Date/Time: Fri, 10 May 2024 21:45:11 +0000
ICE Canola ticker for Sierra under Interactive Brokers
View Count: 1624
[2019-01-13 17:13:32] |
Dirty_C - Posts: 2 |
Hey all - I can't for the life of me figure out how to get ICE Canola into Sierra using interactive brokers. Canola moved from WCE to ICE Canada and is now on ICE US. (this is fairly recent). Ticker should be something like RS. I've recently come back to Sierra after several years and need to get this obscure weirdo product working...any help is much appreciated!! |
[2019-01-14 10:53:57] |
Is this what you are referring to?: https://misc.interactivebrokers.com/cstools/contract_info/v3.10/index.php?action=Conid%20Info&wlId=IB&conid=328552027&lang=en We will get this added. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-15 05:48:38] |
Yes
[2019-01-15 19:02:02] |
This symbol has now been added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
