Date/Time: Thu, 02 May 2024 12:09:02 +0000
Scaling in with limit orders
View Count: 1290
[2013-11-09 17:44:43] |
Bob77 - Posts: 17 |
Hi, is it possible to use two or more limit orders that when filled have the same stop loss and target attached? Or put it another way: can I scale in using just limit orders, or do I have to have an open position? Thanks |
[2013-11-09 23:00:42] |
Refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#ScalingIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
