Date/Time: Sun, 19 May 2024 18:37:13 +0000
[User Discussion] - Attached orders disappearing during live trading
View Count: 656
[2019-01-18 19:24:40] |
User104854 - Posts: 441 |
This happened to me this morning. As soon as I was filled the attached orders went away. My broker said that it might have something to do with CQG-Sierra Chart and to check with you. Please give me the details. Is it resolved? I can't trade if my attached orders go away for obvious reasons. Thanks. |
[2019-01-18 22:09:00] |
It sounds like the Attached Orders Time in Force is not set to good till canceled: Attached Orders: Time In Force Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-18 22:09:20
[2019-01-18 22:14:39] |
Actually, reading this again we think the orders may have gotten rejected. You need to check the Trade >> Trade Service Log for the reason.
[2019-01-18 22:23:36] |
I think I have it figured out. I use a spreadsheet to manage stops and targets. It accidentally gave a value that was above the daily limit that is allowed by the CME for the ES and it was rejected. Thank you.
