Date/Time: Thu, 09 May 2024 06:20:20 +0000
Daily OHLC
View Count: 684
[2019-01-30 03:20:21] |
nicktrader - Posts: 665 |
At the moment I use the left setting. But if I want to change something I get the right picture
Daily OHLC.png / V - Attached On 2019-01-30 03:19:27 UTC - Size: 45.42 KB - 251 views |
[2019-01-30 19:41:55] |
Here is the documentation for that study: Daily OHLC You will want to set this Input to Yes with the study: Display Total Daily Volume Only Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-31 05:32:40] |
Pls take a look on the pic. From my point of view my settings are correct and there is a "bug" (Ver.: 1865)
OHLC Settings.png / V - Attached On 2019-01-31 05:30:53 UTC - Size: 39.45 KB - 231 views |
[2019-01-31 06:56:11] |
Only the Volume Subgraph will be enabled when you have set Display Total Daily Volume Only to Yes. The documentation does explain this.
