Date/Time: Wed, 15 May 2024 00:50:51 +0000
backlight settings when you hover the cursor to place an order
View Count: 699
[2019-01-29 17:24:44] |
AndreyPoroshin - Posts: 102 |
I can not find the backlight settings when you hover the cursor to place an order. In the standard setting, the bid was highlighted in green and ask in red. I want to do the same, because the yellow color is incomprehensible to me. Video file attached to the letter
Private File |
[2019-01-29 17:43:03] |
Well, your proposal to take the platform from you directly suits me. But I want to understand what benefits I will get. 1. Now I have to keep the recording function of the tools I need enabled, so that later I can return to the tick historical data in the DOM. I mean Replay. In the case of buying SierraChart, I will not need to record this data, if I understood correctly from the instructions for the platform. This is true? It says that the client receives complete with “package 5” historical data and a real-time quotation if he pays the quotation from a supplier, for example, CQG $ 15. In this case, what is the depth of the market on popular futures such as E-mini S & P, 6E? Now in my DOM the market depth is 10 ticks. I have "package 3" from AMP 2. How important is an additional package for 100 tools for $ 35, if in the first case, so everything is great? This is what I did not understand. The fact that the quality of quotations the supplier promises so high, then it can be even higher? |
[2019-01-30 01:52:10] |
1. No matter how your Sierra Chart account is obtained, Sierra Chart always by default downloads historical data and records data received in real time. There is nothing special to do and nothing changes in this regard. Although historical market depth data is not provided. That does have to be recorded. If you use the Sierra Chart Exchange Data feed, which is an additional cost to a service package, you can then get up to 50 levels of market depth data for CME symbols. 2. There is also a 25 USD option for 20 symbols with the Sierra Chart Exchange Data feed. Refer to: Sierra Chart Exchange Data Feed: Data Feed Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-30 01:52:45
