Date/Time: Wed, 08 May 2024 05:08:07 +0000
Where is located the Study/Price Overlay study ?
View Count: 1304
[2013-11-11 16:46:25] |
SoundsLikeSun - Posts: 30 |
Hi, I cannot find the study/Price Overlay in any of the Studies#.cpp file. Could you please tell me where it is located, as I need to add something to it in ACSIL. Thank you for your help, Thomas |
[2013-11-13 21:41:36] |
Hi, Just wondering whether you got my message Thank you, Thomas |
[2013-11-13 22:19:07] |
Yes, but later it got overlooked. The source code for this study is not available because it has too much dependency on internal functions within Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-13 22:36:01] |
Interesting Thank you By the way, it would be nice to be able to disactivate the calculation of a study, with a tick case like the one for "hide study". Indeed I have a framework with a lot of different studies that I use for backtesting. Sometimes, instead of hiding, I'd rather disactivate them and save some CPU time. |
[2013-11-14 22:04:27] |
We recommend the use of Study Collections to easily apply a group of studies to the chart: http://www.sierrachart.com/index.php?l=doc/doc_StudyCollections.html This way, you can switch among all of your different configurations easily. We do not foresee ever adding the capability to deactivate the calculation of a study. Easily said but very complex and creates unexpected problems. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
