Date/Time: Sat, 27 Apr 2024 17:48:11 +0000
Windows error code 10060
View Count: 2265
[2019-01-07 11:05:23] |
User279374 - Posts: 4 |
Hi I am getting an error code when opening up the program and a chartbook where the data is not being updated from the data feed with the above error message. I only run into this issue when connected to this particular network at work and the data loads fine on my connection at home, which seems like there might be a firewall blocking some ports. I tried the options to use port 443 for real time data and port 80 for historical data but that did not work. Any help would be really appreciated! The message log is below: Reading Internal Order ID file. | 2019-01-07 05:49:39 Reading Trade Orders file. | 2019-01-07 05:49:39 Reading Trade Positions file. | 2019-01-07 05:49:39 Account Balance file. | 2019-01-07 05:49:39 Listening on UDP port 22904. | 2019-01-07 05:49:39 Software version: 1853 64-bit | 2019-01-07 05:49:39 Usage end date: 2019-02-07 | 2019-01-07 05:49:39 Enabled for: Advanced Features. | 2019-01-07 05:49:39 Enabled for: Sierra Chart Historical Data Service. | 2019-01-07 05:49:39 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-01-07 05:49:39 Enabled for: INDEXES_DATA_BARCHART | 2019-01-07 05:49:39 Enabled for: CME with Market Depth for nonprofessional Trading accounts | 2019-01-07 05:49:39 Received 1 data feed usernames. | 2019-01-07 05:49:39 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-01-07 05:49:39 Current selected Data/Trading service: SC Data - All Services | 2019-01-07 05:49:39 Chart Update Interval: 500 | 2019-01-07 05:49:39 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-01-07 05:49:39 2019-01-07 10:49:39 Local computer time | 2019-01-07 05:49:39 2019-01-07 10:49:39 Local computer time in UTC | 2019-01-07 05:49:39 2019-01-07 05:49:39 Local computer time in SC Time Zone | 2019-01-07 05:49:39 Program path: C:\SierraChart\ | 2019-01-07 05:49:39 Data Files path: C:\SierraChart\Data\ | 2019-01-07 05:49:39 OS Version Number: 10.0 | 2019-01-07 05:49:39 Locale Setting: C | 2019-01-07 05:49:39 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-01-07 05:49:39 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2019-01-07 06:01:46 DTC Client socket (1) | Closed. | 2019-01-07 06:01:46 SC Data - All Services | Using username 0 | 2019-01-07 06:01:48 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2019-01-07 06:01:48 DTC Client socket (1) | Creating socket. | 2019-01-07 06:01:48 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2019-01-07 06:01:48 DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-01-07 06:02:09 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-01-07 06:02:09 DTC Client socket (1) | Signaling to core to close socket | 2019-01-07 06:02:09 DTC Client socket (1) | Closed. | 2019-01-07 06:02:09 SC Data - All Services | Disconnected from the server. | 2019-01-07 06:02:09 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2019-01-07 06:02:09 SC Data - All Services | Using username 0 | 2019-01-07 06:02:11 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2019-01-07 06:02:11 DTC Client socket (1) | Creating socket. | 2019-01-07 06:02:11 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2019-01-07 06:02:11 Date Time Of Last Edit: 2019-01-07 20:49:55
[2019-01-07 20:49:01] |
It is clear from these messages that either the IP address or port 443 is getting blocked somewhere on your side: SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2019-01-07 06:01:48
DTC Client socket (1) | Creating socket. | 2019-01-07 06:01:48 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2019-01-07 06:01:48 DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-01-07 06:02:09 * Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-12 00:14:18] |
User476868 - Posts: 5 |
Hello, Just wondering whether you ever managed to solve the problem as I have had the exact same experience today. Moved to a new office and SC goes down with the similar connection issue. Got back home this evening and SC was working again. From reading documentation, it appears likely to be a firewall issue but still don't know how to resolve. Any suggestions very welcome! |
[2021-03-17 05:34:51] |
Crystal77 - Posts: 28 |
SAME PROBLEM !! SOME PEOPLE HAVE SOME SOLUTION ABOUT THIS ?????? SC CANT HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! allll0OOOOOOOOOOOOOOOOOOOOOOOOOOOO HEEYYYYYYYYYYYYYYYY |
[2021-03-17 06:20:54] |
File attached
[2021-03-17 08:06:12] |
Regarding post #4 and post #5, this is a CQG connectivity issue. That is not something we can help with. Other than to refer you to: CQG Trading Platform Service: Frequent Server Disconnections when Using CQG The section linked above is a different type of issue, however It does have relevant information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
