Date/Time: Mon, 06 May 2024 11:58:38 +0000
[Programming Help] - Alert on the color of the indicator.
View Count: 623
[2019-01-06 20:55:34] |
2garin - Posts: 184 |
Good afternoon support. Is it possible to create alerts by indicator color? Tell me please: How to create an alert in ColorBackgroundBasedonAlertCondition for all blue bars above zero? |
[2019-01-06 21:55:02] |
Sawtooth - Posts: 3993 |
The blue bars are up-sloped, so use a formula like this for an alert at every blue bar above zero: =AND(ID5.SG1>ID5.SG1[-1],ID5.SG1>0) If you want an alert at the first blue bar above zero, use this: =OR( AND(ID5.SG1[-2]>ID5.SG1[-1],ID5.SG1>ID5.SG1[-1],ID5.SG1>0), AND(ID5.SG1>ID5.SG1[-1],ID5.SG1[-1]<0,ID5.SG1>0)) |
[2019-01-06 23:28:59] |
With equal bars height, the color is inverted. How to mark blue bars in similar situations? In the next releases of the terminal, you can add a function that returns the value of one of the colors of the indicator colors? |
[2019-01-06 23:30:45] |
First, I'm a user, not SC Support. Second, if the bars change color, they are not the same height. |
[2019-01-06 23:35:39] |
increased the number of decimal places and the condition worked.
[2019-01-09 09:18:27] |
How to mark all the bars in red (and equal too)?
[2019-01-09 15:15:49] |
Try this: =AND(ID4.SG1<=ID4.SG1[-1],ID4.SG1>0) If you look at the documentation and examples for alerts, you will be able to write your own formulas: Study/Chart Alerts And Scanning: Alert Condition Formula Format Study/Chart Alerts And Scanning: Alert Formula Examples |
