2019-01-30 10:46:10 HTTPS www.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-30 10:46:11 HTTPS www.sierrachart.com:443 (2) | Connecting to IP: 46.4.97.203. | 2019-01-30 10:46:11 HTTPS www.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 10:46:12 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-30 10:46:12 HTTPS www.sierrachart.com:443 (2) | Closed. | 2019-01-30 10:46:12 CL.20190100.CME_NY 1 Min #6 | Reloading chart. | 2019-01-30 10:46:39 CL.20190100.CME_NY 100 Trades #6 | Reloading chart. | 2019-01-30 10:46:54 CL.20190100.CME_NY 50 Trades #6 | Reloading chart. | 2019-01-30 10:46:59 CTS FIX Historical Data socket (3) | Socket gracefully closed by remote side. | 2019-01-30 10:48:10 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2019-01-30 10:48:10 CTS FIX Historical Data socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-30 10:48:10 CTS FIX Historical Data: Disconnected. | 2019-01-30 10:48:10 CTS FIX Historical Data socket (3) | Closed. | 2019-01-30 10:48:10 CL.20190200.CME_NY 500 Trades #5 | Reloading chart. | 2019-01-30 11:03:39 CL.20190200.CME_NY 100 Trades #5 | Reloading chart. | 2019-01-30 11:03:45 CL.20190200.CME_NY Daily #5 | Reloading chart. | 2019-01-30 11:03:50 CL.20190200.CME_NY Daily #5 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data | 2019-01-30 11:03:50 HD Request # 34 | Downloading Historical Daily chart data for CL.20190200.CME_NY. Starting date: 2019-01-18. Service: cts | 2019-01-30 11:03:50 HD Request # 34 | Requesting historical Daily data for CLG19 starting at 2019-01-17 | 2019-01-30 11:03:50 HTTPS historicaldata.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-30 11:03:50 HTTPS historicaldata.sierrachart.com:443 (2) | Connecting to IP: 88.99.0.216. | 2019-01-30 11:03:50 HD Request # 34 | Receiving historical Daily data for CL.20190200.CME_NY starting at 2019-01-18 | 2019-01-30 11:03:51 HD Request # 34 | Writing historical Daily data to the file CL.20190200.CME_NY.dly | 2019-01-30 11:03:51 HD Request # 34 | Received 3 records from 2019-01-18 00:00:00 to 2019-01-22 00:00:00 (5.0 days) and wrote 2 records for CL.20190200.CME_NY | 2019-01-30 11:03:51 HD Request # 34 | Completion time: 0s | 2019-01-30 11:03:51 HD Request # 34 | Daily data download complete for CL.20190200.CME_NY. Unique request ID: 33 | 2019-01-30 11:03:51 Removed historical data download ID 33 | 2019-01-30 11:03:51 HTTPS historicaldata.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 11:03:51 CL.20190200.CME_NY Daily #5 | Reloading chart. | 2019-01-30 11:03:51 HTTPS historicaldata.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-30 11:03:51 HTTPS historicaldata.sierrachart.com:443 (2) | Closed. | 2019-01-30 11:03:51 CL.20190200.CME_NY 100 Trades #5 | Reloading chart. | 2019-01-30 11:03:57 CL.20190200.CME_NY 5 Min #1 | Reloading chart. | 2019-01-30 11:04:45 CL.20190100.CME_NY #1 | Reloading chart. | 2019-01-30 11:12:27 Requesting market depth updates for: CL.20190100.CME_NY if supported. | 2019-01-30 11:12:29 CL.20190100.CME_NY 1 Min #3 | Reloading chart. | 2019-01-30 11:13:19 CL.20190100.CME_NY 100 Trades #3 | Reloading chart. | 2019-01-30 11:13:23 CL.20190100.CME_NY Daily #3 | Reloading chart. | 2019-01-30 11:14:56 CL.20190100.CME_NY Daily #3 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data | 2019-01-30 11:14:56 HD Request # 35 | Downloading Historical Daily chart data for CL.20190100.CME_NY. Starting date: 2018-12-18. Service: cts | 2019-01-30 11:14:56 HD Request # 35 | Requesting historical Daily data for CLF19 starting at 2018-12-17 | 2019-01-30 11:14:56 HTTPS historicaldata.