Date/Time: Mon, 29 Apr 2024 04:11:47 +0000
Multiple Copies of Sierra - Using the same settings
View Count: 2210
[2013-04-09 14:48:46] |
KinsaleForex - Posts: 19 |
I've just set up a second copy of Sierra Charts to pull data from Google finance. Everything is working fine but I was just wondering whether it's possible to copy any files over from the first instance of Sierra so that all my keyboard short cuts / right click menus / font settings etc etc would replicated in the new instance? Or would I have to set up all of this again? Thanks, KF Date Time Of Last Edit: 2013-04-09 14:52:03
[2013-04-09 16:05:08] |
Yes you can. Please refer to help topic 15 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-09 16:20:36] |
Great, thanks!
