Date/Time: Mon, 29 Apr 2024 08:35:29 +0000
Right Click Erase Drawing No Longer Working
View Count: 585
[2019-01-18 09:12:37] |
Acro - Posts: 436 |
Hi, Re 1862, I have left click to drag a drawing and right click to erase ticked in the global settings - tool settings but right click no longer does erase the drawing. Instead, I have to go right click and then choose erase drawing from the menua I have attached a screenshot of my settings for your information. Is this expected behaviour now or is this a new bug ? Thanks |
SierraChart_64_2019-01-18_04-10-33.png / V - Attached On 2019-01-18 09:10:59 UTC - Size: 36.47 KB - 270 views Attachment Deleted. |
[2019-01-19 00:22:03] |
There's an option to keep the chart drawing selected after a modification. Be sure to use that.
