Date/Time: Thu, 02 May 2024 14:03:17 +0000
Adjusting DOM Stop-Loss / Profit Targets
View Count: 1229
[2019-01-08 05:50:12] |
User116783 - Posts: 84 |
Hi, I'm using a simple bracket order with one profit target and two stop losses stacked on top of one another (see attached pic). From the DOM, is there a way to grab and adjust both stops at the same time? As is, I'm only able to move one at a time. Additionally, is there a way to have the profit target move with the stops when they're adjusted (and vice-versa)? For example, after being filled, if I moved my stop 10 ticks lower, the profit target would then move 10 ticks higher. Thanks, ZS |
2019-01-08_0-30-09.png / V - Attached On 2019-01-08 05:49:07 UTC - Size: 64.53 KB - 331 views |
[2019-01-08 16:12:16] |
John - SC Support - Posts: 31293 |
Move all stop Attached Orders to price: Chart Trading and the Chart DOM: Move Attached Stops to Price The answer to the other question is no. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-09 02:26:25] |
Thank you, that is a very useful feature. Is there also a way to quickly move all stops/price targets directly from the DOM as well? Thanks again. |
[2019-01-09 03:30:17] |
Yes the very same method applies as well to a Trading DOM. Just simply right-click somewhere other than the market data columns to select that command.
