Date/Time: Sun, 28 Apr 2024 18:03:29 +0000
[Programming Help] - Change color for stair step on close
View Count: 1355
[2019-01-23 15:22:31] |
User66360 - Posts: 81 |
Is there anyway to change the color on the stair step on close charts? I would like it to go from red to green same as a candle chart. Thank you
[2019-01-23 23:31:28] |
Not through the main interface. You would need to use the Color Bar Based on Alert Condition to color the opposite direction than what is displayed. Be sure to follow the steps outlined in this section in particular, ignoring having to change the Based On Input: Color Bar Based on Alert Condition: Coloring Subgraphs of Other Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-24 12:14:14] |
This is very hard to do. These instructions for what Im trying to do is unclear. Can you type it up and I just copy and paste the code? Or add it as an attachment that I can download and plug in on my end? thank you
[2019-06-12 17:04:11] |
Ackin - Posts: 1865 |
Did you try this? Study settings / Subgraphs / Auto-coloring -> Same as Base Graph |
