Date/Time: Thu, 09 May 2024 05:41:41 +0000
Manage chart drawings window has changed?
View Count: 978
[2019-01-30 00:27:48] |
User19165 - Posts: 346 |
Has the managed chart drawings window changed? Trading HKFE futures we rollover every month. My contextual auction chart has the past 6 months of data on it, that is 6 contracts worth of extending rectangles. I used to be able to select all the drawings from every contract and apply the contract adjustment amount. Now this looks more tedious and I have to do this separately for each contract on that chart via the symbols dropdown?
[2019-01-30 03:59:15] |
So you need to be able to list all symbols at the same time? We can do that. Also be aware there is a Multiple Selection checkbox at the top of the Manage Chart Drawings list.
[2019-01-30 05:39:34] |
Yes aware of the multi-select, but would be more ideal to list all symbols at once and then multi-select the entire lot. Thank you for the consideration.
