Date/Time: Wed, 08 May 2024 22:23:40 +0000
Backfill problem with SC Forex Data (FXCM)
View Count: 1389
[2013-11-11 12:48:56] |
tobi - Posts: 351 |
I realized, that there are little gaps in the data, so I right-clicked and did Delete and Download Data for the corresponding FX pairs. With some pairs other gaps (little parts of missing data) occured. There seems to be a problem with that. Please advice what to do. |
[2013-11-11 17:55:48] |
We are checking on this.
[2013-11-11 21:23:05] |
We have discovered the source of the problem and this is now resolved. Go to the chart and select Edit >> Delete All Data and Download to re-download all the data and fill in the gaps.
[2013-11-12 05:39:41] |
tobi - Posts: 351 |
Thank you again for the quick fix! Just downloading the data. Here I'm seeing, on a 1 min chart, that at 00:00 (midnight) EST (NY-time) that 1-2 bars are missing for all symbols that I'm downloading (e.g. USD/JPY, USD/CHF etc). Hope this has nothing to do with the prior issue or the switch to the new day?! Date Time Of Last Edit: 2013-11-12 05:48:46
[2013-11-12 05:59:47] |
We do see about one minute missing at midnight New York time from the data from FXCM. Not much we can do about that. Hopefully it will not recur.
