Date/Time: Thu, 09 May 2024 08:05:11 +0000
Volume bars on Trade DOM different than chart
View Count: 1156
[2019-01-30 12:46:42] |
User462086 - Posts: 191 |
It looks like the Volume By Price study is using all of the current session's data to build the profile on the charts (this is what I want), but on the Trade DOM it is using only the volume that has taken place since Sierra Chart was opened. The value area and POC are different. How can I get the Trade DOM's volume bars to use all of the session's volume so it matches the charts? Many thanks!! |
[2019-01-31 09:41:45] |
but on the Trade DOM it is using only the volume that has taken place since Sierra Chart was opened. This could not be correct.Refer to the instructions here: Volume By Price Study: Volume Profile Differences There are several settings to check including the Session Times. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
