Date/Time: Thu, 09 May 2024 18:04:41 +0000
Able to view TPO counts?
View Count: 1575
[2019-01-29 05:48:51] |
TATrader20 - Posts: 6 |
http://www.sierrachart.com/image.php?Image=154874069373.png hi there, I have searched the TPO options line by line and cannot find a way to accomplish what I am trying to. I want to display the total TPO count above and below POC above the TPO chart itself. Much like in my image, the volume profile shows total volume above, and below POC. I would like to show the same data on the market profile chart and show the TPO count in the same fashion: tpo count above/ below POC (in the value area) any ideas on how this might be accomplished? thanks :) |
[2019-01-29 18:30:31] |
The TPO count above and below the point of control is only viewable in the Chart Values Windows: Time Price Opportunity (TPO) Profile Charts: Viewing TPO Profile Text Information Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-29 18:47:40] |
ok thank you, and as a follow up question... am i able to adjust the settings so the chart values window always shows the TPO Chart Values data, as opposed to the last clicked one? http://www.sierrachart.com/image.php?Image=1548787407919.png Meaning, in the image, the last chart i selected was the TPO chart, and thus, shows the TPO chart values in the window. But if i move over to the larger chart on right and start moving that chart around and working from there; the data in that text window changes. I want to keep the data shown in that window as is shown in image....the TPO data; regardless of the 'active' chart. is that possible? and thanks again :) |
[2019-01-30 19:05:53] |
No, what you want to do is not supported. It would require a separate Chart Values window for each chart which does not exist. Update: Actually there is a way to do this. You can use a sub instance of Sierra Chart which then is dedicated to your TPO charts or just even one TPO chart and you can keep the Chart Values window always open for that instance and just have that one particular chart active. Refer to: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-30 19:12:54
[2019-01-30 19:12:06] |
The prior post has been updated with an alternative solution.
