Date/Time: Sun, 28 Apr 2024 05:24:40 +0000
Visualise large limit orders in the chart
View Count: 1692
[2019-01-10 15:06:24] |
JanS - Posts: 46 |
Is it possible to visualise limit orders, for instance, upwards of a certain number contracts in the chart? I don't mean the regular DOM bars on the right. If there is an order with 15 or more contracts (as an example), then a dot is displayed in the chart at the price of the limit order and at the time/chart bar when this order was active. Is there a study which can be used to achieve this?
[2019-01-10 19:05:34] |
We do not understand this. Are you referring to limit orders that you submit? Otherwise, have a look at the Market Depth Historical Graph study: Market Depth Historical Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-11 10:29:33] |
JanS - Posts: 46 |
This question relates to limit orders by general market participants as shown in the DOM graph. The DOM graph shows current limit order quantities at the various price levels. A study could filter for a certain quantity (i.e. everything above 20 contracts) and then place a dot above or below the current price in the chart at the price level at which limit orders of that quantity were placed. This dot stays in the chart whether the orders were executed or not. The trader can thus easily see price levels of high-quantity limit orders. These usually act as support or resistance. I take it that this is not possible with the studies currently available, correct? |
[2019-01-11 18:42:32] |
This is supported with the Market Depth Historical Graph study: Market Depth Historical Graph And you will want to use this input: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375&Name=Market_Depth_Historical_Graph#StudyInputs_GraphOnlyQuantitiesGreaterOrEqualTo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