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-30 11:14:56 HTTPS historicaldata.sierrachart.com:443 (2) | Connecting to IP: 88.99.0.216. | 2019-01-30 11:14:56 HD Request # 35 | Receiving historical Daily data for CL.20190100.CME_NY starting at 2018-12-18 | 2019-01-30 11:14:56 HD Request # 35 | Writing historical Daily data to the file CL.20190100.CME_NY.dly | 2019-01-30 11:14:56 HD Request # 35 | Received 3 records from 2018-12-18 00:00:00 to 2018-12-19 00:00:00 (2.0 days) and wrote 2 records for CL.20190100.CME_NY | 2019-01-30 11:14:56 HD Request # 35 | Completion time: 0s | 2019-01-30 11:14:56 HD Request # 35 | Daily data download complete for CL.20190100.CME_NY. Unique request ID: 34 | 2019-01-30 11:14:56 Removed historical data download ID 34 | 2019-01-30 11:14:56 CL.20190100.CME_NY Daily #3 | Reloading chart. | 2019-01-30 11:14:57 HTTPS historicaldata.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 11:14:57 CL.20190100.CME_NY Weekly #4 | Reloading chart. | 2019-01-30 11:14:57 CL.20190100.CME_NY Daily #2 | Reloading chart. | 2019-01-30 11:14:57 HTTPS historicaldata.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-30 11:14:57 HTTPS historicaldata.sierrachart.com:443 (2) | Closed. | 2019-01-30 11:14:57 CL.20190100.CME_NY 60 Min #3 | Reloading chart. | 2019-01-30 11:15:02 Intraday data recording state for symbol CL.20190100.CME_NY is set to download 'Pending'. | 2019-01-30 11:15:56 HD Request # 36 | Downloading Intraday chart data for CL.20190100.CME_NY to the file CL.20190100.CME_NY.scid. Service: nymex | 2019-01-30 11:15:56 HD Request # 36 | Download start date-time: 2018-12-11 22:59:59.000 | 2019-01-30 11:15:56 HD Request # 36 | Disabling Intraday chart updating for symbol. | 2019-01-30 11:15:56 HD Request # 36 | Using server: ds7.sierracharts.com port 10149 | 2019-01-30 11:15:56 Socket (2) | Creating socket. | 2019-01-30 11:15:56 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-01-30 11:15:56 HD Request # 36 | Setting DTC encoding to Binary VLS | 2019-01-30 11:15:57 HD Request # 36 | Sending historical data logon request message. | 2019-01-30 11:15:57 HD Request # 36 | Requesting Intraday data. Start date-time: 2018-12-11 22:59:59. Record interval: 0. Symbol: CLF19 | 2019-01-30 11:15:57 HD Request # 36 | Decompressing data. | 2019-01-30 11:15:57 HD Request # 36 | Receiving Intraday data for CL.20190100.CME_NY starting at 2018-12-11 23:00:01 | 2019-01-30 11:15:58 HD Request # 36 | Truncating file to starting date-time of 2018-12-11 23:00:01 | 2019-01-30 11:15:58 HD Request # 36 | Timestamp of first Intraday data file record written: 2018-12-11 23:00:01 | 2019-01-30 11:15:58 Historical data download thread signaled to stop. | 2019-01-30 11:16:05 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-01-30 11:16:05 HD Request # 36 | Received 1282839 records from 2018-12-11 23:00:01 to 2018-12-19 13:29:41 (7.6 days) and wrote 1282839 records for CL.20190100.CME_NY | 2019-01-30 11:16:05 HD Request # 36 | Completion time: 8s | 2019-01-30 11:16:05 HD Request # 36 | Intraday data download complete for CL.20190100.CME_NY. Unique request ID: 35 | 2019-01-30 11:16:05 Removed historical data download ID 35 | 2019-01-30 11:16:05 Real-time Intraday chart data file updates started for CL.20190100.CME_NY | 2019-01-30 11:16:05 Intraday chart data file opened for CL.20190100.CME_NY | 2019-01-30 11:16:05 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2019-01-30 11:16:05 CL.20190100.CME_NY #1 | Flagging to reload Intraday data on download completion. | 2019-01-30 11:16:05 CL.20190100.CME_NY 60 Min #3 | Flagging to reload Intraday data on download completion. | 2019-01-30 11:16:05 CL.20190100.CME_NY 60 Min #3 | Reloading chart. | 2019-01-30 11:16:05 CL.20190100.CME_NY #1 | Reloading chart. | 2019-01-30 11:16:05 Socket (2) | Socket gracefully closed by remote side. | 2019-01-30 11:16:05 Socket (2) | Closed. | 2019-01-30 11:16:05 CL.20190100.CME_NY 100 Trades #3 | Reloading chart. | 2019-01-30 11:16:11 |
[2019-01-30 17:50:44] |
User907968 - Posts: 802 |
CL.20190200 (Feb) is expired contract, current contract is CL.20190300 (March) See link https://www.cmegroup.com/trading/energy/crude-oil/light-sweet-crude_product_calendar_futures.html Feb Contract expired 2019-01-22 |
[2019-01-30 17:52:58] |
hnariman - Posts: 4 |
Thanks a lot! Sorry for stupid question. Just weren't around for a while.
[2019-01-30 18:36:35] |
Yes that is the problem. You are using an expired contract.
