Date/Time: Mon, 06 May 2024 12:12:43 +0000
data not showing
View Count: 601
[2019-01-09 19:52:32] |
arruga - Posts: 249 |
hi please see this...data not showing on my hourly chart it does show in the weekly, daily, 15 min, etc, but the hourly is empty! http://www.sierrachart.com/image.php?Image=1547063445383.png Please advise |
[2019-01-09 22:52:04] |
First thing we want you to do is to open a completely new chart for that symbol and see if you see the chart. There may be some configuration issue with that particular chart.
[2019-01-09 23:01:22] |
I closed SC and reopened and now chart fine... is this something to be expected on occasions? interested in getting to the bottom of it thanks |
[2019-01-09 23:09:02] |
No it is not expected. We do not know what the problem was. Perhaps something with scaling.
