Date/Time: Mon, 14 Jul 2025 21:12:51 +0000
[Programming Help] - Study Function Programming Error Causing Freeze
View Count: 1240
[2019-01-10 06:46:54] |
User345961 - Posts: 2 |
Hi, as the title, It happens in Custom Study, Template Function, when I write a simple "cicle for" to find the first high bar, higher than actual. SCSFExport scsf_TemplateFunction(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { ...... return; } // Section 2 - Do data processing here unsigned int indexHigh; for(int i=sc.Index-1; ; i--) { if(sc.High > sc.High[sc.Index]) { indexHigh = i; break; } } Maybe it runs continuosly and could be the reason for the freeze....is there a way to insert a "delay" or "pause" in the code (like sleep function in python for example) Or is it another problem? Thank you! |
[2019-01-10 08:43:51] |
Yes that looks like an endless loop condition. You really need to study programming because that is completely wrong the way that for loop is written. Refer to: https://www.cprogramming.com/tutorial/lesson3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
