Date/Time: Sat, 04 May 2024 12:21:56 +0000
Message Log Updates
View Count: 658
[2019-01-09 12:59:02] |
GPST10 - Posts: 139 |
Looks like message log continues to show all quote updates endlessly, is it supposed to be that way now?
[2019-01-09 20:55:57] |
No. That is very inefficient. We see you are using CQG. Make sure Global Settings >> Data/Trade Service Settings >> Service Setting >> Log Real-Time Market Data Messages is disabled.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-09 20:56:18
[2019-01-10 00:41:28] |
Thanks, It was indeed selected, I can't remember doing so but never know - here is the problem now - I unchecked and restarted SC and it is still doing so... Based on numbers it is my Quote Board updates coming in full to the Log ... |
[2019-01-10 00:45:40] |
I double checked and there is unchecked that mark now but on the left side where the service values goes in like psw etc... there it is listed to log live feed and it is marked as TRUE and I can't change it... Please look in this problem. Thanks |
[2019-01-10 00:50:00] |
After unchecking LOG REAL TIME FIX MESSAGES I understand the value on the left should change to FALSE but it is not. I will try to restart machine and see.. UPDATE: NO DIFFERENT - IT IT IS TRUE FOR LOGGING LIVE MARKET MESSAGES Date Time Of Last Edit: 2019-01-10 00:56:58
[2019-01-10 01:19:20] |
We do not see any problem with changing the Service Settings. This has never been an issue and we cannot reproduce any issue. Do you have a problem changing any of the other CQG settings?
[2019-01-10 01:44:25] |
ON THE LEFT SIDE - NO I CAN'T CHANGE ANYTHING THERE NO PASSWORD NO ANY OTHER SETTING - IT'S LIKE LOCKED THERE.
[2019-01-10 01:49:39] |
FINALLY GOOD - I FIXED IT - I LOGGED IN TO THE WEB STYLE AND BACK TO FIX AND RADIO BUTTON SHOWES UP AND I UNCHECKED AND NOW IT IS OK, IT IS OK NOW. PROBLEM RESOLVED |
