Date/Time: Sun, 05 May 2024 01:44:47 +0000
how to click on a symbol on Quote board to change all chart symbols
View Count: 1871
[2013-11-11 21:56:16] |
infpz - Posts: 826 |
Under the settings menu on the Quote Board, select Set Chart Link and choose a link number. Then click on a chart, select the chart menu and at the bottom select linking, and select the same number. Repeat for each chart you want linked, then save via File > Save. -Patrick Zielbauer |
[2013-11-11 22:47:08] |
This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_GettingQuotes.html#ChangingSymbolOfChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
