Date/Time: Thu, 02 May 2024 18:16:14 +0000
Data Feed- Sierra Chart real time data deed CME futures-
View Count: 1330
[2019-01-19 19:28:01] |
User379557 - Posts: 37 |
I would like to start the real time data feed CME nonprofessional with trading account and no market depth. Would like to start 1-21-19. Thanks- Greg Carnell |
[2019-01-19 20:00:58] |
Sierra Chart - Max - Posts: 5598 |
Refer to the setup instructions here: Sierra Chart Exchange Data Feed: Setup Instructions Note that you can take advantage of the Up to 2 Week Trial for 5 USD: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#2WeekTrial Be sure to read over the Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges here: Sierra Chart Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Sierra Chart Support |
[2019-01-19 21:07:32] |
I followed the instructions and don't know what was activated. I paid Total $78 in two payments of $63 and $15. I wanted to activate the real time data feed trial. Is it activated? I'm completely confused. Greg
[2019-01-19 22:21:41] |
I think I fixed the problem. Will know Monday. Thanks-
[2019-01-20 00:06:02] |
Since you have activated CME data, make sure Sierra Chart is connected to your trading account: Sierra Chart Exchange Data Feed: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-20 00:06:20
[2019-01-21 13:58:06] |
I'm receiving live data. However, not sure if its Gains-futures data or Sierra Charts data. How can I check to determine if I'm receiving SC real time data? Thanks- Greg |
[2019-01-21 18:42:19] |
Refer to step 8 here: Sierra Chart Exchange Data Feed: Integration with Trading Services (Integration with Trading Services) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-21 18:42:25
