Date/Time: Sat, 11 May 2024 15:23:26 +0000
Copy value from number bars calculated values study
View Count: 769
[2019-01-16 16:26:39] |
pappe88 - Posts: 22 |
Hello, like shown in the picture, I'd like to copy the delta value of the number bar study (2) from the bottom right somehow as floating text, like the remaining time value (1) to the window of the left. Is there a way to do this? The number bar window on the right shows 1000 trades bars and the market depth on the left updates every two seconds. Yes, it is a detail, but it would be very helpful to have this single info largely visible on the left screen. Thank you very much! |
[2019-01-16 18:09:31] |
John - SC Support - Posts: 31534 |
Yes, this can be done with the Text Display for Study from Chart study for the data from the most recent bar. Refer to the documentation here for this: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-16 18:23:33
