Date/Time: Mon, 06 May 2024 19:06:14 +0000
YM Missing daily data
View Count: 1180
[2013-11-12 10:20:29] |
Vincent G Davinci - Posts: 5 |
http://www.sierrachart.com/image.php?l=1384251423686.png I can not seem to get the YM Data from mar to april 2013 Thanks Vincent |
[2013-11-12 16:30:56] |
This looks like it might be due to the scaling. Open a new chart without any studies and default scaling and see if the data is there.
[2013-11-12 17:00:46] |
Also, re-download the data by selecting Edit >>Delete All Data and Download. Be sure to select the option to re-download data for all files.
