Date/Time: Sun, 19 May 2024 00:37:42 +0000
Crash when deleting multiple drawings
View Count: 607
[2019-01-10 05:35:34] |
User816220 - Posts: 80 |
Sierra Chart v1856-58 are crashing when I try to delete multiple drawings. Deleting them individually works fine. 1. Open SC in safe mode 2. Find Symbol -> ESH19 -> Open Intraday Chart 3. Draw two lines 4. Open Manage Chart Drawings window 5. Check Multiple Selection 6. Select the two drawings 7. Press Delete 8. Crash with status 0xc0000005 |
[2019-01-10 05:51:01] |
We will get this resolved now.
[2019-01-10 06:37:33] |
We will have version 1859 out in about 20 minutes.
