Date/Time: Fri, 16 Oct 2026 19:40:18 +0000
Do Numbers Bars Have Adjustable Column Widths?
View Count: 3768
| [2019-01-21 15:41:26] |
| User462086 - Posts: 203 |
I'm new to Sierra Chart and have a question about the Numbers Bars. Here's my current chart configuration: column #1 : total volume at price with full background based on actual volume column #2 : "bidvol x askvol" with full background coloring based on actual horizontal delta The width of column #2 is not needed for column #1 but I can't figure out how to adjust the column widths separately, ideally with a 'best-fit' or 'fixed pixel' approach. Is this possible? If this is not currently implemented is there a workaround? For example, could the total volume column + coloring be coded and plotted using Windows GDI functions? How much would this impact performance? And how difficult would it be to code? Many thanks!! Date Time Of Last Edit: 2019-01-22 04:37:03
| [2019-01-21 19:26:11] |
This is not possible. They are going to be fixed width based on the chart bar spacing: Working With Charts: Changing Bar Spacing In regards the programming question, we think trying to do this would be very difficult. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
