Date/Time: Fri, 10 May 2024 12:00:00 +0000
multiple sybols with sme starting point on the left side and 5scale on the right side
View Count: 711
[2019-01-15 20:15:03] |
User472677 - Posts: 316 |
Please see attached. A common requirement to figure out correlations is to have multiple symbols on a chart -- starting point zero for all symbols and % scale on the right side. this is the standard for comparing multiple symbols. I have looked at your documentation on add symbol and overlay studies but can not figure out the scales. please help. |
correlation spy tlt gld.jpg / V - Attached On 2019-01-15 20:10:49 UTC - Size: 256.99 KB - 240 views |
[2019-01-16 16:17:58] |
Please reply
[2019-01-16 18:37:50] |
You need to use the Add Additional Symbol study, but the other study you need is Percent Change Since Open. You would then add all the symbols you want using the Add Additional Symbol study (you could hide these studies if you do not want to see them) and then add a Percent Change Since Open study for each symbol and put it them all in the same region. Just make that you change the colors of the Study Subgraphs to what you want for each symbol. Refer to the following for the Percent Change since Open study: Percent Change Since Open And: Add Additional Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-16 18:38:58
