Date/Time: Thu, 09 May 2024 09:58:11 +0000
package and setup
View Count: 578
[2019-01-30 15:48:56] |
racebread - Posts: 2 |
Hello, I would like to purchase service and be ready with the proper feeds on FEB 1. I will be purchasing package 5 so I want to make sure I have the proper feeds to utilize all the delta features. I have interactive brokers and I have read there are a lot of issues with their data. To start, I will be using your charting for DOW,YM,CL,ES,NQ,GC futures. If I like the charting I will start using it for everything including large / small cap equities and some currencies pairs. Which feeds do you suggest to insure I can use all of the features like: depth of market data, ask/bid volume difference bars, ask volume bid volume difference text, numbers bars calculated values Will service package 5 with the IB integration be sufficient or should I purchase data through you all? Thank you for your time, have a good day. |
[2019-01-30 19:48:23] |
If you will be using the Numbers Bars study you will need Sierra Chart service package 5 (Advanced) And really you do have to use the Sierra Chart Exchange Data Feed for the type of analysis you will be doing. Interactive Brokers data is not sufficient. Here are the instructions for using that data feed: Sierra Chart Exchange Data Feed: Setup Instructions And you will have to activate the CME Group exchange with market depth. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-30 19:48:43
