Date/Time: Sun, 28 Apr 2024 21:16:20 +0000
What is the option
View Count: 534
[2019-01-09 11:23:05] |
traderacademie - Posts: 38 |
Hi, Can you explain what the option "Display Note" does? Can I enter a note for each order fill? The online manual isn't updated (Global Trade Settings Windows: Chart Trade Settings) The option can be found under Global Settings > Chart Trade Settings > Order Fills > Display Note Thanks, Will |
[2019-01-09 19:45:59] |
This is now documented here: Chart Trading and the Chart DOM: Displaying Order Fill Text Tag or Notes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
