Date/Time: Fri, 27 Nov 2026 16:46:19 +0000
How to restore info from Message Log and Trade Service Log after SierraChart was closed?
View Count: 1188
| [2019-01-10 18:54:54] |
| User517260 - Posts: 97 |
Dear Support, how to restore info from Message Log and Trade Service Log after SierraChart was closed? Is it possible to switch on record of info from MessageLog and TradeServiceLog into file? Waiting for your reply, Alex. |
| [2019-01-10 19:45:34] |
You cannot but you can enable this option for next time: General Settings Window: Save Message Log to File (Global Settings >> General Settings >> Log >> Log) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-01-10 23:52:35] |
Thanks!
