Date/Time: Thu, 09 May 2024 17:54:06 +0000
Export TPO Spreadsheet
View Count: 833
[2019-01-30 11:12:24] |
User661434 - Posts: 27 |
Is a spreadsheet of a custom study available (TPO in my case) and how could I export this? Thank You |
[2019-01-30 18:38:18] |
We are not understanding the question.
[2019-01-31 10:24:53] |
Ok, sorry, I was wondering if it is possible to export the data of an existing Sierra Study to a spreadsheet Sorry for the confusion |
[2019-01-31 19:15:34] |
In the case of the Sierra Chart TPO Profile Chart study, there is no data which would be outputted to a Spreadsheet. For other studies, yes. The whole idea behind the Spreadsheet studies is to be able to use the data of other studies. Refer to: Overview of Spreadsheet Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-31 19:16:29
